    HMDI (from Pi 3) to DVI? Will it work?
    11 Posts 9 Posters 12.7k Views 8 Watching
      McSorley
      I have a DVI right angle adapter with a DVI to HDMI Cable.
      • indigomejorI Offline
        indigomejor
        Hi, will work VGA cable with HDMI adapter? Thank you very much!
          McSorley
          Dont get a straight VGA to HDMI cable because it wouldnt work. You would need convertor which is a bit larger than you would expect and often need to be powered.
          • yawnsY Offline
            yawns Moderator
            Right, you need an active HDMI-VGA converter.
            You could go for this: https://thepihut.com/products/raspberry-pi-hdmi-to-vga-convertor
            However the “chain” looks a bit ugly (second image) and I could imagine it is a bit unsteady.
            Or you go for this: https://www.pi-supply.com/product/gert-vga-666-hardware-vga-raspberry-pi/
            However this blocks almost all GPIO ports and you need to solder it on your own, as it is a kit
            indigomejorI 1 Reply Last reply Reply Quote 0
              indigomejor @yawns
              @McSorley @yawns thank you guys! The blue one looks exactly like something I discovered in my local shop, so it’s solved, thank you!
                bibi
                in the same idea an adaptor display port > hdmi would also work no? anyone has tried this ?
                  dbahn25 @bibi
                  @bibi display port to hdmi works definitely. it’s both digital, so the adapter should be pretty simple and cheap (I use one for ~12€ from miniDP to HDMI on my laptop)
