    602 Posts 67 Posters 2.3m Views 68 Watching
      shbatm Module Developer @djuscha
      @djuscha said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      I found that on my troubleshooting on the internet maybe that helps us?
      RTSP-Stream-Viewer
      Thanks for the link. Bits of that script look like the script I saw which originally inspired me to use omxplayer, but it has some additional options (like pushing a video off the screen instead of stopping it) that seem promising. I ended up using pm2 instead of screen because that’s what most MM users were already using, and it had the auto restart feature built in.
      I don’t have much time for the next month or so to keep playing with the omx version, so if you wouldn’t mind, please open an issue on GitHub, and if you or anyone has time/skills to implement, I’ll be happy to take a PR.
      To-do (notes to myself or anyone that works on this):
      1. Implement dbus control to move the video off-screen instead of stopping it when we need to hide it: Example dbuscontrol.sh; npm dbus Package
      2. Implement ffmpeg & vlc’s shutdownDelay option for omx player (e.g. move the video off-screen and stop it after x seconds instead of stopping it immediately when hiding a stream).
        shbatm Module Developer @swvalenti
        @swvalenti said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
        How do I make that switch and implement? Sorry for the noob question.
        Look back at previous posts in this thread, there should be several posts from the past month about switching and upgrading.
          @djuscha Use the latest develop branch version if you still want to use omxplayer with OpenGL (Fake KMS). I was stumbling around and found that omxplayer requires the --no-osd flag to work properly with the OpenGL (Fake KMS) driver.
            costascontis
            can someone use vlc instead of omxplayer with your module?If yes whats the pro and con on that?
            BKeyportB S 2 Replies Last reply Reply Quote 0
            • BKeyportB Offline
              BKeyport Module Developer @costascontis
              @costascontis said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              I know on the develop branch you can.
              Pro: it kept the original aspect ratio.
              con: it didn’t work more than once.
                shbatm Module Developer @costascontis
                Yes, its still experimental but was working fine for me. If you’re on a Raspberry Pi, it works best if you’re using the newest distro of Raspbian because VLC has Hardware Acceleration enabled.
                Your mileage may vary between omxplayer and VLC. OMXPlayer is finicky and doesn’t rotate streams well (will be working on that)–VLC should in theory be much more stable and easy to use, but some people have had issues getting it to respond correctly on the Pi.
                Back up a few pages on this thread to find out how to install the develop branch.
                Cr4z33C 3 Replies Last reply Reply Quote 0
                • Cr4z33C Offline
                  Cr4z33 @shbatm
                  @shbatm I hope your module will be perfect one day until then I have unfortunately to give up with the channel switching function and set a static Radio/TV stream. :thumbs_up_medium-light_skin_tone:
                  • Cr4z33C Offline
                    Cr4z33 @shbatm
                    Hi @shbatm ,
                    how is the bug fixing job doing right now? :)
                    I’ve done in the meantime some testing both with VLC and OMXplayer options by using different streaming sources like mp3 podcasts, mp4 live channels & some IP cameras (that I’ve got at home).
                    I can confirm that something is wrong in the module code because the EXACT same issue (wrong stream selected while switching) is happening with the above sources. :confused_face:
                    • Cr4z33C Offline
                      Cr4z33 @shbatm
                      @shbatm you there mate? :smiling_face_with_open_mouth_cold_sweat:
                        shbatm Module Developer @Cr4z33
                        @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
                        you there mate?
                        Gotta earn some money to pay for all my expensive hobbies… Currently 100 miles from land for the next week so debugging will be… Slow.
                        In the meantime, can you please send/share/chat me a copy of your config with both this module and the controlling module sections at least? Also, have you tried using a different module, like my branch of MMM-Remote-Control w api to control the streams? Is it always the same number of streams wrong, or is it for sure random?
                          djuscha
                          Have now made everything new. Raspe new SD card new. MagicMirror Software nue and RTSP module made new. I had 2 cameras. That ran for a few hours and then a camera picture was black, although PM2 status was online. After rebooting everything went again for a few hours.
                          have omxRestart set to 2 hours in both cameras that did not help synonymous.
                          Raspberry Pi 3 RTSP Stream Viewer
                          Now I’ve configured according to the instructions and this is stable for 3 days. Is independent of Magicmirror running in the foreground.
                          have a Raspi and there runs Raspberry Pi 3 RTSP Stream Viewer with 4 cameras for 5 days very stable. I also tested on Raspi zero, and it worked.
                          • Cr4z33C Offline
                            Cr4z33 @shbatm
                            @shbatm I’ve sent you the config link by private chat. ;)
                            Honestly I don’t want to use MMM-Remote-Control or other solutions but voice control in the end so no I didn’t try.
                            All I can say is that the issue happens with whatever source I use and the chosen (wrong) stream is ALWAYS random.
                            If using VLC multiple streams start at the same time while if using OMXplayer a single (wrong) stream is selected.
                            Last thing I am using your dev version of the module.
                            You should get the issue if using the same config and modules. :slightly_smiling_face:
                            • swvalentiS Offline
                              swvalenti Project Sponsor
                              Switched to VLC but issue is now the stream doesn’t fit window…0_1548019379662_VLC.PNG
                              • BKeyportB Offline
                                I recommend in your custom.css file:
                                .MMM-RTSPStream .innerWrapper {
                                border: 0;
                                No more border. :)
                                  costascontis
                                  i try to use develop branch module with vlc and it works fine but one thing.It crashes after an hour or so ,my Gassist (google assistant) that is running at the same pi.My noobish explanation is that vlc module is taking over mic after some time .If i turn off (comment at config.js) the module ,everything work fine for days.
                                  • K Offline
                                    kasperb @costascontis
                                    @costascontis Interesting… I have the same issue with the RTSP feed cutting out as soon as I activate the Google Assistant (MMM-AssistantMk2). Not sure whether it’s triggered by the mic, my guess is that it’s related to the screen output part of the MMM-AssistantMk2 module.
                                    • Cr4z33C Offline
                                      Cr4z33
                                      @shbatm I’ve sent you yesterday a private message with everything you asked me.
                                      Did you find in it anything helpful to fix the issue? :)
                                      • Cr4z33C Offline
                                        Cr4z33 @kasperb
                                        @kasperb should be working as intended then.
                                        If not pausing when there’s ie. a streaming playing with audio it could then insert unwanted words into a voice command therefore resulting into a not understandable (by Google Assistant) command.
                                        • K Offline
                                          kasperb @Cr4z33
                                          @cr4z33 That’s a good point. Should the stream come back up after a few minutes? Right now, I have to refresh the browser (using mmm-remotecontrol) in order for the feed to restart.
                                          • Cr4z33C Offline
                                            Cr4z33 @kasperb
                                            @kasperb I actually added some code parts in the voice command module as per suggestion of its developer.
                                            If you’re using MMM-AssistantMk2 then I can tell you what to do (not if using other modules). :)
                                            K 2 Replies Last reply Reply Quote 0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 30
                                            • 31
                                            • 12 / 31
