    602 Posts 67 Posters 2.1m Views 68 Watching
      shbatm Module Developer @costascontis
      @costascontis said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
      can someone use vlc instead of omxplayer with your module?If yes whats the pro and con on that?
      Yes, its still experimental but was working fine for me. If you’re on a Raspberry Pi, it works best if you’re using the newest distro of Raspbian because VLC has Hardware Acceleration enabled.
      Your mileage may vary between omxplayer and VLC. OMXPlayer is finicky and doesn’t rotate streams well (will be working on that)–VLC should in theory be much more stable and easy to use, but some people have had issues getting it to respond correctly on the Pi.
      Back up a few pages on this thread to find out how to install the develop branch.
      Cr4z33C 3 Replies Last reply Reply Quote 0
      • Cr4z33C Offline
        Cr4z33 @shbatm
        @shbatm I hope your module will be perfect one day until then I have unfortunately to give up with the channel switching function and set a static Radio/TV stream. :thumbs_up_medium-light_skin_tone:
        • Cr4z33C Offline
          Cr4z33 @shbatm
          Hi @shbatm ,
          how is the bug fixing job doing right now? :)
          I’ve done in the meantime some testing both with VLC and OMXplayer options by using different streaming sources like mp3 podcasts, mp4 live channels & some IP cameras (that I’ve got at home).
          I can confirm that something is wrong in the module code because the EXACT same issue (wrong stream selected while switching) is happening with the above sources. :confused_face:
          • Cr4z33C Offline
            Cr4z33 @shbatm
            @shbatm you there mate? :smiling_face_with_open_mouth_cold_sweat:
              shbatm Module Developer @Cr4z33
              @cr4z33 said in [MMM-RTSPStream] - Video Streaming from Live Feeds & Security Cameras:
              you there mate?
              Gotta earn some money to pay for all my expensive hobbies… Currently 100 miles from land for the next week so debugging will be… Slow.
              In the meantime, can you please send/share/chat me a copy of your config with both this module and the controlling module sections at least? Also, have you tried using a different module, like my branch of MMM-Remote-Control w api to control the streams? Is it always the same number of streams wrong, or is it for sure random?
                djuscha
                Have now made everything new. Raspe new SD card new. MagicMirror Software nue and RTSP module made new. I had 2 cameras. That ran for a few hours and then a camera picture was black, although PM2 status was online. After rebooting everything went again for a few hours.
                have omxRestart set to 2 hours in both cameras that did not help synonymous.
                Raspberry Pi 3 RTSP Stream Viewer
                Now I’ve configured according to the instructions and this is stable for 3 days. Is independent of Magicmirror running in the foreground.
                have a Raspi and there runs Raspberry Pi 3 RTSP Stream Viewer with 4 cameras for 5 days very stable. I also tested on Raspi zero, and it worked.
                • Cr4z33C Offline
                  Cr4z33 @shbatm
                  @shbatm I’ve sent you the config link by private chat. ;)
                  Honestly I don’t want to use MMM-Remote-Control or other solutions but voice control in the end so no I didn’t try.
                  All I can say is that the issue happens with whatever source I use and the chosen (wrong) stream is ALWAYS random.
                  If using VLC multiple streams start at the same time while if using OMXplayer a single (wrong) stream is selected.
                  Last thing I am using your dev version of the module.
                  You should get the issue if using the same config and modules. :slightly_smiling_face:
                  • swvalentiS Offline
                    swvalenti Project Sponsor
                    Switched to VLC but issue is now the stream doesn’t fit window…0_1548019379662_VLC.PNG
                    • BKeyportB Online
                      BKeyport Module Developer
                      I recommend in your custom.css file:
                      .MMM-RTSPStream .innerWrapper {
                      border: 0;
                      No more border. :)
                        costascontis
                        i try to use develop branch module with vlc and it works fine but one thing.It crashes after an hour or so ,my Gassist (google assistant) that is running at the same pi.My noobish explanation is that vlc module is taking over mic after some time .If i turn off (comment at config.js) the module ,everything work fine for days.
                        • K Offline
                          kasperb @costascontis
                          @costascontis Interesting… I have the same issue with the RTSP feed cutting out as soon as I activate the Google Assistant (MMM-AssistantMk2). Not sure whether it’s triggered by the mic, my guess is that it’s related to the screen output part of the MMM-AssistantMk2 module.
                          • Cr4z33C Offline
                            Cr4z33
                            @shbatm I’ve sent you yesterday a private message with everything you asked me.
                            Did you find in it anything helpful to fix the issue? :)
                            • Cr4z33C Offline
                              Cr4z33 @kasperb
                              @kasperb should be working as intended then.
                              If not pausing when there’s ie. a streaming playing with audio it could then insert unwanted words into a voice command therefore resulting into a not understandable (by Google Assistant) command.
                              • K Offline
                                kasperb @Cr4z33
                                @cr4z33 That’s a good point. Should the stream come back up after a few minutes? Right now, I have to refresh the browser (using mmm-remotecontrol) in order for the feed to restart.
                                • Cr4z33C Offline
                                  Cr4z33 @kasperb
                                  @kasperb I actually added some code parts in the voice command module as per suggestion of its developer.
                                  If you’re using MMM-AssistantMk2 then I can tell you what to do (not if using other modules). :)
                                  K 2 Replies Last reply Reply Quote 0
                                    costascontis
                                    i think using this module from develop branch it work decent with vlc but…it is breaking other modules and features and freezing mm from time to time.My backup from pre installing develop branch is working for weeks without a glitch.After installing the module and viewing just one stream ,its a matter of a few hours that something will stuck or mm freeze.I think that upgrading electron and using opengl is not ready for MM yet.
                                      anthony6608 @Cr4z33
                                      Did you see his post where he stated he was away working to earn money? :) They do this on their spare time for free and have to make a living somehow. He’s been very good with answering my questions when he is around. I am sure he’ll respond as soon as he returns and has a chance.
                                      • K Offline
                                        kasperb @Cr4z33
                                        • K Offline
                                          kasperb @Cr4z33
                                          Yes, I’m using MMM-AssistantMk2. Would love to hear your suggestion.
                                          Cr4z33C K 2 Replies Last reply Reply Quote 0
                                          • Cr4z33C Offline
                                            Cr4z33 @kasperb
                                            @kasperb in your config.js go to the MMM-AssistantMk2 module and add
                                            					onActivate: {
                                            							timer: 0,
                                            							command: "RTSP_DEACTIVATE"
                                            					command: {
                                            							"RTSP_DEACTIVATE": {
                                            										notificationExec: {
                                            													notification: "RTSP-STOP",
                                            													payload: "all"
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 30
                                            • 31
                                            • 12 / 31
