    Besides your MagicMirror, what are some Maker-projects you worked/working on?
    23 Posts 10 Posters 20.7k Views 10 Watching
    • T Offline
      Tomekkkkk @Tomekkkkk
      @Tomekkkkk
      Update - it works
      Bild Text
      Bild Text
      Bild Text
      Bild Text
      • K Offline
        KirAsh4 Moderator
        This is an existing design that I modify to get rid of things a laser cutter can not make. Original design calls for dowels in certain spots (axles and such), I modify it to use the same flat sheet material. This’ll be a fun build
        And how this compares to the Front End Loader I made last year:
          Mitchfarino Module Developer
          This is going to be my next project.
          GameBoy Zero!
          • Z Offline
            zombi27
            waaah <3 that gamebooy :D i want to make an N64 out of a pi soon
            • K Offline
              KirAsh4 Moderator
              As if I don’t already have a bunch of stuff on my plate, yesterday someone asked me to re-make this for them:
              https://www.youtube.com/watch?v=r8PtwqRvVDU
              After calculating all 148 parts, it comes out to 135 hours of printing (24 hours a day, non-stop), $60 worth of material, about 175 meters of it. If I were to print it at high quality, it’s 190 hours of printing (24 hours a day, non-stop.)
              Then you need to add 20 minutes of cooling time between prints (the print bed has to cool down before you can remove the parts), set up time, the assumption that there will be not a single failed print job, assembly time, machine time, and that pesky electric bill.
              Y 1 Reply Last reply Reply Quote 2
              • K Offline
                KirAsh4 Moderator
                The above post on Arcus … it’s being printed. Some of the pieces, when printed all at once, take 30+ hours.
                In the mean time, this “rolled off of the assembly line” today:
                • cowboysdudeC Offline
                  I don’t have pictures but have been working on a PI radio for my car… I had to take the software and port it over from German to English… I did and a few other people are using it LOL Mine’s not ready yet…
                  Got a 3d printer to make some parts but I’m a contractor and working on this stuff in the summer is too hard… I’m too busy so it’s winter work… :)
                  • Y Offline
                    yawns Moderator @KirAsh4
                    @KirAsh4
                    so you designed, 3dprinted and built a one-hand-minirailgun driven by rubber bands? That’s crazy but awesome!
                    • K Offline
                      KirAsh4 Moderator @yawns
                      @yawns said in Besides your MagicMirror, what are some Maker-projects you worked/working on?:
                      @KirAsh4
                      No I have not. The design is by that person in the video, Matthew Davis. I’m simply printing and assembling it for myself. I did however (re)designed the laser cut vehicle, laser cut, and assembled the thing. It’s sitting on my living room table right now, awaiting some minor changes.
                      • L Offline
                        loribeeinca
                        I built a HomeKit garage door opener with sensor …
                        'Hey Siri, open the garage door"
                        K MichMichM 2 Replies Last reply Reply Quote 2
                        • K Offline
                          KirAsh4 Moderator @loribeeinca
                          @loribeeinca said in Besides your MagicMirror, what are some Maker-projects you worked/working on?:
                          Siri, “Sorry HAL, that is not your car. I will not open the garage door.”
                          L 1 Reply Last reply Reply Quote 2
                          • L Offline
                            loribeeinca @KirAsh4
                            @KirAsh4 said in Besides your MagicMirror, what are some Maker-projects you worked/working on?:
                            I was tempted to call it “Pod Bay Doors” in HAP
                            K 1 Reply Last reply Reply Quote 1
                            • K Offline
                              @loribeeinca, how about “force field” ?
                                McSorley @KirAsh4
                                @KirAsh4 Siri! Lower the force field!
                                  Well it would appear as though I’m also making a clock… yeah I said it… boring old clock LOL
                                  BUT I’m going to use an RPI Zero 1.3 and run a minimal run of MM2 on it using a 7" touchscreen… you know off/snooze thing ;)
                                  So I’ll keep you all informed… I just ordered a HubPiWi 1.3 :)
                                  • K Offline
                                    KirAsh4 Moderator @cowboysdude
                                    @cowboysdude said in Besides your MagicMirror, what are some Maker-projects you worked/working on?:
                                    Don’t expect Electron to run on that. It’s not compiled for that platform last I checked.
                                    • K Offline
                                      KirAsh4 Moderator @McSorley
                                      @McSorley said in Besides your MagicMirror, what are some Maker-projects you worked/working on?:
                                      Unfortunately, unless the garage door goes down, instead of up, telling Siri to ‘lower’ it doesn’t seem right.
                                      • MichMichM Offline
                                        MichMich @loribeeinca
                                        @loribeeinca Nice, which software did you use to connect your door to siri? Homebridge?
                                        • L Offline
                                          loribeeinca @MichMich
                                          @MichMich . hi, yes. it was the HAP-NodeJS stuff that I used.
                                            [[global:former-user]]
