    Fitbit
    129 Posts 42 Posters 226.0k Views 37 Watching
    • A
      Achilles
      @bhepler Thanks! That helped. I guess this means I can look forward to doing this every month or so?
      bheplerB 1 Reply Last reply
      • bheplerB
        bhepler Module Developer @Achilles
        @achilles - I don’t actually know. Mine was up for months with no issue. It may be that a prolonged period without the module refreshing the tokens is the determining factor. It may even be something on Fitbit’s end expired all of the tokens.
          mmille40
          This module looks great, unfortunately the installation is giving me the most difficulties from any module so far, I’m completely new to anything coding so I’m learning as I go. My first problem was trying to install the python-shell dependency. I get this message in my terminal:
          pi@matt:~ $ npm install python-shell
          npm WARN saveError ENOENT: no such file or directory, open ‘/home/pi/package.json’
          npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
          npm WARN pi No description
          npm WARN pi No repository field.
          npm WARN pi No README data
          npm WARN pi No license field.
          • python-shell@1.0.4
            updated 1 package in 2.932s
          What am I doing wrong here?
            dh1201
            See issue from mmille40 (above).
            I am running ‘npm install python-shell’ from within the MagicMirror/modules/MMM-fitbit folder and appear to be having the exact same issue [although the location of the file that cannot be found is reported differently to mmille40’s location] and am unable to discover the reason why. Does anyone have any ideas?
            npm WARN saveError ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
            npm WARN enoent ENOENT: no such file or directory, open ‘/home/pi/MagicMirror/modules/package.json’
            npm WARN modules No description
            npm WARN modules No repository field.
            npm WARN modules No README data
            npm WARN modules No license field.
              updated 1 package and audited 2 packages in 3.126s
              found 0 vulnerabilities
              sdetweil @dh1201
              @dh1201 this says u are in the MODULES folder, not MMM-Fitbit
                dh1201
                Should it be the modules directory then?
                Set up states:
                As with all modules, use git clone in the modules directory to download the module
                Goto fitbit to register a new app (sign in with your fitbit account)
                Give your app a catchy name and description
                Your personal website, organisation, and organisation website can be whatever you like
                Check browser and personal for OAuth settings
                Callback URL MUST BE http://127.0.0.1:8080/
                Give your app read & write permissions (read-only untested)
                Note your:
                “OAuth 2.0 Client ID” — (client_id)
                “Client (Consumer) Secret” — (client_secret)
                (You can access these again later via manage my apps at the same link as above)
                Navigate to MMM-fitbit in the modules directory
                Install dependancies using the listed commands
                  dh1201
                  Sorry @sdetweil - I misread your post.
                  The command is definitely being run from within the MMM-fitbit directory; but shows the errors previously posted.
                  • A
                    Achilles
                    This module usually stops working for me after a day or two, and I have to go through the setupAccess.py again to get it to work, and then it stops working again within 48 hours.
                    Am I doing something wrong?
                    • DeepThoughtD
                      DeepThought
                      Was there a resolution to the problems @dh1201 and @mmille40 were experiencing?
                      I am experiencing the same problem where when running the command, npm install python-shell, while in the MMM-fitbit directory, I receive the same error as @dh1201
                      npm WARN saveError ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json’
                      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/MagicMirror/modules/package.json’
                      When starting Magic Mirror, the Fitbit module displays no info and the cmd prompt states ‘TypeError: PythonShell.run is not a function’ and ‘TypeError: PythonShell is not a constructor’.
                      Does anyone know how to resolve this issue with python-shell? I’ve tried different versions and installing through different directories without any success. I’ve also tried clean installs of Magic Mirror but that doesn’t help either.
                      Is @Vendittelli still supporting this module?
                      • K
                        K-Pental
                        @deepthought said in Fitbit:
                        After some faffing with the config to get the MM to load I am also getting this same error message when MM now loads.
                        From what I can see it is pulling the auth tokens correctly and is also able to run the getData.ph as running this on its own returns my total lack of steps etc. But the figures are not updating on MM, I’m assuming this is because of the above error messages.
                        I was able to get past PythonShell.run is not a function by altering line 9 in the node_helper.js to be:
                        let {PythonShell} = require(‘python-shell’)
                        However doing this then gave other error messages relating to code in other files, kind of making me think that this was the wrong thing to do. I’m assuming I am missing something obvious.
                        Does anyone have any suggestions?
                        O 1 Reply Last reply
                          MMMveasy
                          hi everyone
                          i found a workaround
                          1. cd MagicMirror
                          2. mkdir Test
                          3. cd Test
                          4. npm install python-shell@0.5.0
                          5. copy python-shell from Test/node_modules folder to MagicMirror/node_modules
                          6. also copy package.json to node_modules folder of MM
                          • O
                            OttToyBoy @K-Pental
                            @k-pental said in Fitbit:
                            I’ve been struggling with this as well with no resolution. Pinging to see if anyone can provide some guidance.
                            Notes:
                            • brand new Raspian installation on pi 3, B+
                            • manual installation of Magic Mirror meticulously following instructions (note: the auto-install did not work due to issues with missing npm)
                            • installed MMM-Fitbit per instructions and have successfully executed getData.py and seen my correct fitbit data (i.e. all the registration and tokens have worked)
                            • trying to “npm install python-shell” from within the MMM-Fitbit directory has errors as previously described by other users
                            • doing “npm install python-shell” from the MagicMirror directory will succeed but I’ve no idea if this is where it should be done instead. After install, the following has been created: ~/MagicMirror/node_modules/python-shell
                            I’ve tried re-installing from scratch several times to make sure I’m following instructions closely but no luck. Any guru guidance would be appreciated!
                            Thanks, Peter.
                              sameer-t @MMMveasy
                              @MMMveasy said in Fitbit:
                              hi everyone
                              1. cd MagicMirror
                              2. mkdir Test
                              3. cd Test
                              This worked for me! Thank you!!
                              • StoffbeuteluweS
                                Stoffbeuteluwe Project Sponsor
                                Hi is the module still working ?.???.
                                • V
                                  voodew @bhepler
                                  @bhepler
                                  This post helped me the most.
                                  • Example config file on the module GitHub page contains errors. The character after config: should be {, not [
                                  • The secret key and appID field values need to be surrounded by single quotes, something not explained in the readme file.
                                  Thank you.
                                  • Arno-StrasbourgA
                                    Arno-Strasbourg
                                    Hi guys,
                                    I don’t know if the module is still maintained. But I have just implemented it. I have got the credentiels. I have put the code in the config.js file. It works fine but I have no datas refresh and an error in the log :
                                    0|mm | [2020-05-10 13:41:56.342] [ERROR] TypeError: PythonShell.run is not a function
                                    0|mm | at Class.setCreds (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:32:15)
                                    0|mm | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:18:9)
                                    0|mm | at Socket. (/home/pi/MagicMirror/js/node_helper.js:113:11)
                                    0|mm | at Socket.emit (events.js:200:13)
                                    0|mm | at /home/pi/MagicMirror/node_modules/socket.io/lib/socket.js:528:12
                                    0|mm | at processTicksAndRejections (internal/process/task_queues.js:82:9)
                                    0|mm | [2020-05-10 13:41:56.380] [ERROR] TypeError: PythonShell is not a constructor
                                    0|mm | at Class.getData (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:43:25)
                                    0|mm | at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-fitbit/node_helper.js:22:9)
                                    0|mm | [2020-05-10 13:43:43.317] [LOG]
                                    0|mm | Set credential request recieved.
                                    0|mm | [2020-05-10 13:43:43.318] [LOG]
                                    0|mm | {
                                    0|mm | client_id: '22BR8T',
                                    0|mm | client_secret: '51313d185cxxxxxxxxxxxxxxxxd141c99'
                                    0|mm | }
                                    0|mm | [2020-05-10 13:43:43.329] [LOG]
                                    0|mm | Whoops! There was an uncaught exception...
                                    0|mm | [2020-05-10 13:43:43.330] [ERROR] TypeError: PythonShell.run is not a function
                                    0|mm | [2020-05-10 13:43:43.334] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    0|mm | [2020-05-10 13:43:43.335] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    0|mm | [2020-05-10 13:43:43.336] [LOG] Initial run request recieved.
                                    0|mm | [2020-05-10 13:43:43.338] [LOG] Running getData.py
                                    0|mm | [2020-05-10 13:43:43.339] [LOG] Whoops! There was an uncaught exception...
                                    0|mm | [2020-05-10 13:43:43.342] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    0|mm | [2020-05-10 13:43:43.342] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    0|mm | [2020-05-10 13:43:43.344] [LOG] [NewPIR] Initialize...
                                    0|mm | [2020-05-10 13:43:43.340] [ERROR] TypeError: PythonShell is not a constructor
                                    Do someone has any idea of that error ?
                                    StoffbeuteluweS 1 Reply Last reply
                                    • StoffbeuteluweS
                                      Stoffbeuteluwe Project Sponsor @Arno-Strasbourg
                                      @Arno-Strasbourg Hey, please install MMM-Fitbit2 that works perfect.:thumbs_up_medium-light_skin_tone:
                                      • Arno-StrasbourgA
                                        Arno-Strasbourg
                                        Oh ! There is an other app !! Where can I found it ? It isn’t on the gitub third party modules ?
                                        Edit : Got it ! Thank you @Stoffbeuteluwe
                                        • StoffbeuteluweS
                                          @Arno-Strasbourg https://github.com/m-roberts/MMM-Fitbit2
                                          • Arno-StrasbourgA
                                            Arno-Strasbourg
                                            Yes I confirm, it works very well !! Thank you very much !!
                                            Just a small question, I put it on the bottom_bar, but it appear on the bottom left.
                                            How can i center it please ? with the MMM-Fitbit2.css or custom.css ? and wich command to add ?
                                            That makes 2 questions in fact ! :face_with_hand_over_mouth:
                                            • 6 / 7
