    [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer
    160 Posts 6 Posters 229.9k Views 6 Watching
    • evroomE
      evroom
      @axled said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
      Now the module should work with dreambox, no matter if the dreambox uses a separat port or not.
      I can confirm that with or without port, streaming works.
      MagicMirror version: 2.37.0
      • A
        AxLed Module Developer @evroom
        @evroom said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
        Error: null in http://192.168.178.47/web/about
        I checked with some of the files you send me (all different 3 VU+ about xmls), the work in my environment. Is your VU+ maybe also in standby mode?
        AxLED
        • evroomE
          evroom
          Can you please try with your receivers (Dreambox or VU) on?
          VU+ Solo2:
          When on /web/about shows the service name.
          When in standby it shows no service name.
          Dreambox dm7020hd:
          So, the same.
          When I use the Dreambox for the module, there are NO errors.
          The service list is shown.
          When I use the VU+ for the module, there are errors.
          The service list is NOT shown.
          The errors are different when in standby (/web/about) and when on (/web/epgnow).
          Could you please also print the errors in the pm2 log ?
          Now on the Mirror I see Error for 30 seconds and then Error: for 2 seconds.
          • evroomE
            evroom
            Btw,
            VU+ Solo2:
            http://192.168.178.46/web/epgnow?bRef=1%3A7%3A1%3A0%3A0%3A0%3A0%3A0%3A0%3A0%3AFROM BOUQUET "userbouquet.favourites.tv" ORDER BY bouquet
            Works. Both when on or in soft-standby.
            • evroomE
              evroom
              I never tried my module in dreambox standby, as i dont use it. My dreambox is on or in deep standby.
              When in deep standby I would expect that you will see
              < e2servicename >< /e2servicename >
              for /web/about.
              And as you do not see an error, I fail to see the difference with the VU+ in soft-standby.
              But in deep standby, you cannot stream, can you ?
              Will the playable services then be none ?
              Cannot test this now without being killed by the family :-)
              A 1 Reply Last reply
              • A
                @evroom said in [MMM-Dreambox]:
                @evroom
                Welcome to my world :-)
                I have another idea:
                Did you check/compare the settings on your tuners (dreambox vs. VU+).
                I case of my dreambox (DM800SE) they are under:
                • Erweiterungen -> Webinterface
                • Extensions -> Webinterface (maybe the spelling is different, as i translated them into english)
                This is a screenshot of my actual setting (i only played around with the HTTP Port to fix some earlier bugs):
                AxLED
                • evroomE
                  evroom
                  For VU+ Solo2:
                  Port is 80 and HTTP authentication on yes.
                  Will set HTTP authentication to no and try again.
                  I see now, there is also a separate OpenWebif config:
                  This uses port 81 and indeed works.
                  Looks totally different from the Webif.
                  Interesting.
                  For the Dreambox I cannot find a menu item like this.
                  I still use the original Dreambox OE2.0 image.
                  • evroomE
                    evroom
                    Excellent idea on a Sunday !!!
                    Changed Enable HTTP Authentication to no and see, it works !!!
                    The services list is shown and streaming works.
                    The same issues occur though for the dual tuner VU+:
                    After the first DB-PLAY all is well, but then DB-STOP, DB-SERVICE-NEXT and DB-PLAY causes 2 streams.
                    Will try now on the single tuner VU+.
                    Perhaps you try setting it to yes for the Dreambox and see what happens ?
                    If the same errors appear then it is confirmed.
                    • A
                      @evroom
                      I will try the authentication thing if i find some time, maybe i can catch the error and handle it, so the module user know what to do.
                      AxLED
                      • evroomE
                        evroom
                        VU+ zero (1 tuner):
                        $ pm2 restart mm
                        DB-SERVICE-NEXT
                        $ ps -eaf | grep omxplayer | grep -v grep
                        DB-PLAY
                        pi@MagicPi:~/MagicMirror/modules/MMM-Dreambox $ ps -eaf | grep omxplayer | grep -v grep
                        pi       14356 13842  0 12:52 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:1:2F08:441:1:C00000:0:0:0:
                        pi       14357 14356  1 12:52 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:1:2F08:441:1:C00000:0:0:0:
                        pi       14380 14357  0 12:52 ?        00:00:00 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:1:2F08:441:1:C00000:0:0:0:
                        DB-PLAY
                        pi       14357 14356  0 12:52 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:1:2F08:441:1:C00000:0:0:0:
                        pi       14380 14357  9 12:52 ?        00:00:01 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:1:2F08:441:1:C00000:0:0:0:
                        pi       14394 13842  0 12:52 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:1:2F08:441:1:C00000:0:0:0:
                        pi       14395 14394  0 12:52 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:1:2F08:441:1:C00000:0:0:0:
                        pi       14421 14395 18 12:52 ?        00:00:00 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:1:2F08:441:1:C00000:0:0:0:
                        DB-PLAY
                        pi       14380 14357 10 12:52 ?        00:00:03 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:1:2F08:441:1:C00000:0:0:0:
                        pi       14421 14395  9 12:52 ?        00:00:01 /usr/bin/omxplayer.bin --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:1:2F08:441:1:C00000:0:0:0:
                        pi       14435 13842  1 12:53 ?        00:00:00 /bin/sh -c omxplayer  --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:1:2F08:441:1:C00000:0:0:0:
                        pi       14436 14435  0 12:53 ?        00:00:00 /bin/bash /usr/bin/omxplayer --vol -6000 --win 0,625,590,957 --live http://192.168.178.47:8001/1:0:1:2F08:441:1:C00000:0:0:0:
                        Conclusion:
                        When you do DB-PLAY it streams one service.
                        Then a next DB-PLAY will stream another service, so 2 in total.
                        Next DB-PLAY, next stream, etc.
                        When you stream 2 times the same service and the power of your MM device is enough (I have a Pi 3 Model B), you will not notice it.
                        With 3 streams you will see artefacts.
                        When you do DB-SERVICE-NEXT, DB-PLAY, DB-SERVICE-NEXT, DB-PLAY you will have 2 different services streaming.
                        Then you will see 2 streams overlapping and you will see that 2 streams are running in parallel.
                        • evroomE
                          evroom
                          Final thoughts for today.
                          New commands:
                          Select the next service and play:
                          DB-SERVICENEXTANDPLAY
                          Stop the current stream and start a new stream (handy after a DB-SERVICE-NEXT):
                          DB-STOPANDPLAY
                          Stop the current stream, select the next service and start a new stream (allows zapping):
                          DB-STOPANDSERVICENEXTANDPLAY
                          Or when DB-PLAY, stop a possible current stream and then start a stream.
                          • A
                            @evroom
                            I did some further bugfixing:
                            • added catching of error 401 unauthorized (this is when in enigma2 receiver webinterface setting Enable HTTP Authentication is set to yes)
                            • added a stop of omxplayer before starting a new stream, so streaming of more than one unwanted streams should now work
                            • added readme with some enigma2 receiver requirements (Enable HTTP Authentication and powerstate)
                            Please check the dev branch of my module:
                            Rename your MMM-Dreambox folder to _MMM-Dreambox (for example)
                            do a git clone --branch dev https://github.com/Ax-LED/MMM-Dreambox.git in your modules folder
                            • more informations on wrong enigma2 receiver settings
                            • the streaming of multiple channels should be fixed
                            Regards
                            AxLED
                            Cr4z33C 1 Reply Last reply
                            • Cr4z33C
                              Cr4z33 @AxLed
                              @axled did everything suggested on my Vu+ Duo2, but I keep getting no streams.
                              When I do that DB-PLAY thing I get now a gray square containing the channels list exactly like what happened to @evroom .
                              • A
                                @Cr4z33
                                Can you please describe it a little more detailed.
                                So i guess the module loads and shows you the following information:
                                • your VU+ Model
                                • the name of the favorites list (you entered in config.js) an number channels in that list
                                • the channel list, limited to the number you entered in config.js
                                Can you please comment or confirm the points mentioned above?
                                If the module load, you have to:
                                1. select a channel (DB-SERVICE-NEXT or DB-SERVICE-PREV), otherwise the module doesnt know which channel should be streamed.
                                2. choose DB-PLAY the start streaming the selected channel.
                                Screenshots:
                                Module loaded:
                                Select a channel:
                                DB-PLAY send (unfortunatelly i can show omxplayer on my dev machine):
                                AxLED
                                • evroomE
                                  evroom
                                  @AxLed
                                  I have successfully tested you latest changes.
                                  Everything work very well.
                                  Thanks for taking the time and quick responses.
                                  I have requested 2 new features via GitHub:
                                  [Feature Request] - make zapping possible by using DB-ZAP
                                  [Feature Request] - get sRef and bRef information from getservices
                                  • evroomE
                                    evroom
                                    @cr4z33 said in [MMM-Dreambox] to connect a Dreambox or a Enigma2 Receiver (like VU or VU+) to MagicMirror and stream stations via omxplayer:
                                    That is because @evroom thought that the first service would be selected and streamed with DB-PLAY.
                                    Like @AxLed said, you need to use DB-SERVICE-NEXT first (as many times as needed to select the service to stream and then DB-PLAY to start the stream.
                                    • Cr4z33C
                                      Cr4z33
                                      @AxLed perhaps I was doing things wrongly, but even by doing them right the stream won’t start.
                                      Long story:
                                      I first run (succesfully) http://vuplusip:8080/remote?action=NOTIFICATION&notification=DB-SERVICE-NEXT and I see a channel gets selected in the list by being displayed into a gray rectangle.
                                      I then run (succesfully) http://vuplusip:8080/remote?action=NOTIFICATION&notification=DB-PLAY and I see a white PLAY triangle near the channel I selected before, but after let’s say 5-6 seconds the symbol goes away and nothing happens.
                                      I repeat I am using no authentication indeed, but I am using a different WebIf port.
                                      Maybe this can be helpfull for you?
                                      • evroomE
                                        evroom
                                        @Cr4z33
                                        Just to be sure, did you do:
                                        $ cd ~/MagicMirror/modules/MMM-Dreambox
                                        $ git pull
                                        $ git status
                                        On branch dev
                                        Your branch is up-to-date with 'origin/dev'.
                                        nothing to commit, working tree clean
                                        Restart MM when there was something new pulled.
                                        And the correct path for the notifications is:
                                        http://{MagicMirror_IP}:8080/
                                        Not your VU+ IP.
                                        And port 8080.
                                        After DB-PLAY do on the MM (pretty fast after DB-PLAY):
                                        to be sure really nothing is streaming.
                                        Streaming uses port 8001 so I am pretty sure that your port from apiBase has nothing to do with it.
                                        It is only used to get the services list (which you apparently see on your Mirror).
                                        And btw, my omxargs is:
                                        omxargs: ' --vol -6000 --win 0,625,590,957 --live ',
                                        Do not know if this makes a difference.
                                        And you can stream from the command line, right?
                                        $ omxplayer --vol -6000 --win "0 0 480 320" --live http://192.168.178.28:8001/1:0:1:38F1:2648:FBFF:820000:0:0:0:
                                        • A
                                          @Cr4z33
                                          @evroom
                                          I did some further bugfixing / adding usability:
                                          • catching error if you want to DB-PLAY before selecting a channel: MM shows notification that no channel is selected
                                          • catching error if you want to DB-STOP before streaming: exiting css formating
                                          • selected channel will stay selected, even if refresh intervall get new datas from receiver
                                          • play symbol will stay selected, only DB-STOP and selection of new channel removes it
                                          Now the module should work a little bit smoother and shows the user some information if some of the functions a used in the wrong order.
                                          Regards
                                          AxLED
                                          • Cr4z33C
                                            Cr4z33 @evroom
                                            @evroom I confirm that everything you wrote is what I am getting (succesfully) BUT the ps part which gives no output after I enter the command.
                                            @AxLed I ran the update and now I get continuous PLAY without interruption, but there’s still no video output on screen.
                                            • 6 / 8
