Help with CSS not showing changes on MMM-CalendarExt2
Scheduled Pinned Locked Moved Solved Development
11 Posts 5 Posters 3.8k Views 5 Watching
  • 4 Offline
    44mc44
    This is my first pi project and most of it is working well, but I’m struggling to figure out how to make my custom.css file to show the changes on the MM. I created a className of “personal” in the config.js and am trying to change the appearance in custom.css. I’m simply trying to make the personal calendar items look different than the others. I’ve read the wiki and searched for examples in the forum, but I’m at a loss. Appreciate anyone that can help point me in the right direction.
    Here is custom.css. I don’t really understand what the .CX2 is but I saw it on several related posts so I tried it. I also tried without it, but no luck either way. It seems like it’s just not applying anything in this file so I’m hoping it’s just something basic that I’m missing.
    custom.css
     body {
    	.CX2 .event .personal {
      	color:#ffffff;
      	background-color:#000000;
    	.CX2 .event .personal .fullday {
      	color:#000000;
    	background-color:#FFA500;
    Config.js
    var config = {
    	port: 8080,
    	ipWhitelist: [], // Set [] to allow all IP addresses
    	language: "en",
    	timeFormat: 12,
    	units: "imperial",
      module: 'MMM-CalendarExt2',
        calendars : [
    	url: "https://calendar.google.com/calendar/ical/***********************/basic.ics",
    	icon: "noto-ice-hockey",
    	className: "personal",
    	scanInterval: 5*60*1000,
    	name: "Ducks Schedule",
            url: "http://ducks.ice.nhl.com/schedule/full.ics",
    	name: "Sharks Schedule",
    	url: "http://sharks.ice.nhl.com/schedule/full.ics",
    	classname: "sharks",
        views: [
            mode: "daily",
       	mode: "month",
        	position: "fullscreen_below",
        	calendars: [],
        scenes: [
    ? S 2 Replies Last reply Feb 8, 2019, 8:45 PM Reply Quote 0
      A Former User
      @44mc44
      No space between ‘personal’ and ‘fullday’
      And don’t put in ‘body{}’
        A Former User @44mc44
        @44mc44
        try this.
        .CX2 .personal {
        .CX2 .personal.fullday {
        • 4 Offline
          44mc44
          Made the following changes but no luck. After I save the file, I run pm2 restart mm correct? I can see the screen refresh with any changes. Just making sure I’m not missing a step.
           body {
          	.CX2 .personal {
            	color:#ffffff;
          	.CX2 .personal .fullday {
            	color:#000000;
            A Former User
            @44mc44
            • 4 Offline
              44mc44
              Just had another thought. There is only one custom.css file correct? The file I am using was existing and is in MagicMirror/css . Just making sure I’m not supposed to be creating a new custom.css file in the MMM-CalendarExt2 module folder instead.
              M 1 Reply Last reply Feb 8, 2019, 11:55 PM Reply Quote 0
              • 4 Offline
                44mc44
                Success!
                removing ‘body{}’ took care of it.
                Appreciate the help!
                  Mykle1 Project Sponsor Module Developer @44mc44
                  @44mc44 said in Help with CSS not showing changes on MMM-CalendarExt2:
                  That is correct. It might not be a bad idea to make a backup as you add to it. You never know. :-)
                  • 4 Offline
                    44mc44
                    Definitely will do. :thumbs_up:
                      Seann Module Developer @44mc44
                      @44mc44 Just a suggestion, but you may want to do some research on css using w3 schools or something. The way you attempted to create your css would only work using scss. In standard css you can’t nest the declaration of styles inside of each other. (Not sure how to word it, although i’m pretty certain declaration of styles is wrong.)
                      4 1 Reply Last reply Feb 9, 2019, 1:14 AM Reply Quote 0
                      • 4 Offline
                        44mc44 @Seann
                        @seann Will check it out. Thanks! This is all really new to me. I read through the CSS 101 in this forum, but I could definitely use more help.
