MMM-EyeCandy shown when USER_PRESENCE
8 Posts 3 Posters 2.1k Views 3 Watching
  • T Offline
    thedk
    Searching for a while, how i can hide modules when PIR doesnt detect movement. So i used the voice control part from EyeCandy modul.
    I’m new in MagicMirror, is it correct like this:
    notificationReceived: function(notification, payload) {
            if (payload === false) {
                this.hide();
            } else if (notification === 'USER_PRESENCE') {
                this.show(2000);
    this.show means how long the eyecandy is shown?
    M 1 Reply Last reply Feb 15, 2019, 1:02 AM Reply Quote 0
      Mykle1 Project Sponsor Module Developer @thedk
      @thedk said in MMM-EyeCandy shown when USER_PRESENCE:
      this.show(2000); means the transition from hidden to shown is 2000ms, or 2 seconds…
      Now, in order to hide all modules “when the PIR doesn’t detect any movement”, you could try something like this within the PIR module
                    MM.getModules().enumerate((module) => {
                                 module.hide(2000);
                                 module.show(2000);
      Something like that.
      • T Offline
        thedk
        Thanks for that.
        To hide all modules i an other problem. I have a discussion about that, when the screen goes off to save energy.
        I wanr to use this code just for eyecandy an maybe newsfeed cause of the high Temperatur of the Pi when its always running.
        • T Offline
          thedk
          Is it possible to add a duration how long the eyecandy is shown?
          Rest works fine.
          M 1 Reply Last reply Feb 16, 2019, 3:22 PM Reply Quote 0
            I’ll take a look at it when I get a chance. In the meantime, you could use something like this https://github.com/ianperrin/MMM-ModuleScheduler to accomplish that. Or, there are a few voice modules that can hide or show modules upon command.
            • T Offline
              thedk
              With the Sheduler it wouldnt work, i guess.
              I just want to show the eyecandy when PIR detects movement for some seconds. Maybe it isnt that complicated and just a little command?
              • E Offline
                ejay-ibm Project Sponsor Module Developer
                Hi all,
                I’m looking for something similar than the main thread request.
                I need to switch between 2 gif images on notification sent by other module.
                Eg : On notification 1 , diplay gif one , on notification 2 display Gif 2 .
                I can’t find how to achieve this…
                @Mykle1 Do you still make developement on this module ? If yes would it be possible to implement some notification consideration in your module to handle multiple custom images ?
                Thank you !
                Ejay
                M 1 Reply Last reply Feb 28, 2019, 12:57 PM Reply Quote 0
                  Mykle1 Project Sponsor Module Developer @ejay-ibm
                  @ejay-ibm
                  That is really not the purpose of this module. It was designed to simply show animations. Perhaps one of the image modules would be better suited to your needs. I will look into this when I am not so busy.
