MMM-EyeCandy shown when USER_PRESENCE
8 Posts 3 Posters 2.1k Views 3 Watching
    Mykle1 Project Sponsor Module Developer @thedk
    @thedk said in MMM-EyeCandy shown when USER_PRESENCE:
    this.show means how long the eyecandy is shown?
    this.show(2000); means the transition from hidden to shown is 2000ms, or 2 seconds…
    Now, in order to hide all modules “when the PIR doesn’t detect any movement”, you could try something like this within the PIR module
    notificationReceived: function(notification, payload) {
            if (payload === false) {
                  MM.getModules().enumerate((module) => {
                               module.hide(2000);
            } else if (notification === 'USER_PRESENCE') {
                               module.show(2000);
    Something like that.
    • T Offline
      thedk
      Thanks for that.
      To hide all modules i an other problem. I have a discussion about that, when the screen goes off to save energy.
      I wanr to use this code just for eyecandy an maybe newsfeed cause of the high Temperatur of the Pi when its always running.
      • T Offline
        thedk
        Is it possible to add a duration how long the eyecandy is shown?
        Rest works fine.
        M 1 Reply Last reply Feb 16, 2019, 3:22 PM Reply Quote 0
          I’ll take a look at it when I get a chance. In the meantime, you could use something like this https://github.com/ianperrin/MMM-ModuleScheduler to accomplish that. Or, there are a few voice modules that can hide or show modules upon command.
          • T Offline
            thedk
            With the Sheduler it wouldnt work, i guess.
            I just want to show the eyecandy when PIR detects movement for some seconds. Maybe it isnt that complicated and just a little command?
            • E Offline
              ejay-ibm Project Sponsor Module Developer
              Hi all,
              I’m looking for something similar than the main thread request.
              I need to switch between 2 gif images on notification sent by other module.
              Eg : On notification 1 , diplay gif one , on notification 2 display Gif 2 .
              I can’t find how to achieve this…
              @Mykle1 Do you still make developement on this module ? If yes would it be possible to implement some notification consideration in your module to handle multiple custom images ?
              Thank you !
              Ejay
              M 1 Reply Last reply Feb 28, 2019, 12:57 PM Reply Quote 0
                Mykle1 Project Sponsor Module Developer @ejay-ibm
                @ejay-ibm
                That is really not the purpose of this module. It was designed to simply show animations. Perhaps one of the image modules would be better suited to your needs. I will look into this when I am not so busy.
