    MMM-EyeCandy shown when USER_PRESENCE
    8 Posts 3 Posters 2.9k Views 3 Watching
    • T
      thedk
      Searching for a while, how i can hide modules when PIR doesnt detect movement. So i used the voice control part from EyeCandy modul.
      I’m new in MagicMirror, is it correct like this:
      notificationReceived: function(notification, payload) {
              if (payload === false) {
                  this.hide();
              } else if (notification === 'USER_PRESENCE') {
                  this.show(2000);
      this.show means how long the eyecandy is shown?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @thedk
        @thedk said in MMM-EyeCandy shown when USER_PRESENCE:
        this.show(2000); means the transition from hidden to shown is 2000ms, or 2 seconds…
        Now, in order to hide all modules “when the PIR doesn’t detect any movement”, you could try something like this within the PIR module
                      MM.getModules().enumerate((module) => {
                                   module.hide(2000);
                                   module.show(2000);
        Something like that.
        • T
          thedk
          Thanks for that.
          To hide all modules i an other problem. I have a discussion about that, when the screen goes off to save energy.
          I wanr to use this code just for eyecandy an maybe newsfeed cause of the high Temperatur of the Pi when its always running.
          • T
            thedk
            Is it possible to add a duration how long the eyecandy is shown?
            Rest works fine.
            • Mykle1M
              I’ll take a look at it when I get a chance. In the meantime, you could use something like this https://github.com/ianperrin/MMM-ModuleScheduler to accomplish that. Or, there are a few voice modules that can hide or show modules upon command.
              • T
                thedk
                With the Sheduler it wouldnt work, i guess.
                I just want to show the eyecandy when PIR detects movement for some seconds. Maybe it isnt that complicated and just a little command?
                • ejay-ibmE
                  ejay-ibm Project Sponsor Module Developer
                  Hi all,
                  I’m looking for something similar than the main thread request.
                  I need to switch between 2 gif images on notification sent by other module.
                  Eg : On notification 1 , diplay gif one , on notification 2 display Gif 2 .
                  I can’t find how to achieve this…
                  @Mykle1 Do you still make developement on this module ? If yes would it be possible to implement some notification consideration in your module to handle multiple custom images ?
                  Thank you !
                  Ejay
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @ejay-ibm
                    @ejay-ibm
                    That is really not the purpose of this module. It was designed to simply show animations. Perhaps one of the image modules would be better suited to your needs. I will look into this when I am not so busy.
