    MM Error - .AppleDouble and UnhandledPromiseRejectionWarning
    34 Posts 4 Posters 17.6k Views 3 Watching
      robiv8
      You will have had your files on the OS X computer, then OS X automatically makes these .AppleDouble files.
      Search your Magic Mirror completely for these files and delete them.
      These can be safely deleted.
        bolish
        @Mykle1 @lavolp3 @robiv8
        .appledouble : found the rootcause!!
        I believe it’s because I mounted my raspberry Pi as a share on my MacBook.
        By making “all hidden files visible” on the Pi, I noticed that ALL (literally ALL) folders on the Pi where showing an .appledouble folder with a lot of files inside…
        By removing the .appledouble folder which was into the /MagicMirror/Modules one…this error message stopped.
        I’m convinced this .appledouble folder will be created again later my the MacOs…Nevertheless, I’m now sure that this error message was not causing any trouble in the end…So everything fine.
        Anyway, thanks for support!!
          bolish
          @lavolp3
          Here is the list of the modules I’m using :
          It’s a lot…So it seems difficult to identify the one causing the issue, don’t you think so? Maybe you know an analysis method that could help?
          Do you think that by “disabled : true” then one by one, it could work to identify which one is causing the issue?
          Regards
          • lavolp3L Offline
            lavolp3 Module Developer @bolish
            @bolish Well at first I would rule out:
            MMM-Wunderlist
            MMM-remote-control
            MMM-SystemStats
            calendar_monthly
            all in default
            I have these as well and not the message you’re finding.
            What you could try out:
            There is a module MMM-Logging by @shbatm giving the logging output more detail. It’s easy to install and you don’t need to configure anything.
            That module could be able to show where the unhandled promise reection is sitting.
            How to troubleshoot modules
            MMM-soccer v2, MMM-AVStock
              bolish
              @lavolp3
              OK I will give it a try this weekend and check the logs.
              Disabling them on by one (through the config.js) will not help?
              • lavolp3L Offline
                @bolish It will but it’s more work :-) That would be my next approach
                  bolish
                  @lavolp3
                  Done…I can indeed see strange things…
                  2019-02-15T22:45:59 <log> Launching application. (/home/pi/MagicMirror/js/electron.js:82 App.<anonymous>)
                  2019-02-15T22:45:59 <error> ERROR! Could not find main module js file for .AppleDouble (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:258 Class.loadModuleDefaultConfig)
                  2019-02-15T22:46:03 <error> (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  2019-02-15T22:46:03 <error> (node:6793) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  2019-02-15T22:46:03 <error> (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  2019-02-15T22:46:03 <error> (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  2019-02-15T22:46:03 <error> (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  2019-02-15T22:46:04 <error> (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                  2019-02-15T22:46:08 <info> MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                  What do you think?
                  Regards
                  • lavolp3L Offline
                    @bolish
                    OK that didn’t help.
                    MMM-Logging at least gave us the file putting the error out but not file from which it originated.
                    But isn’t Linux a beautiful wild monsterous creature?
                    Try this command
                    find . -maxdepth 2 -exec grep -nwl  Promise 2>/dev/null {} +
                    in the MagicMirror directory.
                    “find” looks for all files in the 3rd party module directories (all files with depth of 2 directories maximum, we don’t want to have all the numerous node module files included), then it executes (“-exec”) a grep function searching the files for the “Promise” function.
                    “2>/dev/null” is there to put all error output (there’s a lot) away from the standard output
                    This will give you all 3rd party module files including the promise function. Then we can limit it to a few modules.
                    With these you can do the “deactivate and look for errors” workflow and find out the one responsible
                      bolish
                      @lavolp3
                      this is the result I have :
                      ./js/main.js
                      ./js/module.js
                      ./clientonly/index.js
                      Seems to be linked to the core system itself only and not to any particular module?
                      I’ve already made a git pull for MM itself but it’s already up to date.
                      • lavolp3L Offline
                        @bolish Sorry my bad. You need to do it in the modules folder. Then maxdepth 2 leads to the folder itself and all 3rd party folders.
                        Sorry again!
                          bolish
                          @lavolp3
                          !!! it’s not your fault, it’s shame on me!!!
                          Anyway, I just did it…Result is zero…Nothing…
                          pi@MagicPi:~/MagicMirror/modules $ find . -maxdepth 2 -exec grep -nwl  Promise 2>/dev/null {} +
                          So…disable them one by one is the next analysis step??
                          • lavolp3L Offline
                            @bolish First, try another one
                            find . -maxdepth 2 -exec grep -nwl  .then 2>/dev/null {} +
                            Promises are not always processed by a Promise function, but I also by calling something and then calling .then().
                            Actually I know these bastards for two or three days now, so I’m far from being an expert
                              bolish
                              @lavolp3
                              thx
                              Here is the result
                              pi@MagicPi:~/MagicMirror/modules $ find . -maxdepth 2 -exec grep -nwl  .then 2>/dev/null {} +
                              ./MMM-Remote-Control/node_helper.js
                              ./MMM-Remote-Control/installer.sh
                              ./MMM-BackgroundSlideshowInfo/README.md
                              ./MMM-NotificationTrigger/README.md
                              So… Remote Control I believe…
                              I will try to disable it and see what happens.
                                bolish
                                I confirm…
                                No error message anymore after disabling MMM-RemoteControl.
                                Wao…and now?? Do you have a clue about next step or should I raise an issue into MMM-ControlRemote git?
                                • lavolp3L Offline
                                  @bolish That’s odd. Something doesn’t add up, sorry. I think a “then” is searched as well. But try these modules.
                                  If not successfull you’d need to go with disabling one module after another
                                  • lavolp3L Offline
                                    @bolish Well, great!! BUt oddly, I dont have this… and I have the module as well.
                                    Do you have Jopyth’s original version installed? Or a fork?
                                      bolish
                                      @lavolp3
                                      I have the original version from Jopyth.
                                      S***, I hoped it would have been easier to figure out!!
                                      I just Git Pulled… Was already up to date
                                      • lavolp3L Offline
                                        @bolish OK I can confirm your errors. Had it disabled. By enabling the unhaldled promises come up.
                                        Raise an issue. I’ll have a look at the code
                                          bolish
                                          Don’t you think it can be linked to the .appledouble thing. Remember that :
                                          2019-02-15T22:45:59  Launching application. (/home/pi/MagicMirror/js/electron.js:82 App.)
                                          2019-02-15T22:45:59  ERROR! Could not find main module js file for .AppleDouble (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:258 Class.loadModuleDefaultConfig)
                                          2019-02-15T22:46:03  (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 1): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                                          2019-02-15T22:46:03  (node:6793) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code. (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                                          2019-02-15T22:46:03  (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 2): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                                          2019-02-15T22:46:03  (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 3): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                                          2019-02-15T22:46:03  (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 4): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                                          2019-02-15T22:46:04  (node:6793) UnhandledPromiseRejectionWarning: Unhandled promise rejection (rejection id: 5): TypeError: Cannot read property 'refs' of undefined (/home/pi/MagicMirror/internal/process/warning.js:18 writeOut)
                                          2019-02-15T22:46:08  MMM-Logging updated config received, reloading console (/home/pi/MagicMirror/modules/MMM-Logging/node_helper.js:30 Class.socketNotificationReceived)
                                          Because the .appledouble error is refering to Remote Control also.
                                          So…you just have the same issue now but never noticed it before?
                                          lavolp3L 2 Replies Last reply Reply Quote 0
                                          • lavolp3L Offline
                                            @bolish No.
                                            Unhandled promise rejections are code stuff that can be overcome quite easily.
                                            Think of it like this.
                                            You ask your program to do something outside (e.g. request data from somewhere else.
                                            When it doesn’t work the “promise” of delivering something is rejected.
                                            When this rejection is unhandled (the program isnt told what to do) you get this error
