    Config file
    13 Posts 6 Posters 6.6k Views 5 Watching
      sdetweil @sanaa1369
      @sanaa1369 the instructions say to copy the sample to config.js
      • cowboysdudeC Offline
        If you’re using a PI [or anyother Linux variant] then go to command prompt and change directory to MagicMirror/config
        and do this:
        cp config.js.sample config.js
        If you’re using windows well that’s simple enough:
        Open up file browser right click, copy and paste the copy and then rename it to config.js
          @sanaa1369 said in Config file:
          how do you create a config file when i run npm start it says the file is missing and i need to create one
          https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
            sanaa1369 @sdetweil
            @sdetweil thank’s but i am new to this i know how to copy but were to paste.
              sanaa1369 @Mykle1
              @cowboysdude thank"s for trying to help me but it can find the file to copy it
                The instructions say
                Copy /home/pi/MagicMirror/config/config.js.sample to /home/pi/MagicMirror/config/config.js.
                  sanaa1369 @Mykle1
                  @mykle1 Thank’s for trying to help me i am new to this but i must have made a mistake now when i put in npm start it give me the same message and then lock the screen and i have to reboot
                  Mykle1M bheplerB 3 Replies Last reply Reply Quote 0
                    Mykle1 Project Sponsor Module Developer @sanaa1369
                    @sanaa1369
                    It’s hard to know what’s going on there by your descriptions. However, when you were getting the error “the file is missing and i need to create one” your MM was working EXCEPT for the config.js needing to be created. In your config folder, there should be a file named config.js.sample. This file should not be edited. You have to copy this file and paste it in the same folder, renaming it to config.js. You now should have config.js.sample file and the config.js file in the same folder (the config folder of MagicMirror). Unless you’ve made some other changes this will allow the mirror to run.
                    • bheplerB Offline
                      bhepler Module Developer @sanaa1369
                      @sanaa1369 - The screen isn’t really locked, it’s just displaying the MagicMirror application in full screen. If you hit Alt+Q it should give you your command prompt back.
                        @sanaa1369
                        Some other very useful key commands for MagicMirror
                        https://forum.magicmirror.builders/topic/5619/how-to-find-and-use-key-commands-in-mm-for-absolute-beginners
