    Config file
    13 Posts 6 Posters 6.8k Views 5 Watching
      sanaa1369 @Mykle1
      @cowboysdude thank"s for trying to help me but it can find the file to copy it
        The instructions say
        Copy /home/pi/MagicMirror/config/config.js.sample to /home/pi/MagicMirror/config/config.js.
          sanaa1369 @Mykle1
          @mykle1 Thank’s for trying to help me i am new to this but i must have made a mistake now when i put in npm start it give me the same message and then lock the screen and i have to reboot
          Mykle1M bheplerB 3 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @sanaa1369
            @sanaa1369
            It’s hard to know what’s going on there by your descriptions. However, when you were getting the error “the file is missing and i need to create one” your MM was working EXCEPT for the config.js needing to be created. In your config folder, there should be a file named config.js.sample. This file should not be edited. You have to copy this file and paste it in the same folder, renaming it to config.js. You now should have config.js.sample file and the config.js file in the same folder (the config folder of MagicMirror). Unless you’ve made some other changes this will allow the mirror to run.
            • bheplerB Offline
              bhepler Module Developer @sanaa1369
              @sanaa1369 - The screen isn’t really locked, it’s just displaying the MagicMirror application in full screen. If you hit Alt+Q it should give you your command prompt back.
                @sanaa1369
                Some other very useful key commands for MagicMirror
                https://forum.magicmirror.builders/topic/5619/how-to-find-and-use-key-commands-in-mm-for-absolute-beginners
                • F Offline
                  fulmik Project Sponsor
                  That’s a link that will be saved for later use. Thanks
                    sanaa1369 @Mykle1
                    @mykle1 thank’s a lot i appreciate it
