    Config file
    13 Posts 6 Posters 7.4k Views 5 Watching
      @sanaa1369 said in Config file:
      how do you create a config file when i run npm start it says the file is missing and i need to create one
      https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
        sanaa1369 @sdetweil
        @sdetweil thank’s but i am new to this i know how to copy but were to paste.
          sanaa1369 @Mykle1
          @cowboysdude thank"s for trying to help me but it can find the file to copy it
            The instructions say
            Copy /home/pi/MagicMirror/config/config.js.sample to /home/pi/MagicMirror/config/config.js.
              sanaa1369 @Mykle1
              @mykle1 Thank’s for trying to help me i am new to this but i must have made a mistake now when i put in npm start it give me the same message and then lock the screen and i have to reboot
              Mykle1M B 3 Replies Last reply Reply Quote 0
                Mykle1 Project Sponsor Module Developer @sanaa1369
                @sanaa1369
                It’s hard to know what’s going on there by your descriptions. However, when you were getting the error “the file is missing and i need to create one” your MM was working EXCEPT for the config.js needing to be created. In your config folder, there should be a file named config.js.sample. This file should not be edited. You have to copy this file and paste it in the same folder, renaming it to config.js. You now should have config.js.sample file and the config.js file in the same folder (the config folder of MagicMirror). Unless you’ve made some other changes this will allow the mirror to run.
                  bhepler Module Developer @sanaa1369
                  @sanaa1369 - The screen isn’t really locked, it’s just displaying the MagicMirror application in full screen. If you hit Alt+Q it should give you your command prompt back.
                    @sanaa1369
                    Some other very useful key commands for MagicMirror
                    https://forum.magicmirror.builders/topic/5619/how-to-find-and-use-key-commands-in-mm-for-absolute-beginners
                    • F Offline
                      fulmik Project Sponsor
                      That’s a link that will be saved for later use. Thanks
                        sanaa1369 @Mykle1
                        @mykle1 thank’s a lot i appreciate it
