    MMM-Compliments doesn't load
    16 Posts 5 Posters 7.6k Views 5 Watching
      Anthony Project Sponsor
      Re: Compliments text cycler without the randomizerHello, I have installed the module and configured it in my config.js but it doesn’t load. Here is my config:
      			module: 'MMM-Compliments',
      			position: 'lower_third',
      				compliments: {
      				morning: [
      					'Good morning, handsome!',
      					'Enjoy your day!',
      					'How was your sleep?'
      				afternoon: [
      					'Hello, beauty!',
      					'You look sexy!',
      					'Looking good today!'
      				evening: [
      					'Wow, you look hot!',
      					'You look nice!',
      					'Hi, sexy!'
        Mykle1 Project Sponsor Module Developer @Anthony
        @anthony
        This is incorrect (At the beginning of your entry)
        Change it to
        module: 'compliments',
        I tested it for you.
          Anthony Project Sponsor @Mykle1
          @mykle1 Are you sure because it is not the default module. It is a third party one so I can add personalized compliments. I tried to add them in the dafault compliments but after adding them nothing showed up. Not even the defaults. Although I’ll try it when I get home. Thank you very much.
          Mykle1M lavolp3L 2 Replies Last reply Reply Quote 0
            @anthony said in MMM-Compliments doesn't load:
            My bad. I did not notice that it was a different module from the default. I will install it and test for you when I get home from work unless someone gives you a hand before I get here
              @mykle1
              I would appreciate that. Thnak you very much. I will wait for your results and suggestions. As for the MMM-EARTH it is working perfect again. I read your reply on github but I already had disabled it for a couple of days and after that it load perfectly again.
              • lavolp3L Offline
                lavolp3 Module Developer @Anthony
                @Anthony you can add personalized comments to the core module.
                You shoudl consider using the core module and sparing yet another module in your 3rd-party folder. We can help you sort out the personalized things.
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                • lavolp3L Offline
                  lavolp3 Module Developer @lavolp3
                  @lavolp3 For both modules you should add the additional compliments outside of the main module file but inside config.js OR a new referenced json file like this:
                          module: "compliments",
                          position: "lower_third",
                              classes: 'small',
                              remoteFile: 'xxxxx.json',
                              updateInterval: 12*60*60*1000,
                  The json file sits in the module folder
                  A S 2 Replies Last reply Reply Quote 1
                    Anthony Project Sponsor @lavolp3
                    @lavolp3
                    Can you give me a little more help? I created the json file by copy paste the original js file, added my compliments and saved it in the compliments folder named as compliments2.json (was this right?). I also added the lines in my config as you mentioned but still only the defaults are visible. Thank you.
                    • lavolp3L Offline
                      @anthony Your json needs to look like this:
                          "anytime" : [
                           "morning": [
                      Nothing else…
                      If you want you can post your config.js entry and the json file here or via pm. But it’s important you understand how it needs to look and why.
                      A 1 Reply Last reply Reply Quote 1
                        @lavolp3
                        FIXED! Thank you very much for your help.
                          sdetweil @Anthony
                          @anthony can u mark your problem resolved please
                            Anthony Project Sponsor @sdetweil
                            Whatever module you use (default compliments or MMM-Compliments for not crowding your config.js with a big array you can create a json file containing the array with the compliments you want and save it in your compliments folder. After that you must edit your config.js for the compliments module to target that json you created by adding the line remoteFile: "your_file's_name.json", under the config: {. If you don’t have a programm to create the .json file you can do it on line.
                              I understand… but this shows as not solved…
                              click the 3 dots to the right of one of your posts, select ‘mark this post as the correct answer’.
                              I cannot, as you are the topic owner
                                My mistake. Sorry. I will Mark the topic as solved right now! Thank you.
                                  stuartiannaylor @lavolp3
                                  @lavolp3
                                  classes: ‘small’,
                                  remoteFile: ‘xxxxx.json’,
                                  updateInterval: 126060*1000,
                                  Is that all you need to do to partition config.js?
                                  As that is a top tip and ‘small’ ? remoteFile: can that be a local folder such as the corresponding modules folder?
                                  • lavolp3L Offline
                                    lavolp3 Module Developer @stuartiannaylor
                                    @stuartiannaylor yes that’s all you need in the config part.
                                    The module entry looks like this for me:
                                            //disabled: true,
                                                classes: 'small',
                                                remoteFile: 'xxxxxxx.json',
                                    Dont know what you mean with that. I think you don’t need to give it a class but with this class you can determine the size of the text.
                                    remoteFile is a file, not a folder. But it can be anywhere, however if it’s not in the module directory you ned to give the absolute path “/home/pi/…”
