    MMM-nasaastropic no picture
    7 Posts 4 Posters 2.7k Views 4 Watching
    • A
      Anthony Project Sponsor
      I installed the module and it only shows the header and the the url of which should load the image from. But url says: https://apod.nasa.gov/apod/undefined. What does this means?
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Anthony
        @anthony
        It most likely means that the url to the picture is broken. Having made several modules that use the NASA API I would bet this is the problem. NASA has been known to change their API data.
        You can send a message and/or create an issue at the repo and see if the author responds. His last commit to this module was 2 years ago.
        In the meantime, if you are interested in this type of module then you could try https://github.com/mykle1/MMM-NASA
        A 1 Reply Last reply
        • A
          Anthony Project Sponsor @Mykle1
          @mykle1
          I tried the link and it is working but it shows a video instead of a picture. Is that why it doesn’t show on my MM? And that means that every time that NASA will upload a video intstead of a picture I will get the udefined url? I already have installed NASA.
          • A
            Does anyone knows who can change the title color of the module if it doesn’t have css file? I tried many different entries in my custom css but nothing worked. Thank you in advance.
              stuartiannaylor
              guess you could just add it in the code header.style.background = “gray”; just have it before the wrapper code and set it there.
              But think you can just add a style class in config.js
              • A
                Anthony Project Sponsor @stuartiannaylor
                @stuartiannaylor
                That worked! Thank you mate! I am changing the status of the topic as solved.
                • G
                  grena Module Developer
                  The error https://apod.nasa.gov/apod/undefined with MMM-nasaastropic can occur when the media published by NASA is not an image (a video for example).
                  My new module MMM-APOD support image and video (thanks to NASA API) : https://github.com/grenagit/MMM-APOD
                  MMM-APOD ScreenShots
