    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 918.2k Views 74 Watching
      motdog
      dumb question I’m sure but when placing this in the config.js I should get rid of the default weather program, right?
      S J 2 Replies Last reply Reply Quote 0
        sdetweil @motdog
        @motdog you could leave them both in for a little while to check that they both say the same thing!
          motdog @sdetweil
          @sdetweil I tried that & could not get dark sky to show up at all. That’s why I am confused
            sdetweil @motdog
            @motdog me too… can u open the developers console, and see if there are any errors?
            either ctrl-shift-i (letter i) while MM is running,
            or
            npm start dev
            to start with the dev console…
            then select the console tab in the right handle white pane. scroll up to find any errors… in red text usually
              j.e.f.f Project Sponsor Module Developer @motdog
              @motdog said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
              You don’t have to. It will just mean you’ll have weather information from two sources. But one wouldn’t (shouldn’t ?) conflict with the other.
                motdog @j.e.f.f
                @j-e-f-f thats what I thought. Im just having all sorts of weird issues with both weather modules. I may just need to redo them
                  motdog
                  Ive got it up but when I change “table” to “tiled” I get a config error when I restart.
                  When I add units: us I get an error. Ugh.
                  This works```
                  //your cod {
                  module: “MMM-DarkSkyForecast”,
                  header: “Weather”,
                  position: “top_right”,
                  classes: “default everyone”,
                  disabled: false,
                  apikey: “*********”,
                  latitude: “38.751389”,
                  longitude: “-90.565948”,
                  iconset: “4c”,
                  concise: true,
                  forecastLayout: “table”
                  },e here
                  this doesnt
                  header: “Weather”,
                  disabled: false,
                  apikey: “*******”,
                  iconset: “4c”,
                  concise: true,
                  units: us,
                    sdetweil @motdog
                    @motdog always hide your apikey values. with ***
                      motdog @sdetweil
                      @sdetweil thanks. I finally got this module the way I wanted. On to the next one!
                        @motdog You have specified units without quotes. need to write it like this:
                        units: "us",
                        Cr4z33C M 2 Replies Last reply Reply Quote 0
                        • Cr4z33C Offline
                          Cr4z33 @j.e.f.f
                          @j-e-f-f I don’t know why, but when I use your module after a while MM becomes all dark although modules keep working (ie. MMM-AssistantMk2).
                          There’s no specific timing for the issue to appear (it can be after 1 hour or after 15 mins, etc.).
                          Modules won’t appear again until I restart MM.
                          This is my current module config:
                          			module: "MMM-DarkSkyForecast",
                          			header: "Meteo",
                          			classes: "default everyone",
                          			disabled: false,
                          					apikey: "***",
                          					latitude: "***",
                          					longitude: "***",
                          					language: "it",
                          					forecastHeaderText: "***",
                          					label_timeFormat: "hh:mm",
                          					iconset: "4c",
                          					concise: false,
                          					showSummary: false,
                          					forecastLayout: "table"
                            motdog @j.e.f.f
                            @j-e-f-f yep. Thanks. Just lots of trial and error but it was set up how I wanted.
                            • Cr4z33C Offline
                              Cr4z33 @Cr4z33
                              @Cr4z33 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                              			header: "Meteo",
                              			disabled: false,
                              					apikey: "***",
                              					latitude: "***",
                              					longitude: "***",
                              					language: "it",
                              					iconset: "4c",
                              					concise: false,
                              					showSummary: false,
                              @j-e-f-f you there? :smiling_face_with_open_mouth_cold_sweat:
                              J S 2 Replies Last reply Reply Quote 0
                                j.e.f.f Project Sponsor Module Developer @Cr4z33
                                @Cr4z33 I have not seen this behaviour… the module does not do anything to hide any modules including itself… you can examine the code for yourself to see. My guess is there is some unintended consequence of my module interacting with one of the other ones your are also using… Can you try disabling the other modules one at a time to see if the behaviour goes away? If it does, whichever was the last one to be disabled is likely the other party. We can start investigating what’s going on after that.
                                  sdetweil @Cr4z33
                                  that usually means MM has crashed… many times this is memory related… we know that the default updater module also causes a similar behavior
                                  • Cr4z33C Offline
                                    Cr4z33 @j.e.f.f
                                    @j-e-f-f OK, I’ve started disabling all other 3rd-party modules and enabling them one by one.
                                    Apart from that what shall I look to then once there’s an issue between your module and the one of someone else? :)
                                    @sdetweil so what do you suggest me to do? :thinking_face:
                                    At first I thought that using MMM-WatchDog could sort the problem, but I feel like I misunderstood? :smiling_face_with_open_mouth_cold_sweat:
                                      sdetweil @Cr4z33
                                      @Cr4z33 watchdog will just allow you to restart when it crashes… not capture why…
                                      I still don’t have a good method for capturing these kinds of failures…
                                      • Cr4z33C Offline
                                        Cr4z33 @sdetweil
                                        @sdetweil oh I see, but then even if my MM doesn’t look like it restarted.
                                        By now I am trying to see the overall behaviour with the Update module being disabled to see if the issue is still happening.
                                          sdetweil @Cr4z33
                                          @Cr4z33 yeh. i don’t know how watchdog works… at some level if the MM process hangs, watchdog can’t work either… (my opinion without looking at the code)
                                          • Cr4z33C Offline
                                            Cr4z33 @sdetweil
                                            @sdetweil alright.
                                            In the meantime disabling the Update module sorted out the issue… weird…
                                            Oh well that means I will run the updater manually from time to time. :D
                                            • 16
                                            • 17
                                            • 7 / 17
