    Spotify Play?
    19 Posts 6 Posters 18.0k Views 12 Watching
      Rasmus rytter
      How do i play the spotify?
      richland007R 1 Reply Last reply Reply Quote 0
      • richland007R
        richland007 @Rasmus rytter
        @rasmus-rytter First you have to have a premium Spotify account to play outside authorized Spotify devices (google home device is a different story) and if you have Spotify Premium you need to install raspotify on your Raspberry Pi (if that is what you are using) and than you can sling music to it from your phone or ask google to play Spotify on your mirror.
        So 2 things:
        1. Spotify premium
        2. You dont play it on the Magic Mirror per say or form the module you play it form the outside of the mirror in if i am making any sense …the MMM-NowPlayingOnSpotify does exactly that …displays whats playing on your Spotify at that time whether in your phone, tablet or mirror but just displays the info and art that is it …it does not play the music.
          Raspotify is the one that does play the music
          D
          Rasmus rytter @richland007
          Thanks @richland007
          so i need raspotify to start the music though the mirror?
          • Y
            yawns Moderator @Rasmus rytter
            @rasmus-rytter said in Spotify Play?:
            Thanks @richland007
            Yes, you need it. https://github.com/dtcooper/raspotify
            And still you need something else (smartphone, tablet, computer/laptop) to control the playback. All you do is connect the “control device” to the same network as your mirror, start spotify, look for other playback devices and select your mirror instead. Then - in theory - playback should run on your mirror.
            I used spotify-connect-web and MMM-SpotifyConnectUI, but I haven’t been playing around with my mirror installation for almost a year, so I am not sure if this still works. Biggest issue was getting the spotify appkey after registering as a developer. Looks like you don’t have to worry about this with the newer raspotify
              Rasmus rytter @yawns
              Hey @yawns,
              Okay that makes sense. I have just wondered if i could play the music with my google assistant from MMM-AssistantMk2 but i guess not, Tanks :)
                mantha @Rasmus rytter
                Hi @rasmus-rytter,
                if two or more people came to the same conclusion, its an indication that its not an to bad idea :-)
                independent from this post i just had setup my mirror exactly the way @yawns and @richland007 described to you.
                I enhanced MMM-NowPlayingOnSpotify and MMM-AssistantMk2 to make them capable to control Spotify. It´s still in development but if you like you can have a look on my git forks.
                MMM-AssistantMk2
                you need to redo your authorization (Step 2) because we require now also the authorization user-modify-playback-state and you should add “deviceName” into your config-file.
                Im looking forward to your feedback dear alpha-tester ;-)
                F 1 Reply Last reply Reply Quote 1
                • F
                  F17MC @mantha
                  @mantha Hi! How can I install this feature?
                  I want launch Spotify with my MagicMirror. I have installed NowPlayingOnSpotify, AssistantMK2 and Raspotify. All works fine.
                  Now, I can do the next: If I said to AssistantMK2 “SmartMirror, play Spotify on Chromecast Audio”, it launch raspotify and select my ChromeCast Audio as output. Do you think that it is possible?
                  Sorry for my English.
                  • ejay-ibmE
                    ejay-ibm Project Sponsor Module Developer
                    @mantha Thank you for working on this !
                    I have installed you modules.
                    Unfortunately I can’t make the player respond to my play / stop command .
                    the player well respond when I select a song from my phone and send it to raspotify , the module is well updated with cover and paying status .
                    But voice command just doesn’t work .
                    Anything particular I should say ?
                    Maybe your developement is just done 100% done yet.
                    Thank you
                    Ejay
                      mantha @ejay-ibm
                      @ejay-ibm
                      the module is listening to an open.spotify.com answer from Google assistant.
                      It seems like the assistant is not aware of the preconfigured music provider and you need to point him in the right direction.
                      “search for xxx on Spotify” works in my case. I’m almost sure that in the past also “play xxx from spotify” had worked, but now I got no more an open.spotify.com link backs. Would be interesting how it works for you.
                      FYI - I identified that the Device parameter does not work proper in the current github version. need to work on this…
                      • ejay-ibmE
                        Ok I see the answer coming to the screen but it look like it’s not passed to the module.
                        "Micheal Jackson on spotify" ((open.spotify.com -- https://open.spotify.com/artist/3fMbdgg4jU18AjLCKBhRSm))\nMichael Jackson wasn't merely the biggest pop ....
                        Let me know if you need me to run some test or report logs to help you in debug.
                        Ejay
                          mantha @ejay-ibm
                          @ejay-ibm
                          in a first step you could check the console log for “[AMK2] openSpotify found:” and if the event PLAY_SPOTIFY was fired…
                          ejay-ibmE 1 Reply Last reply Reply Quote 0
                          • ejay-ibmE
                            ejay-ibm Project Sponsor Module Developer @mantha
                            @mantha none of both found .
                            could you point me to the line in your code sending this to the console log please ?
                            I see in MK2 js code
                            if (payload.foundOpenSpotify) {
                            		this.sendNotification("PLAY_SPOTIFY", {
                            			url: payload.foundOpenSpotify
                            I can say that the notification is not sent, so no payload.foundOpenSpotify occur
                            I can see as well in node_helper.js
                            if (openSpotify) {
                                      console.error("[AMK2] openSpotify found:", openSpotify[1])
                                      foundOpenSpotify = openSpotify[1]
                            Why in console error instead of console log ?
                            ( Sorry i’m not a dev might be a silly question and I guess the result would be the same if log or error it should be sent to the console… )
                            • ejay-ibmE
                              As well I think the regex is not correct here : node_helper.js line 290
                              var re = new RegExp("\\(.open\\.spotify\\.com – (https:\\/\\/open\\.spotify\\.com[^ ]*).\\)", "gm")
                              should be :
                              var re = new RegExp("\(open\.spotify\.com – (https:\/\/open\.spotify\.com[^ ]*\/\)", "gm")
                              open\.spotify\.com
                              is the correct regex to match with :
                              open.spotify.com
                              and
                              https://open.spotify.com/fallback1234
                              I may be wrong in my interpretation.
                                mantha @ejay-ibm
                                @ejay-ibm said in Spotify Play?:
                                haha… there is a simple answer. I want them to be red to find them more easy. In a final version it should be console log…
                                Regarding the RegEx: I just tested them in german. I’m for sure not an RegEx pro (that’s a kind of black magic for me) ;-)
                                So if you have a better Regex expression feel free to change it.
                                The additional escape characters was necessary to wrap the RegEx into the java code.
                                Are you getting it to work without these escapes?
                                Proposal:
                                based on your post it seems to me, like the English version respond with
                                open.spotify.com -- https...
                                instead of
                                open.spotify.com - https...
                                So you might need to reflect this in the RegEx
                                var re = new RegExp("\\(.open\\.spotify\\.com –+ (https:\\/\\/open\\.spotify\\.com[^ ]*).\\)", "gm")
                                • ejay-ibmE
                                  @mantha
                                  Sorry typo it well respond with
                                  I have try :
                                   var re = new RegExp("https:\/\/open\.spotify\.com\/([^ ]*)", "gm")
                                          var openSpotify = re.exec(str)
                                          if (openSpotify) {
                                  And I’m getting in console log :
                                  received a module notification: PLAY_SPOTIFY from sender: MMM-AssistantMk2
                                  but
                                  I’m not getting anything.
                                  What is strange is that in both case :
                                  console.error(“[AMK2] openSpotify found:”, openSpotify[1])
                                  Doesn’t throw anything…
                                  but as well
                                  console.log(“[AMK2] video found:”, youtubeVideo[1])
                                  Doesn’t throw anything either even when it find and play a video. so i’ll not worry for not about the notif logs
                                  So, for Now, I consider it’s working as PLAY_SPOTIFY notification is fired.
                                  What would be the next step now?
                                  Ejay
                                    mantha @ejay-ibm
                                    @ejay-ibm
                                    please check the console in the dev mode, as well as the filesystem logs…
                                    module and helper write unfortunately to different log destinations.
                                    Regarding the next steps I’m going to open a chat…
                                    • ejay-ibmE
                                      Ok I made a few changes in the MK2assistant node-helper.js
                                      var re = new RegExp("https:\/\/open\.spotify\.com\/([a-zA-Z0-9?\/]+)", "gm")
                                              //var re = new RegExp("\\(.open\\.spotify\\.com – (https:\\/\\/open\\.spotify\\.com[^ ]*).\\)", "gm")
                                              if (openSpotify) {
                                              console.error("[AMK2] openSpotify found:", openSpotify[0])
                                                foundOpenSpotify = openSpotify[0]
                                      And as well in Nowplayingoncpotify/core/Spotifyconnector.js
                                      let uri = replaceall("/", ":", url.replace("https:\/\/open.spotify.com", "spotify"));
                                      The slash were not escaped in the url making half of the line be a comment.
                                      After updating raspotify to the latest I can say : “Michael Jackson on spotify” and the song start playing .
                                      Good stuff .
                                      I’m wondering if slash should be escaped as well here I haven’t do it since it’s working :
                                      const tokenRefreshEndpoint = 'https://accounts.spotify.com/api/token';
                                      const apiEndpoint = 'https://api.spotify.com/v1/me/player';
                                      As you can see the editor consider the part after the slash as comment
                                      Not sure how it works on interpretor side.
                                      anyway I’ll post my update in the repo .
                                      Ejay
                                        mantha @ejay-ibm
                                        @ejay-ibm
                                        Hey Ejay,
                                        many thanks for testing and bug fixing.
                                        Regarding your findings: The original RegEx still works on my installation, but based on your experience it seams like the RegEx is more stable by just looking for the URL itself. I can´t see any downside of this approach.
                                        In my test it turn out that “-” and “_” need to be added to the character set, due to they are used e.g. in usernames (spotify_germany) which are part of playlist path.
                                        Also the escaping is now much more proper (interesting that the raw version had worked…)
                                        Important finding from ejay
                                        if raspotify just jump back to track start instead of changing the song, an update of raspotify is needed. I had exactly the same behavior on my installation.
