    Spotify Play?
    19 Posts 6 Posters 18.0k Views 12 Watching
    • ejay-ibmE
      ejay-ibm Project Sponsor Module Developer
      @mantha Thank you for working on this !
      I have installed you modules.
      Unfortunately I can’t make the player respond to my play / stop command .
      the player well respond when I select a song from my phone and send it to raspotify , the module is well updated with cover and paying status .
      But voice command just doesn’t work .
      Anything particular I should say ?
      Maybe your developement is just done 100% done yet.
      Thank you
      Ejay
        mantha @ejay-ibm
        @ejay-ibm
        the module is listening to an open.spotify.com answer from Google assistant.
        It seems like the assistant is not aware of the preconfigured music provider and you need to point him in the right direction.
        “search for xxx on Spotify” works in my case. I’m almost sure that in the past also “play xxx from spotify” had worked, but now I got no more an open.spotify.com link backs. Would be interesting how it works for you.
        FYI - I identified that the Device parameter does not work proper in the current github version. need to work on this…
        • ejay-ibmE
          Ok I see the answer coming to the screen but it look like it’s not passed to the module.
          "Micheal Jackson on spotify" ((open.spotify.com -- https://open.spotify.com/artist/3fMbdgg4jU18AjLCKBhRSm))\nMichael Jackson wasn't merely the biggest pop ....
          Let me know if you need me to run some test or report logs to help you in debug.
          Ejay
            mantha @ejay-ibm
            @ejay-ibm
            in a first step you could check the console log for “[AMK2] openSpotify found:” and if the event PLAY_SPOTIFY was fired…
            ejay-ibmE 1 Reply Last reply Reply Quote 0
            • ejay-ibmE
              ejay-ibm Project Sponsor Module Developer @mantha
              @mantha none of both found .
              could you point me to the line in your code sending this to the console log please ?
              I see in MK2 js code
              if (payload.foundOpenSpotify) {
              		this.sendNotification("PLAY_SPOTIFY", {
              			url: payload.foundOpenSpotify
              I can say that the notification is not sent, so no payload.foundOpenSpotify occur
              I can see as well in node_helper.js
              if (openSpotify) {
                        console.error("[AMK2] openSpotify found:", openSpotify[1])
                        foundOpenSpotify = openSpotify[1]
              Why in console error instead of console log ?
              ( Sorry i’m not a dev might be a silly question and I guess the result would be the same if log or error it should be sent to the console… )
              • ejay-ibmE
                As well I think the regex is not correct here : node_helper.js line 290
                var re = new RegExp("\\(.open\\.spotify\\.com – (https:\\/\\/open\\.spotify\\.com[^ ]*).\\)", "gm")
                should be :
                var re = new RegExp("\(open\.spotify\.com – (https:\/\/open\.spotify\.com[^ ]*\/\)", "gm")
                open\.spotify\.com
                is the correct regex to match with :
                open.spotify.com
                and
                https://open.spotify.com/fallback1234
                I may be wrong in my interpretation.
                  mantha @ejay-ibm
                  @ejay-ibm said in Spotify Play?:
                  haha… there is a simple answer. I want them to be red to find them more easy. In a final version it should be console log…
                  Regarding the RegEx: I just tested them in german. I’m for sure not an RegEx pro (that’s a kind of black magic for me) ;-)
                  So if you have a better Regex expression feel free to change it.
                  The additional escape characters was necessary to wrap the RegEx into the java code.
                  Are you getting it to work without these escapes?
                  Proposal:
                  based on your post it seems to me, like the English version respond with
                  open.spotify.com -- https...
                  instead of
                  open.spotify.com - https...
                  So you might need to reflect this in the RegEx
                  var re = new RegExp("\\(.open\\.spotify\\.com –+ (https:\\/\\/open\\.spotify\\.com[^ ]*).\\)", "gm")
                  • ejay-ibmE
                    @mantha
                    Sorry typo it well respond with
                    I have try :
                     var re = new RegExp("https:\/\/open\.spotify\.com\/([^ ]*)", "gm")
                            var openSpotify = re.exec(str)
                            if (openSpotify) {
                    And I’m getting in console log :
                    received a module notification: PLAY_SPOTIFY from sender: MMM-AssistantMk2
                    but
                    I’m not getting anything.
                    What is strange is that in both case :
                    console.error(“[AMK2] openSpotify found:”, openSpotify[1])
                    Doesn’t throw anything…
                    but as well
                    console.log(“[AMK2] video found:”, youtubeVideo[1])
                    Doesn’t throw anything either even when it find and play a video. so i’ll not worry for not about the notif logs
                    So, for Now, I consider it’s working as PLAY_SPOTIFY notification is fired.
                    What would be the next step now?
                    Ejay
                      mantha @ejay-ibm
                      @ejay-ibm
                      please check the console in the dev mode, as well as the filesystem logs…
                      module and helper write unfortunately to different log destinations.
                      Regarding the next steps I’m going to open a chat…
                      • ejay-ibmE
                        Ok I made a few changes in the MK2assistant node-helper.js
                        var re = new RegExp("https:\/\/open\.spotify\.com\/([a-zA-Z0-9?\/]+)", "gm")
                                //var re = new RegExp("\\(.open\\.spotify\\.com – (https:\\/\\/open\\.spotify\\.com[^ ]*).\\)", "gm")
                                if (openSpotify) {
                                console.error("[AMK2] openSpotify found:", openSpotify[0])
                                  foundOpenSpotify = openSpotify[0]
                        And as well in Nowplayingoncpotify/core/Spotifyconnector.js
                        let uri = replaceall("/", ":", url.replace("https:\/\/open.spotify.com", "spotify"));
                        The slash were not escaped in the url making half of the line be a comment.
                        After updating raspotify to the latest I can say : “Michael Jackson on spotify” and the song start playing .
                        Good stuff .
                        I’m wondering if slash should be escaped as well here I haven’t do it since it’s working :
                        const tokenRefreshEndpoint = 'https://accounts.spotify.com/api/token';
                        const apiEndpoint = 'https://api.spotify.com/v1/me/player';
                        As you can see the editor consider the part after the slash as comment
                        Not sure how it works on interpretor side.
                        anyway I’ll post my update in the repo .
                        Ejay
                          mantha @ejay-ibm
                          @ejay-ibm
                          Hey Ejay,
                          many thanks for testing and bug fixing.
                          Regarding your findings: The original RegEx still works on my installation, but based on your experience it seams like the RegEx is more stable by just looking for the URL itself. I can´t see any downside of this approach.
                          In my test it turn out that “-” and “_” need to be added to the character set, due to they are used e.g. in usernames (spotify_germany) which are part of playlist path.
                          Also the escaping is now much more proper (interesting that the raw version had worked…)
                          Important finding from ejay
                          if raspotify just jump back to track start instead of changing the song, an update of raspotify is needed. I had exactly the same behavior on my installation.
