    MMM-AssistantMk2
    421 Posts 61 Posters 761.7k Views 57 Watching
      A Former User @Egnos
      @egnos
      There are 3 endpoints of CSS applied.
      • CSS of module itself(modules/SOMEMODULE/SOMEMODULE.css) : It is predefined CSS for module by it’s developer.
      • main magicmirror css (css/main.css) : This is common CSS for Mirror itself and basic default module CSS.
      • custom css (css/custom.css) : When you need to modify some CSS rules over SOMEMODULE.css and main.css, You can redefine or override that CSS rules here.
      By example;
      #ASSISTANT_YOUTUBE is defined in modules/MMM-AssistantMk2/MMM-AssistantMk2.js like this;
      #ASSISTANT_YOUTUBE {
        width:100%;
        height:100%;
        border:none;
        display:none;
        position:fixed;
        top:0;
        left:0;
        background-color:rgba(0,0,0,0.5);
        z-index:99999;
      When you want to modify some CSS rules - smaller size -, you can override those rules in your css/custom.css instead modify MMM-AssisntantMk2.js directly.
        width: 50%;
        height:50%;
        top: 25%;
        left: 25%;
        A Former User
        ADDED
        Step-by-step guide about custom gaction to make a timer feature on wiki page.
        https://github.com/eouia/MMM-AssistantMk2/wiki/Tip%3AMaking-Timer-with-gAction
          Davido
          @Sean : First of all, great Work from your side, my Assistant is working, but I have a question: Is it possible, that the answer box from google could stay a little bit longer onscreen? I also tried your custom.css customization, but it doesn’t work, changing it in MMM-AssistantMk2.css was successful, any suggestions?
          @Lowis : you wrote that your Radio is running, i was also successful, but are you also able to stop it with the voice command? My Mic reacts on saying the Hotword, but then nothing happens. Only a reboot stops the Radio
          ejay-ibmE L 2 Replies Last reply Reply Quote 0
          • ejay-ibmE Offline
            ejay-ibm Project Sponsor Module Developer @Davido
            @davido I think the option you are looking for regarding answer of assistant duration on screen is :
            “screenDuration”: 2000 // here for 2 seconds
            hope this helps
            Ejay
              bachoo786 @Guest
              @sean hello mate
              i want to install google assistant on my rpi 3b+. i have connected a bluetooth speaker and was wondering if it would work? i have tried in the past with my rpi2b but couldnt just install assistant.
              also is there a ste[ by step guide on how to install assistant?
              many thanks god bless.
                A Former User @bachoo786
                @bachoo786 bt speaker will work. Personally I recommend.
                And for instructions, read the github documents. And leave issues what trouble tou have. I’ll support.
                • L Offline
                  Lowis @Davido
                  @davido could be that the radio is too loud . my running at 50% volume and it works.
                  Hotword is “webradio” for start and stop … next hotword is “next station”
                  At the moment i have problems with the sound config. Mic is USB MIC and Speaker HDMI from my monitor.
                  Assistant voice is distorted but radio is clean
                  Update: i deleted all ALSA settings in /etc/asound.conf and ~/.asoundrc and Voice works perfekt.
                  in raspi-config i do this setting > Force HDMI
                    Davido
                    @ejay-ibm :
                    i will try your setting, thx for your answer
                    @Lowis :
                    i tried it with 30% and the same result, also with the mic in front of my mouth, no action to stop … the mic onscreen reacts to my voice, but the input field leaves blank, and there is also no timeout for another input
                      bachoo786 @Guest
                      @Sean I have installed assistantmk2 correctly and have also installed hotword. However I get a blank screen but when I say ok google everything works fine.
                      I have already been through the “electron-rebuild” step, this is what I did:
                      pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ npm install --save-dev electron-rebuild
                      + electron-rebuild@1.8.4
                      updated 1 package and audited 617 packages in 12.623s
                      found 0 vulnerabilities
                      pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ ./node_modules/.bin/electron-rebuild
                      ✔ Rebuild Complete
                      but still no joy.
                      and this is what I have in my config.js
                          module: "MMM-AssistantMk2",
                            record: {
                              recordProgram : "arecord",
                              device        : "plughw:1",
                            notifications: {
                              ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                              ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                          module: "MMM-Hotword",
                            record: {
                            autostart:true,
                            onDetected: {
                              notification: function (payload) {
                                return "ASSISTANT_ACTIVATE"
                              payload: function (payload){
                                return {
                                  profile: payload.hotword
                      what I did notice that if I was to remove the MMM-Hotword from my config i.e. the last part of the code i.e.
                            record: {
                            autostart:true,
                            onDetected: {
                                return {
                      the mirror starts working fine.
                      Also in the hotword git I have followed all the possible solutions and also the main one which is :
                      cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                      nano package.json ## Or open the file with any TEXT editor
                      Then, find this and replace From
                      “node-pre-gyp”: “^0.6.30”
                      To
                      “node-pre-gyp”: “^0.12.0”
                      Then retry npm install again in the module directory again.
                      I have no joy buddy. Please help me
                        bachoo786
                        Hi @Sean
                        So I managed to get it working and everything is fine. However I will be grateful if you could please help me with the following queries:
                        1). When i say jarvis or smart mirror, the assistantmk2 module takes 1 to 2 seconds to respond i.e. the ding bell I mean after which I can ask any question. How can I remove this lag and make it instant? I have seen other people dont have this issue.
                        2). How do I get the assistantmk2 to play youtube videos on my mirror by asking it to play something from youtube?
                        Thanks.
                        This is my config:
                              deviceLocation: {
                                                coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
                                                latitude: 51.597442, // -90.0 - +90.0
                                                longitude: -0.338839, // -180.0 - +180.0
                              record: {
                                device        : "default",
                              play: { // Full values are in `FOR EXPERTS` section.
                                      playProgram: "mpg321", // recommended.
                              notifications: {
                              record: {
                                device        : "default",
                              autostart:true,
                              onDetected: {
                                  return {
                          Davido @bachoo786
                          @bachoo786
                          to 1) which Hardware are you using?
                          to 2) i say the Hotword and then “play on youtube …” and it is working
                            bachoo786 @Davido
                            @Davido I am using raspberry pi 3b+
                              Davido @bachoo786
                              @bachoo786 :
                              i am using a normal rPi 3B without + and the answering time is really fast … maybe some other Module which is interacting?
                                bachoo786 @Davido
                                @Davido nope nothing is interacting with my assistantmk2 module.
                                  bachoo786 @Davido
                                  @Davido can you share your config for both mmm-assistant and mmm-hotword please?
                                    Davido @bachoo786
                                    @bachoo786
                                    I hope this will help
                                        // --- ESSENTIALS / modifying for your environment might be needed.
                                        deviceLocation: {
                                            latitude: 47.809490, // -90.0 - +90.0
                                            longitude: 13.055010, // -180.0 - +180.0
                                        defaultProfile: "default", // If you have several profiles and want to set one of them as default profile, describe here.
                                        profiles: {
                                          "default" : { // profile name.
                                            profileFile: "default.json", // profile file name.
                                            lang: "de-DE"
                                            //currently available (estimation, not all tested):
                                            //  de-DE, en-AU, en-CA, en-GB, en-US, en-IN
                                            // fr-CA, fr-FR, it-IT, ja-JP, es-ES, es-MX, ko-KR, pt-BR
                                            // https://developers.google.com/assistant/sdk/reference/rpc/languages
                                          /* Add your other profiles here, if exists.
                                          "other_profile" : {
                                            profileFile: "other.json",
                                            lang: "de-DE"
                                        record: { // Full values are in `FOR EXPERTS` section.
                                          recordProgram: "arecord",  // Defaults to "arecord" - also supports "rec" and "sox"
                                          device: null        // recording device (e.g.: "plughw:1")
                                        // --- OPTIONAL / not important but customizable for your usage
                                        responseVoice: true, // If available, Assistant will response with her voice.
                                        responseScreen: true, // If available, Assistant will response with some rendered HTML
                                        responseAlert: true, // If available, Assistant will response with Alert module of MM
                                        // Sometimes, any response might not be returned. responseAlert is useful for displaying error.
                                        screenZoom: "80%", // Adjust responseScreen to your mirror size.
                                        screenDuration: 2000, // milliseconds. How long responseScreen will be shown after speech.
                                        //If you set 0, Screen Output will be closed after Response speech finishes ASAP.
                                        youtubeAutoplay: true, //If set as true, found Youtube video will be played automatically.
                                        pauseOnYoutube:true, //If set as true, You cannot activate Assistant during youtube playing. Recommended for the performance (Because permanent hotword detecting might make performance lower)
                                        useWelcomeMessage: "", //Try "brief today" as this value. You can use this value to check module working when MM is starting.
                                        onIdle: {
                                          timer: 1000*60*30, // if you don't want to use this feature, just set timer as `0` or command as ""
                                          command: "HIDEMODULES"
                                        onActivate: {
                                          timer: 0,
                                          command: "SHOWMODULES"
                                        // --- FOR EXPERTS / For development, debug or more
                                        verbose:false, // You can get error or some logs when this value is set as true.
                                        startChime: "connection.mp3", // you can use `mp3` to play chime when your mic is ready. It should be playable with your `play.playProgram`
                                        noChimeOnSay: false, // When using the `ASSISTANT_SAY` trigger, you can prevent the chime from being played before your words
                                        auth: { // I believe you don't need to change this.
                                          keyFilePath: "./credentials.json"
                                        record:  { // Full version
                                          sampleRate    : 16000,      // audio sample rate
                                          threshold     : 0.5,        // silence threshold (rec only)
                                          thresholdStart: null,       // silence threshold to start recording, overrides threshold (rec only)
                                          thresholdEnd  : null,       // silence threshold to end recording, overrides threshold (rec only)
                                          silence       : 1.0,        // seconds of silence before ending
                                          verbose       : false,      // log info to the console
                                          recordProgram : "arecord",  // Defaults to "arecord" - also supports "rec" and "sox"
                                          device        : null        // recording device (e.g.: "plughw:1")
                                        play: { // Full version
                                          encodingOut: "MP3", //'MP3' or 'WAV' is available, but you might not need to modify this.
                                          sampleRateOut: 24000,
                                          playProgram: "mpg321", //Your prefer sound play program. By example, if you are running this on OSX, `afplay` could be available.
                                          playOption: [],
                                          // If you need additional options to use playProgram, describe here. (except filename)
                                          // e.g: ["-d", "", "-t", "100"]
                                        useGactionCLI: false, // If set as true, you can update your gAction when MM is rebooted.
                                        projectId: "", // Google Assistant ProjectId (Required only when you use gAction.)
                                        deviceModelId: "", // It should be described in your config.json. In most of case, you don't need to this.
                                        deviceInstanceId: "", // It should be described in your config.json. In most of case, you don't need to this.
                                        action:{}, // You can catch your gAction command.
                                        transcriptionHook: {}, // You can catch transcription hook and be able to make your own `COMMAND` with this.
                                        //See the `transcriptionHook` section.
                                        command: {}, // You can make your own MM command for gAction and transcriptionHook
                                        //See the `command` section.
                                        record: {
                                          notifications: {
                                        notifications: { // You can redefine these notifications to communicate with specific modules.
                                          ASSISTANT_ACTIVATE: "ASSISTANT_ACTIVATE",
                                          ASSISTANT_DEACTIVATE: "ASSISTANT_CLEAR",
                                          ASSISTANT_ACTIVATED: "ASSISTANT_ACTIVATED",
                                          ASSISTANT_DEACTIVATED: "ASSISTANT_DEACTIVATED",
                                          ASSISTANT_ACTION: "ASSISTANT_ACTION",
                                          DEFAULT_HOOK_NOTIFICATION: "ASSISTANT_HOOK",
                                          TEXT_QUERY: "ASSISTANT_QUERY",
                                          SAY_TEXT: "ASSISTANT_SAY",
                                          snowboy: [
                                        hotwords: "smartmirror", //this will be sent to other module for distinguishing which hotword is detected.
                                        file: "resources/models/smart_mirror.umdl",
                                        sensitivity: '0.5',
                                        hotwords: "snowboy",
                                        file: "resources/models/snowboy.umdl",
                                        sensitivity: '0.5',
                                        file: 'resources/models/jarvis.umdl',
                                        sensitivity: '0.8,0.80',
                                        hotwords: ['jarvis','jarvis'] //Kitt.ai changed their Jarvis UMDL, it has 2 models in one file. So weird.
                                        //anyway, you can give different name for each. ['jarvis_1', 'jarvis_2']. Even though I think this is useless.
                                        record: {
                                          verbose       : false,      // log info to the console. Use this when you want to check mic working or not.
                                          recordProgram : 'arecord',  // Defaults to 'arecord' - also supports 'rec' and 'sox'
                                          device        : null        // recording device (e.g.: 'plughw:1')
                                        autostart: true,              // if 'false', this module will wait for 'HOTWORD_RESUME' notification to start hotwords detection at the beginning.
                                        autorestart: false,          // You can set this 'true' when you want this module to go back to listening mode automatically again after hotword is detected. But use this carefully when your other modules are using microphone or speaker.
                                        // customizable notification trigger
                                        notifications: {
                                          PAUSE: "HOTWORD_PAUSE",
                                          RESUME: "HOTWORD_RESUME",
                                          LISTENING : "HOTWORD_LISTENING",
                                          SLEEPING : "HOTWORD_SLEEPING",
                                          ERROR : "HOTWORD_ERROR",
                                        onDetected: {
                                          notification: (payload) => {
                                            return "HOTWORD_DETECTED"
                                          payload: (payload) => {
                                            return payload
                                    	  record: {
                                          autostart:true,
                                          onDetected: {
                                              return {
                                      bachoo786 @Davido
                                      @Davido thank you
                                        A Former User
                                        UPDATED
                                        [2.1.4] - 2019.03.26
                                        • Added : Now you can use recipes. https://github.com/eouia/MMM-AssistantMk2/wiki/Usage#recipes
                                          recipe is an external js file containing definitions of command, transcriptionHook and action. Your configuration could be more shorter.
                                        recipes:["hide_and_show_all_modules.js", "reboot.js", "screen_onoff.js", "shutdown.js"],
                                        Feel free to request PR to share your recipes to others.
                                        • Changed : onIdle, onDetected features are disabled by default.
                                          bryan_1
                                          @Sean
                                          sorry for my bad English. I use the default recipes and set the language to German for all pattern (“spiegel reboot”, “monitor aus”, etc). Every thing works fine, only the “SHOWMODULES” doesn’t work. Although the hotword is correctly detected, but nothing happens. I set the pattern for SHOWMODULE to pattern: “alle module”,
                                          This is also the same case if I use the OnIdle and OnActivate:
                                          onIdle: {
                                          timer: 10006020,
                                          command: “HIDEMODULES”,
                                          onActivate: {
                                          timer: 0,
                                          command: “SHOWMODULES”,
                                          I can hide the modules, but after the hotword for SHOWMODULES being recognized the modules aren’t shown again. What do I wrong? Many thanks in advance.
                                            A Former User @bryan_1
                                            @bryan_1
                                            Can you show me the recipe(command and transcriptionHook or gAction) about SHOWMODULES?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 21
                                            • 22
                                            • 13 / 22
