    MMM-AssistantMk2
    421 Posts 61 Posters 804.1k Views 57 Watching
    • T
      teitlebot
      @Sean
      Thanks again for all the work and help
      So how would I get assistant module to disable and enable the google photo module?
      I would like to speak “Hide Photos” and the Google Photos will stop displaying.
      I know I need transition hook and command
      I tried learning how to do this using your example of hide clock except after I added the code nothing happened. When I say “hide clock” it searches google for hide clock instead of turning off module. So I must be doing something wrong
      BTW the hide all command works fine.
      ? 1 Reply Last reply
        A Former User @teitlebot
        @teitlebot
        I don’t know how you do your code. I have no second sight. Show your work to examine.
        • E
          Egnos
          Hi @Sean.
          I have some questions to ask you:
          • I installed AssistantMK2 and Hotword successfully but the only way to wake up the assistant is to say “snowboy”. The hot word “smartmirror” and “jarvis” do not work. Can you help me? (my config.js below…)
          • When I ask for a song on youtube I can not stop the song anymore. The assistant does not listen to me. To talk to the assistant I have to wait for the end of the song. How do I solve?
          • When the assistant begins to speak, he cuts the first words, is it possible to solve?
          • The videos on youtube are reproduced in full screen. Is it possible to reproduce them in a small box (example: bottom right …)?
          Thanks you for your great work and patience! :winking_face:
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "en",
          	timeFormat: 24,
          	units: "metric",
          		  module: "MMM-AssistantMk2",
          		    /*useWelcomeMessage: "brief today",*/
          		    deviceLocation: {
          					coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
          					latitude: 45.200049, // -90.0 - +90.0
          					longitude: 7.568917, // -180.0 - +180.0
          			profiles: {
          				"default" : { // profile name.
          				profileFile: "default.json", // profile file name.
          				lang: "it-IT",
          				//currently available (estimation, not all tested):
          				//  de-DE, en-AU, en-CA, en-GB, en-US, en-IN
          				// fr-CA, fr-FR, it-IT, ja-JP, es-ES, es-MX, ko-KR, pt-BR
          				// https://developers.google.com/assistant/sdk/reference/rpc/languages
          			record: { // Full values are in `FOR EXPERTS` section.
          				recordProgram: "arecord",  // Defaults to "arecord" - also supports "rec" and "sox"
          				device: "plughw:1"        // recording device (e.g.: "plughw:1")
          			play: { // Full values are in `FOR EXPERTS` section.
          				playProgram: "mpg321", // recommended.
          			notifications: {
                  ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                  ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
              module: "MMM-Hotword",
                record: {
                  recordProgram : "arecord",
                  device        : "plughw:1",
                autostart:true,
                onDetected: {
                  notification: function (payload) {
                    return "ASSISTANT_ACTIVATE"
                  payload: function (payload){
                    return {
                      profile: payload.hotword
            module: 'MMM-Hotword',
              snowboy: [
              hotwords: "smartmirror", //this will be sent to other module for distinguishing which hotword is detected.
              file: "resources/models/smart_mirror.umdl",
              sensitivity: '0.5',
              hotwords: "snowboy",
              file: "resources/models/snowboy.umdl",
              sensitivity: '0.5',
              file: 'resources/models/jarvis.umdl',
              sensitivity: '0.8,0.80',
              hotwords: ['jarvis','jarvis'] //Kitt.ai changed their Jarvis UMDL, it has 2 models in one file. So weird.
              //anyway, you can give different name for each. ['jarvis_1', 'jarvis_2']. Even though I think this is useless.
              record: {
                sampleRate    : 16000,      // audio sample rate
                threshold     : 0.5,        // silence threshold (rec only)
                thresholdStart: null,       // silence threshold to start recording, overrides threshold (rec only)
                thresholdEnd  : null,       // silence threshold to end recording, overrides threshold (rec only)
                silence       : 1.0,        // seconds of silence before ending
                verbose       : true,      // log info to the console. Use this when you want to check mic working or not.
                recordProgram : 'arecord',  // Defaults to 'arecord' - also supports 'rec' and 'sox'
                device        : 'plughw:1'        // recording device (e.g.: 'plughw:1')
              autostart: true,              // if 'false', this module will wait for 'HOTWORD_RESUME' notification to start hotwords detection at the beginning.
              autorestart: false,          // You can set this 'true' when you want this module to go back to listening mode automatically again after hotword is detected. But use this carefully when your other modules are using microphone or speaker.
              // customizable notification trigger
              notifications: {
                PAUSE: "HOTWORD_PAUSE",
                RESUME: "HOTWORD_RESUME",
                LISTENING : "HOTWORD_LISTENING",
                SLEEPING : "HOTWORD_SLEEPING",
                ERROR : "HOTWORD_ERROR",
              onDetected: {
                notification: (payload) => {
                  return "HOTWORD_DETECTED"
                payload: (payload) => {
                  return payload
                  module: 'MMM-pages',
                          modules:
                              [[ "weatherforecast", "newsfeed"],
                               [ "calendar", "compliments" ]],
                          excludes: ["clock", "currentweather", "MMM-page-indicator", "MMM-AssistantMk2"],
                  module: 'MMM-page-indicator',
                  position: 'bottom_bar',
                      pages: 3,
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			header: "US Holidays",
          						symbol: "calendar-check-o ",
          			module: "compliments",
          			position: "lower_third"
          			module: "currentweather",
          				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
          			module: "weatherforecast",
          			header: "Weather Forecast",
          				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "La Stampa",
          						url: "https://www.lastampa.it/rss.xml"
          				showSourceTitle: true,
          				showPublishDate: true
            A Former User @Egnos
            @egnos
            Adjust sensitivity.
            set pauseOnYoutube:false. You can activate hotword during videoplaying and it will stop the video. Anyway, there is a risk that your video sounds could also activate hotword.
            I think you are using HDMI as output. HDMI could have that symptom. Use other output.
            Redefine CSS selector #ASSISTANT_YOUTUBE in css/custom.css.
            E R 2 Replies Last reply
            • E
              Egnos @Guest
              @sean said in MMM-AssistantMk2:
              Adjust sensitivity.
              The sensitivity of the microphone?
              If yes, how do you do it?
              Where should I make this modify?
              Thanks a lot!
                @egnos
                    sensitivity: '0.5', // < - SENSITIVITY
                css/custom.css
                • T
                  teitlebot @jomwells
                  @jomwells @Sean
                  I seem to have always had this problem where after a reboot I sometimes need to manually change the hardware number of my usb mic. I saw @jomwells wrote a fix by changing the .asoundrc file but for some reason my system always changes the asoundrc back after any changes I make.
                  I wonder if you have any ideas of a fix for me?
                    @teitlebot
                    As far as I know, there be alias for device instead cardno. But not sure. I’m not familiar with these things.
                    • E
                      Egnos
                      Sorry @Sean I’m new in the MagicMirror environment and I do not know all the components.
                      Where can I find information on what is needed and how to customize the “custom.css” file?
                      What do you mean:
                      MagicMirror use the “custom.css” or “main.css”?
                      bheplerB ? 2 Replies Last reply
                      • bheplerB
                        bhepler Module Developer @Egnos
                        @egnos It uses both. Changes you make to custom.css will 1) be included in the mirror’s display and 2) persist if you update when new mirror code is released.
                          @egnos
                          There are 3 endpoints of CSS applied.
                          • CSS of module itself(modules/SOMEMODULE/SOMEMODULE.css) : It is predefined CSS for module by it’s developer.
                          • main magicmirror css (css/main.css) : This is common CSS for Mirror itself and basic default module CSS.
                          • custom css (css/custom.css) : When you need to modify some CSS rules over SOMEMODULE.css and main.css, You can redefine or override that CSS rules here.
                          By example;
                          #ASSISTANT_YOUTUBE is defined in modules/MMM-AssistantMk2/MMM-AssistantMk2.js like this;
                          #ASSISTANT_YOUTUBE {
                            width:100%;
                            height:100%;
                            border:none;
                            display:none;
                            position:fixed;
                            top:0;
                            left:0;
                            background-color:rgba(0,0,0,0.5);
                            z-index:99999;
                          When you want to modify some CSS rules - smaller size -, you can override those rules in your css/custom.css instead modify MMM-AssisntantMk2.js directly.
                            width: 50%;
                            height:50%;
                            top: 25%;
                            left: 25%;
                            A Former User
                            ADDED
                            Step-by-step guide about custom gaction to make a timer feature on wiki page.
                            https://github.com/eouia/MMM-AssistantMk2/wiki/Tip%3AMaking-Timer-with-gAction
                            B 1 Reply Last reply
                              Davido
                              @Sean : First of all, great Work from your side, my Assistant is working, but I have a question: Is it possible, that the answer box from google could stay a little bit longer onscreen? I also tried your custom.css customization, but it doesn’t work, changing it in MMM-AssistantMk2.css was successful, any suggestions?
                              @Lowis : you wrote that your Radio is running, i was also successful, but are you also able to stop it with the voice command? My Mic reacts on saying the Hotword, but then nothing happens. Only a reboot stops the Radio
                              ejay-ibmE L 2 Replies Last reply
                              • ejay-ibmE
                                ejay-ibm Project Sponsor Module Developer @Davido
                                @davido I think the option you are looking for regarding answer of assistant duration on screen is :
                                “screenDuration”: 2000 // here for 2 seconds
                                hope this helps
                                Ejay
                                  bachoo786 @Guest
                                  @sean hello mate
                                  i want to install google assistant on my rpi 3b+. i have connected a bluetooth speaker and was wondering if it would work? i have tried in the past with my rpi2b but couldnt just install assistant.
                                  also is there a ste[ by step guide on how to install assistant?
                                  many thanks god bless.
                                    A Former User @bachoo786
                                    @bachoo786 bt speaker will work. Personally I recommend.
                                    And for instructions, read the github documents. And leave issues what trouble tou have. I’ll support.
                                    • L
                                      Lowis @Davido
                                      @davido could be that the radio is too loud . my running at 50% volume and it works.
                                      Hotword is “webradio” for start and stop … next hotword is “next station”
                                      At the moment i have problems with the sound config. Mic is USB MIC and Speaker HDMI from my monitor.
                                      Assistant voice is distorted but radio is clean
                                      Update: i deleted all ALSA settings in /etc/asound.conf and ~/.asoundrc and Voice works perfekt.
                                      in raspi-config i do this setting > Force HDMI
                                        Davido
                                        @ejay-ibm :
                                        i will try your setting, thx for your answer
                                        @Lowis :
                                        i tried it with 30% and the same result, also with the mic in front of my mouth, no action to stop … the mic onscreen reacts to my voice, but the input field leaves blank, and there is also no timeout for another input
                                          bachoo786 @Guest
                                          @Sean I have installed assistantmk2 correctly and have also installed hotword. However I get a blank screen but when I say ok google everything works fine.
                                          I have already been through the “electron-rebuild” step, this is what I did:
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ npm install --save-dev electron-rebuild
                                          + electron-rebuild@1.8.4
                                          updated 1 package and audited 617 packages in 12.623s
                                          found 0 vulnerabilities
                                          pi@raspberrypi:~/MagicMirror/modules/MMM-AssistantMk2 $ ./node_modules/.bin/electron-rebuild
                                          ✔ Rebuild Complete
                                          but still no joy.
                                          and this is what I have in my config.js
                                                record: {
                                                notifications: {
                                                record: {
                                                autostart:true,
                                                onDetected: {
                                                    return {
                                          what I did notice that if I was to remove the MMM-Hotword from my config i.e. the last part of the code i.e.
                                                record: {
                                                autostart:true,
                                                onDetected: {
                                                    return {
                                          the mirror starts working fine.
                                          Also in the hotword git I have followed all the possible solutions and also the main one which is :
                                          cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                                          nano package.json ## Or open the file with any TEXT editor
                                          Then, find this and replace From
                                          “node-pre-gyp”: “^0.6.30”
                                          To
                                          “node-pre-gyp”: “^0.12.0”
                                          Then retry npm install again in the module directory again.
                                          I have no joy buddy. Please help me
                                            bachoo786
                                            Hi @Sean
                                            So I managed to get it working and everything is fine. However I will be grateful if you could please help me with the following queries:
                                            1). When i say jarvis or smart mirror, the assistantmk2 module takes 1 to 2 seconds to respond i.e. the ding bell I mean after which I can ask any question. How can I remove this lag and make it instant? I have seen other people dont have this issue.
                                            2). How do I get the assistantmk2 to play youtube videos on my mirror by asking it to play something from youtube?
                                            Thanks.
                                            This is my config:
                                                  deviceLocation: {
        latitude: 51.597442, // -90.0 - +90.0
        longitude: -0.338839, // -180.0 - +180.0
                                                  record: {
                                                    device        : "default",
                                                  notifications: {
                                                  record: {
                                                    device        : "default",
                                                  autostart:true,
                                                  onDetected: {
                                                      return {
                                            D 1 Reply Last reply
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 21
                                            • 22
                                            • 13 / 22
