    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 933.2k Views 74 Watching
      chris1971
      After several trials I think it’s o.k.
      Thanks for the support.
      Chris
      • CyruS1337C
        CyruS1337 Project Sponsor
        Good Morning all
        First of all, thank you for the Herrvorrande weather module !!
        Is it also possible to display different weather forecasts (two different locations)? For example, the locations alternate every 30 seconds.
        J 1 Reply Last reply
          j.e.f.f Project Sponsor Module Developer @Cr4z33
          @Cr4z33 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
          Apart from that what shall I look to then once there’s an issue between your module and the one of someone else?
          No idea :) But at least we’ll have a starting point as to where to look. Basically something is causing all of the modules to hide, and it has something to do with an interaction with mine. The only thing my module does to affect anything outside itself is to broadcast weather data whenever it updates to any other modules who want to use it. See if the module is reacting to the DARK_SKY_FORECAST_WEATHER_UPDATE notification.
            j.e.f.f Project Sponsor Module Developer @CyruS1337
            @CyruS1337 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
            Not in a rotation, as I believe that is what you are asking for. However you can configure multiple instances of the module, so you could have two forecasts that way. Keep in mind that this doubles the number of requests to the Dark Sky API, so you’ll want to be mindful that you don’t exceed the daily maximum of 1000 requests. You can tune how frequently the module polls for data with the updateInterval configuration parameter.
            CyruS1337C 1 Reply Last reply
              j.e.f.f Project Sponsor Module Developer @chris1971
              @chris1971 Did you run npm install in the MMM-DarkSkyForecast directory? Otherwise, what is the behaviour you are seeing?
              • CyruS1337C
                CyruS1337 Project Sponsor @j.e.f.f
                @j-e-f-f That’s too bad. Thanks anyway for the quick answer
                  chris1971 @j.e.f.f
                  @j-e-f-f Yes I have executed npm install… everything is running smooth right now. Can you explain how I can set the font size of the forecast text?
                  It would be great if you could implement time for sunrise/ sunset and a moonphase… :-)
                  Thanks for the great module!!! Chris
                    mielu80
                    I’ve installed this weather module and I find it very nice but I have a little issue with it,a strange character like a rectangle appear in front of the temperature value. (marked with red in pic)
                    Does anybody knows what could be the cause ?
                    Had this issue on an old installation of raspbian + MagicMirror,also have it on a fresh reinstall of raspbian and magic mirror only the config file remained from old installation.
                    My config:
                    <------><------><------>module: 'MMM-DarkSkyForecast',
                    <------><------><------>position: 'right',
                    <------><------><------>classes: 'default everyone',
                    <------><------><------>disabled: false,
                    <------><------><------>config: {
                    <------><------><------><------>apikey: "xxxxx......xxxx....",
                    <------><------><------><------>latitude: "44.426765",
                    <------><------><------><------>longitude: "26.102537",
                    <------><------><------><------>iconset: "5c",
                    <------><------><------><------>concise: false,
                    <------><------><------><------>forecastLayout: "table",
                    <------><------><------><------>showHourlyForecast: true,
                    <------><------><------><------>hourlyForecastInterval: 12,
                    <------><------><------><------>maxHourliesToShow: 1,
                    <------><------><------><------>label_high: "max",
                    <------><------><------><------>label_low: "min",
                    <------><------><------><------>label_days: ["Duminica", "Luni", "Mar?i", "Miercuri", "Joi", "Vineri", "Sâmbata"],
                    <------><------><------><------>showCurrentConditions: true,
                    <------><------><------><------>showExtraCurrentConditions: true,
                    <------><------><------><------>label_ordinals: ["N", "NNE", "NE", "ENE", "E", "ESE", "SE", "SSE", "S", "SSV", "SV", "VSV", "V", "VNV", "NV", "NNV"],
                    <------><------><------><------>maxDailiesToShow: "5",
                    <------><------><------><------>showSummary: true,
                    <------><------><------><------>label_timeFormat: "kk:mm",
                    Thank you.
                    richland007R J 2 Replies Last reply
                    • E
                      epi @lavolp3
                      Great widget!
                      It just lacks 3 things:
                      1. Sunrise & sunset data
                      2. “Feels like”
                      3. showWindDirectionAsArrow: true as in module: “currentweather”,
                      Made a sketch -
                      Cr4z33C 1 Reply Last reply
                      • richland007R
                        richland007 @mielu80
                        @mielu80 me too… no idea whats up other than that works great
                        • Cr4z33C
                          Cr4z33 @epi
                          @epi said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                          1. “Feels like”
                          Indeed comes very handy to me when in Summer.
                          The weather here is usually very wet and in Summer ie. 35° C give a feeling of 42° C so I wish I could know it before getting out. :sun: :fire:
                          E 1 Reply Last reply
                            j.e.f.f Project Sponsor Module Developer @mielu80
                            @mielu80 said in MMM-DarkSkyForecast - Yet ANOTHER weather module:
                            I’ve just tried with your config and I can’t duplicate this problem. That said, when I inspect that part of the screen with the dev tools, it looks like there is an extra character there, but in my case it just appears as white space. But there’s nothing I can see in the markup where this is…
                            M E S 3 Replies Last reply
                            • E
                              epi @Cr4z33
                              1. “Feels like”
                              Its the opposite in Latvia - due to cold weather and wind, taking into consideration that the sea is very close, even -1 Celsius might feel like -7.
                                chris1971
                                Oh my god… everything was running and I have shoot the system…and try to install it again.
                                Now the module is not loading anymore. here is my config:
                                module: “MMM-DarkSkyForecast”,
                                header: “Wetter in Mülheim”,
                                position: “top_right”,
                                classes: “default everyone”,
                                disabled: false,
                                apikey: “xxxxxxxxxxxxxxxxxxxx”,
                                latitude: “51.4185682”,
                                longitude: “6.8845226”,
                                iconset: “3c”,
                                maxHourliesToShow: 4,
                                maxDailiesToShow: 4,
                                useAnimatedIcons: true,
                                label_timeFormat: “k[h]”,
                                concise: false,
                                forecastLayout: “table”
                                Do you see any problems? I only see in the top right region “Weeter in Mülheim” and Loading… but the module isn’t running…
                                Please advise - Thanks, Chris
                                • O
                                  onkelbobby
                                  I implemented this fantastic Modus and it integrates almost seamlessly into our existing mirror layout. To make it perfect I need to reduce the gap between the time and the icon as wells between the day and the icon (yellow arrows). and also between the individual block’s (arrows in red)
                                  I know that I have to modify the .css file can someone give me a hint what would be the correct values to be changed?
                                  • Cr4z33C
                                    Cr4z33 @chris1971
                                    @chris1971 maybe the API key has expired or has been blacklisted?
                                    I had this issue 1 month ago and using another API key solved the issue. :)
                                      mielu80 @j.e.f.f
                                      @j-e-f-f
                                      Hello j.e.f.f,
                                      Thank you for your update about this issue.
                                      I did try another thing:
                                      -I’ve commented out my whole config for DarkSkyForecast module
                                      -copied the default config from module’s github and pasted it my config file from MM
                                      -restarted MM
                                      Unfortunately the result is the same,still had that odd character even with the default config for this module.
                                      Thank you very much for your effort.
                                        chris1971 @Cr4z33
                                        @Cr4z33 - Thx - I tried a new API and the module is running. Does anybody know how to minimize the font size in the module. Especially in the tiled view?
                                        • O
                                          onkelbobby
                                          Minimizing to font size should not be a big thing. If you open the module specific css file you an search for font and play with the values in that section. Note that you need to restart MM after saving the modified css file.
                                            chris1971
                                            how can I delete the 2 lines in the forecast?
                                            • 10
                                            • 11
                                            • 16
                                            • 17
                                            • 9 / 17
