    MMM-Spotify
    249 Posts 51 Posters 365.2k Views 54 Watching
    • yawnsY
      yawns Moderator
      Looks nice and touch interface sounds promising
      • T
        teitlebot
        Really nice. Do you know if Google Play is possible to have such a module?
        ? 1 Reply Last reply
          A Former User @teitlebot
          @teitlebot
          As far as I know, Kodi could work on Raspberry Pi. But I cannot find API or data which could be used.
          Google Player Music has no official API currently.
          There are some unofficial implements but I’m not sure whether it will work on RPI easily or not.
          ejay-ibmE Cr4z33C 2 Replies Last reply
          • ejay-ibmE
            ejay-ibm Project Sponsor Module Developer @Guest
            @Sean It was a real pleasure to work with you on this project.
            We have a real good Spotify module now that do all in one!
            Fantastic!
            • Cr4z33C
              Cr4z33 @Guest
              @Sean @ejay-ibm nice release guys.
              Only could you please replace the plain white Spotify logo with a darker one (like in MMM-NowPlayingOnSpotify)? :grimacing_face:
              Also Is this a stand-alone Spotify module?
              And if yes is it mandatory then to have a (Spotify) Premium account?
              In addition:
              I noticed that the module doesn’t go into ‘standby’ view once I end playing music until I restart MagicMirror.
                A Former User @Cr4z33
                @Cr4z33
                Thanks for using
                1. You can replace image file by yourself (It is under resources directory). Feel free to change it as your wish.
                2. This is not stand-alone player. Originally, I was developing stand-alone player with new Web Playback API but unfortunately, current Electron/Chromium on RPI miss core feature about that. Somedays, when Electron/Chromium on RPI has that feature, I’ll implement. Currently you need RASPOTIFY to play spotify on RPI. (Or any other spotify-enable device like smartTV, smartphone, or smartspeakers)
                3. You could not controll playback or not use some features without premium account.
                4. Eh, last song cover is better than spotify icon, isn’t it? :D
                  spotify icon will be appeared when there is no possible playback or device. But not sure. I didn’t test about it. If you need that feature absolutely, I’ll consider it on next update.
                • ejay-ibmE
                  @Sean said in MMM-Spotify:
                  @Cr4z33
                  Yes that is correct . When nothing is played and all players are disconnected the white spotify icon appear.
                  We place that one here just to not have nothing.
                  As Sean said this is customizable , you just need to change the png file under the resources directory .
                  Enjoy you new module.
                  Ejay
                  • Cr4z33C
                    Cr4z33 @Guest
                    @Sean @ejay-ibm alright thanks to both of you.
                    • K
                      kwaeksler
                      i installed this module today. Works perfect, thanks for this great work :-) I just overwrited the css a little bit, hope this is ok for you!
                      And now my question: is it possible to show this module only on my mirror when i play music on it? Because when i am not at home i think my music selection isnt very interessting for my girlfriend :-D
                      Thank you
                      Kwaeksler
                      ? 2 Replies Last reply
                        A Former User @kwaeksler
                        @kwaeksler
                        Frankly said, I didn’t test, but module would work only under same network. But I might be wrong. I hope there be who can explain it clearly. Or i’ll test it on monday by myself.
                        ejay-ibmE 1 Reply Last reply
                        • ejay-ibmE
                          @Sean @kwaeksler
                          Spotify is account linked, so actually, the module will display what is currently played on any devices linked to the same account ( same client ID/secret) even out of your network. I tested with a Spotify family , even different email are linked to the main account. So I can not think of a solution right now.
                          Ejay
                            @kwaeksler I think I can add device limitation to display or control. I’ll consider it on updates.
                            K 1 Reply Last reply
                            • K
                              kwaeksler @Guest
                              @Sean That sounds great :-) Thank you!
                              • ejay-ibmE
                                some more testing . With Spotify Familly. You can have 1 device set per email account .
                                ejay
                                  A Former User
                                  updated
                                  1.1.0 (2019-03-25)
                                  • Added: touch(click) interface
                                  • Device Limitation : Now you can allow or limit devices to display its playing on MM.
                                  • Some CSS structure is changed.
                                  • Now this module can emit SPOTIFY_* notifications for other module.
                                  • thymonT
                                    thymon
                                    Need the same for DEEZER :disappointed_face: :loudly_crying_face:
                                    Cr4z33C 1 Reply Last reply
                                    • Cr4z33C
                                      Cr4z33 @thymon
                                      @thymon said in MMM-Spotify:
                                      Never got it working, but here it is.
                                      • Cr4z33C
                                        Cr4z33
                                        @Sean @ejay-ibm I’ve got a Spotify Premium account now so I was giving MMM-Spotify another shot, but I am stuck at instructions step #4.
                                        I am logged in however I get INVALID_CLIENT: Invalid redirect URI in the webpage once I click the generated URL. :confused_face:
                                        Any thoughts?
                                          @Cr4z33
                                          Your two values of “REDIRCT_URI” should be the same; Your spotify App setup and your spotify.config.json. Check again.
                                          • Cr4z33C
                                            Cr4z33 @Guest
                                            @Sean sorry where shoud I look for that? :smiling_face_with_open_mouth_cold_sweat:
                                            In the generated link or?
                                            • 12
                                            • 13
                                            • 1 / 13
