    MMM-Spotify
    249 Posts 51 Posters 344.0k Views 54 Watching
    • Cr4z33C Offline
      Cr4z33 @Guest
      @Sean @ejay-ibm nice release guys.
      Only could you please replace the plain white Spotify logo with a darker one (like in MMM-NowPlayingOnSpotify)? :grimacing_face:
      Also Is this a stand-alone Spotify module?
      And if yes is it mandatory then to have a (Spotify) Premium account?
      In addition:
      I noticed that the module doesn’t go into ‘standby’ view once I end playing music until I restart MagicMirror.
        A Former User @Cr4z33
        @Cr4z33
        Thanks for using
        1. You can replace image file by yourself (It is under resources directory). Feel free to change it as your wish.
        2. This is not stand-alone player. Originally, I was developing stand-alone player with new Web Playback API but unfortunately, current Electron/Chromium on RPI miss core feature about that. Somedays, when Electron/Chromium on RPI has that feature, I’ll implement. Currently you need RASPOTIFY to play spotify on RPI. (Or any other spotify-enable device like smartTV, smartphone, or smartspeakers)
        3. You could not controll playback or not use some features without premium account.
        4. Eh, last song cover is better than spotify icon, isn’t it? :D
          spotify icon will be appeared when there is no possible playback or device. But not sure. I didn’t test about it. If you need that feature absolutely, I’ll consider it on next update.
        ejay-ibmE Cr4z33C 2 Replies Last reply Reply Quote 0
        • ejay-ibmE Offline
          ejay-ibm Project Sponsor Module Developer @Guest
          @Sean said in MMM-Spotify:
          @Cr4z33
          Yes that is correct . When nothing is played and all players are disconnected the white spotify icon appear.
          We place that one here just to not have nothing.
          As Sean said this is customizable , you just need to change the png file under the resources directory .
          Enjoy you new module.
          Ejay
          • Cr4z33C Offline
            Cr4z33 @Guest
            @Sean @ejay-ibm alright thanks to both of you.
            • K Offline
              kwaeksler
              i installed this module today. Works perfect, thanks for this great work :-) I just overwrited the css a little bit, hope this is ok for you!
              And now my question: is it possible to show this module only on my mirror when i play music on it? Because when i am not at home i think my music selection isnt very interessting for my girlfriend :-D
              Thank you
              Kwaeksler
                A Former User @kwaeksler
                @kwaeksler
                Frankly said, I didn’t test, but module would work only under same network. But I might be wrong. I hope there be who can explain it clearly. Or i’ll test it on monday by myself.
                ejay-ibmE 1 Reply Last reply Reply Quote 0
                • ejay-ibmE Offline
                  @Sean @kwaeksler
                  Spotify is account linked, so actually, the module will display what is currently played on any devices linked to the same account ( same client ID/secret) even out of your network. I tested with a Spotify family , even different email are linked to the main account. So I can not think of a solution right now.
                  Ejay
                    @kwaeksler I think I can add device limitation to display or control. I’ll consider it on updates.
                    • K Offline
                      kwaeksler @Guest
                      @Sean That sounds great :-) Thank you!
                      • ejay-ibmE Offline
                        some more testing . With Spotify Familly. You can have 1 device set per email account .
                        ejay
                          A Former User
                          updated
                          1.1.0 (2019-03-25)
                          • Added: touch(click) interface
                          • Device Limitation : Now you can allow or limit devices to display its playing on MM.
                          • Some CSS structure is changed.
                          • Now this module can emit SPOTIFY_* notifications for other module.
                          K 1 Reply Last reply Reply Quote 1
                          • thymonT Offline
                            thymon
                            Need the same for DEEZER :disappointed_face: :loudly_crying_face:
                            • Cr4z33C Offline
                              Cr4z33 @thymon
                              @thymon said in MMM-Spotify:
                              Never got it working, but here it is.
                              • Cr4z33C Offline
                                Cr4z33
                                @Sean @ejay-ibm I’ve got a Spotify Premium account now so I was giving MMM-Spotify another shot, but I am stuck at instructions step #4.
                                I am logged in however I get INVALID_CLIENT: Invalid redirect URI in the webpage once I click the generated URL. :confused_face:
                                Any thoughts?
                                  @Cr4z33
                                  Your two values of “REDIRCT_URI” should be the same; Your spotify App setup and your spotify.config.json. Check again.
                                  • Cr4z33C Offline
                                    Cr4z33 @Guest
                                    @Sean sorry where shoud I look for that? :smiling_face_with_open_mouth_cold_sweat:
                                    In the generated link or?
                                    • Cr4z33C Offline
                                      Cr4z33
                                      There’s more now I notice a following error message in the terminal
                                      [SPOTIFY_AUTH] Error: null { error: 'invalid_request',
                                        error_description: 'code must be supplied' }
                                        @Cr4z33
                                        Go to https://developer.spotify.com/dashboard/applications (login)
                                        Then select your spotify app for this module. (You might have created one if you followed instruction)
                                        Then check your redirect_uri with your spotify.config.json.
                                        • Cr4z33C Offline
                                          Cr4z33 @Guest
                                          @Sean that was the solution. :D
                                          The redirect URI for some reason was empty.
                                          As soon as I added it manually re-running step #4 worked like a charm. :thumbs_up_medium_skin_tone:
                                          • Cr4z33C Offline
                                            Cr4z33
                                            @Sean OK now a different issue.
                                            I added the MMM-AssistantMk2 needed lines, but when I say ie. Michael Jackson on Spotify nothing happens…
                                            Isn’t it supposed to play then straight on MagicMirror? :thinking_face:
                                            • 12
                                            • 13
                                            • 1 / 13
