    MMM-Spotify
    249 Posts 51 Posters 365.2k Views 54 Watching
      A Former User @ejay-ibm
      @ejay-ibm thanks. As your wish, my colleague.
      • Cr4z33C
        Cr4z33 @ejay-ibm
        @ejay-ibm thanks, but it came out that the module was already fine only I didn’t know I had to setup Raspotify if I want a stand-alone solution.
        Tbh you guys should state that as I guess many here would love to run Spotify completely from the mirror, but it is not so obvious. ;)
        • Cr4z33C
          Cr4z33
          @Sean @ejay-ibm can you please add the option to hide module commands?
          If someone like me is using MMM-AssistantMk2 to control it then buttons aren’t needed anymore. ;)
          ejay-ibmE 1 Reply Last reply
          • ejay-ibmE
            ejay-ibm Project Sponsor Module Developer @Cr4z33
            @Cr4z33 We have added an option to hide the control
            after doing a “git pull” from : ~/MagicMirror/modules/MMM-Spotify/
            you can set in your config file
             control: "default", //"default", "hidden" available~
            Ejay
            Cr4z33C 1 Reply Last reply
            • Cr4z33C
              Cr4z33 @ejay-ibm
              @ejay-ibm nice thanks! :thumbs_up_medium_skin_tone:
              Also I didn’t notice in your last reply the many Spotify’ MMM-AssistantMk2 commands you were sharing.
              Thanks for that too (although GA doesn’t understand properly yet when calling a specific Playlist, but hey we can’t have everything lol). :D
              • Cr4z33C
                Cr4z33
                @ejay-ibm @Sean I noticed only now that if using allowDevices: with the Raspotify device name I can then hear the music, but somehow the module doesn’t ‘wake up’ and keeps showing the Spotify logo only.
                K Cr4z33C 2 Replies Last reply
                • K
                  kwaeksler @Cr4z33
                  @Cr4z33 thats true. That was one of my feature request on page one. I only wanted to see the information about the song on the mirror when i play it on it. Because for other familie members the information about my playing songs arent very interessting when i am not at home. :-D
                  • K
                    kwaeksler
                    • K
                      kwaeksler @Guest
                      @Sean said in MMM-Spotify:
                      updated
                      1.1.0 (2019-03-25)
                      • Added: touch(click) interface
                      • Device Limitation : Now you can allow or limit devices to display its playing on MM.
                      • Some CSS structure is changed.
                      • Now this module can emit SPOTIFY_* notifications for other module.
                      @Sean that sounds very great. I will update it later, thank you very much! :-)
                      R 1 Reply Last reply
                      • Cr4z33C
                        Cr4z33 @Cr4z33
                        @Cr4z33 said in MMM-Spotify:
                        Guys any idea why? :grimacing_face:
                        Also @ejay-ibm maybe it’s because I translated them into Italian, but the commands used with MMM-AssistantMk2 that you posted earlier this week don’t get applied.
                        Ie. I say the hotword and then ‘next song’ and nothing happens…
                        Usually GA either executes the command or replies saying he didn’t understand, but not this time… :thinking_face:
                        alt text
                        • ejay-ibmE
                          @Cr4z33 1st you have a wonderfull miror
                          2nd , if you send it to me maybe i’ll give you the answer ^^… joking …
                          I’m not sure what’s wrong .
                          What I would do first is turn on verbose mode on hotword and Mk2 assistant and check .
                          1- Console log .
                          2- pm2 out logs ( see “pm2 show scriptname” )
                          3- pm2 error logs
                          Capitalization is very important in hook eg .
                          hook is like “next song”
                          when you say this to assistant if assistnat wirte " Next song" that that wikk not work .
                          All I can say for now is check the logs and share with us , that mitght help to help .
                          Ejay
                          • I
                            icripps
                            can whatever that is playing on your phone be played by the mirror too?
                            ? 1 Reply Last reply
                              A Former User @icripps
                              @icripps
                              If you mean multi-speaker, It isn’t.
                              To play Spotify on your MagicMirror(Raspberry Pi), you need to install Raspotify on your Raspberry Pi.
                              Then, you can play Spotify on your MM directly and can control Spotify (Wherever it played on).
                              • Cr4z33C
                                Cr4z33 @ejay-ibm
                                @ejay-ibm lol for my mirror and thanks for the suggestion. :smiling_face_with_open_mouth_closed_eyes:
                                @icripps please note that to be able to use Raspotify a Spotify Premium account is MANDATORY. ;)
                                • I
                                  icripps
                                  Okay thank you. Will manage what I have for now
                                    bolish
                                    Hi guys,
                                    Do you know which parameter to play with into the custom.css to get the module smaller in size? (it’s taking to much place on my screen).
                                    Thx
                                      A Former User @bolish
                                      @bolish
                                      Is style: "mini" still too big? It has only around 360px X 120px.
                                      Unfortunately, there is no single magic keypoint to modify simply.
                                      See MMM-Spotify.css and redefine values on your css/custom.css
                                        bolish
                                        @sean thanks for feedback.
                                        I liked the default view, but wanted it to be a little bit smaller.
                                        I was a bit lost into the .css but I will try to play around with it and see what happens.
                                        Good idea would have been to have a single entry to modify ( like in %) so that user could adjust itself but I believe it’s very personal need, it’s maybe not worth to implement into the module.
                                          @bolish
                                          Add this into your css/custom.css.
                                          :root {
                                            --sp-width: 300px;
                                          #SPOTIFY {
                                           width: var(--sp-width);
                                          #SPOTIFY_INFO {
                                            width: calc(var(--sp-width) - 20px);
                                          #SPOTIFY_INFO .text {
                                            width: calc(var(--sp-width) - 70px);
                                          #SPOTIFY_COVER {
                                            width: calc(var(--sp-width) - 40px);
                                            height: calc(var(--sp-width) - 40px);
                                          --sp-width:300px is magic point. adjust it as your wish. I think 200px is the minimal value possible.
                                            bolish
                                            @sean, thanks I will try in the evening
                                            • 12
                                            • 13
                                            • 3 / 13
