    MMM-Spotify
    249 Posts 51 Posters 365.2k Views 54 Watching
    • K
      kwaeksler @Cr4z33
      @Cr4z33 thats true. That was one of my feature request on page one. I only wanted to see the information about the song on the mirror when i play it on it. Because for other familie members the information about my playing songs arent very interessting when i am not at home. :-D
      • K
        kwaeksler
        • K
          kwaeksler @Guest
          @Sean said in MMM-Spotify:
          updated
          1.1.0 (2019-03-25)
          • Added: touch(click) interface
          • Device Limitation : Now you can allow or limit devices to display its playing on MM.
          • Some CSS structure is changed.
          • Now this module can emit SPOTIFY_* notifications for other module.
          @Sean that sounds very great. I will update it later, thank you very much! :-)
          R 1 Reply Last reply
          • Cr4z33C
            Cr4z33 @Cr4z33
            @Cr4z33 said in MMM-Spotify:
            @ejay-ibm @Sean I noticed only now that if using allowDevices: with the Raspotify device name I can then hear the music, but somehow the module doesn’t ‘wake up’ and keeps showing the Spotify logo only.
            Guys any idea why? :grimacing_face:
            Also @ejay-ibm maybe it’s because I translated them into Italian, but the commands used with MMM-AssistantMk2 that you posted earlier this week don’t get applied.
            Ie. I say the hotword and then ‘next song’ and nothing happens…
            Usually GA either executes the command or replies saying he didn’t understand, but not this time… :thinking_face:
            alt text
            • ejay-ibmE
              ejay-ibm Project Sponsor Module Developer
              @Cr4z33 1st you have a wonderfull miror
              2nd , if you send it to me maybe i’ll give you the answer ^^… joking …
              I’m not sure what’s wrong .
              What I would do first is turn on verbose mode on hotword and Mk2 assistant and check .
              1- Console log .
              2- pm2 out logs ( see “pm2 show scriptname” )
              3- pm2 error logs
              Capitalization is very important in hook eg .
              hook is like “next song”
              when you say this to assistant if assistnat wirte " Next song" that that wikk not work .
              All I can say for now is check the logs and share with us , that mitght help to help .
              Ejay
              Cr4z33C 1 Reply Last reply
              • I
                icripps
                can whatever that is playing on your phone be played by the mirror too?
                ? 1 Reply Last reply
                  A Former User @icripps
                  @icripps
                  If you mean multi-speaker, It isn’t.
                  To play Spotify on your MagicMirror(Raspberry Pi), you need to install Raspotify on your Raspberry Pi.
                  Then, you can play Spotify on your MM directly and can control Spotify (Wherever it played on).
                  • Cr4z33C
                    Cr4z33 @ejay-ibm
                    @ejay-ibm lol for my mirror and thanks for the suggestion. :smiling_face_with_open_mouth_closed_eyes:
                    @icripps please note that to be able to use Raspotify a Spotify Premium account is MANDATORY. ;)
                    • I
                      icripps
                      Okay thank you. Will manage what I have for now
                        bolish
                        Hi guys,
                        Do you know which parameter to play with into the custom.css to get the module smaller in size? (it’s taking to much place on my screen).
                        Thx
                          A Former User @bolish
                          @bolish
                          Is style: "mini" still too big? It has only around 360px X 120px.
                          Unfortunately, there is no single magic keypoint to modify simply.
                          See MMM-Spotify.css and redefine values on your css/custom.css
                            bolish
                            @sean thanks for feedback.
                            I liked the default view, but wanted it to be a little bit smaller.
                            I was a bit lost into the .css but I will try to play around with it and see what happens.
                            Good idea would have been to have a single entry to modify ( like in %) so that user could adjust itself but I believe it’s very personal need, it’s maybe not worth to implement into the module.
                              @bolish
                              Add this into your css/custom.css.
                              :root {
                                --sp-width: 300px;
                              #SPOTIFY {
                               width: var(--sp-width);
                              #SPOTIFY_INFO {
                                width: calc(var(--sp-width) - 20px);
                              #SPOTIFY_INFO .text {
                                width: calc(var(--sp-width) - 70px);
                              #SPOTIFY_COVER {
                                width: calc(var(--sp-width) - 40px);
                                height: calc(var(--sp-width) - 40px);
                              --sp-width:300px is magic point. adjust it as your wish. I think 200px is the minimal value possible.
                                bolish
                                @sean, thanks I will try in the evening
                                  bolish
                                  @Sean Works great. Tx
                                    mmmmh Project Sponsor
                                    Another awesome module, thank you!
                                    The displayed album cover goes dim when there is no playback which is nice. Would it be possible to add an option to completely hide the module when there is no playback?
                                      A Former User @mmmmh
                                      @mmmmh
                                      #SPOTIFY.pausing {
                                      display:none;
                                      M Cr4z33C 2 Replies Last reply
                                        mmmmh Project Sponsor @Guest
                                        #SPOTIFY.pausing {
                                        display:none;
                                        Simple and works perfectly. Thanks!
                                        • Cr4z33C
                                          Cr4z33 @Guest
                                          @mmmmh
                                          #SPOTIFY.pausing {
                                          display:none;
                                          I stopped and quit the Windows 10 Spotify app, but the artwork keeps showing.
                                            A Former User @Cr4z33
                                            @Cr4z33
                                            That checks only playing and pausing. Inactive device is another issue.
                                            This module is pooling to pull current playback data per 1~2 secs.
                                            PPL may have several spotify devices, so if one device is deactivated, but others could be alive. And there’s no way to receive one device’s activeness at event time. (Spotify API doesn’t support pushing to client)
                                            To check “ALL DEVICES” are inactive, another pooling be needed to pull data about available devices per 1~2 sec. I’m not sure whether it’s good approach or not. It would make API usage double. (Somebody be already worrying about too many DNS calling by this module)
                                            Anyway, I’ll consider it.
                                            • 12
                                            • 13
                                            • 3 / 13
