    MMM-AssistantMk2
    421 Posts 61 Posters 761.2k Views 57 Watching
      bryan_1 @Guest
      @Sean unfortunately it doesn’t help. I wonder, why only this SHOWMODULES doesn’t work but all other recipes do (include HIDEMODULES) :pensive_face:
      • T Offline
        teitlebot @Guest
        @Sean @ejay-ibm
        so if I can use assistant_say why would I need to install TTS?
          A Former User @teitlebot
          @teitlebot
          Assistant_say is a kind of hack. It cannot be guaranteed to work properly at every case. And not for long text.
            A Former User @bryan_1
            @bryan_1
            Log is needed to figure out what happens. Furthermore for tracing and checking suspicious points, source modifying is needed.
            You can contact me on Telegram (ID : @eouia). If you don’t mind, I can help on the telegram when I’m not busy.
            • Cr4z33C Offline
              Cr4z33 @Guest
              @Sean please check Telegram as I sent you a message with the error I am getting after MM latest update. ;)
                A Former User @Cr4z33
                @Cr4z33
                You need electron-rebuild for module. MichMich change electron version in new update. so, new module binary for electron is needed.
                Cr4z33C B 2 Replies Last reply Reply Quote 0
                • Cr4z33C Offline
                  Cr4z33 @Guest
                  @Sean thank you.
                  The steps (suggested by @Sean) to fix the black screen issue after latest MagicMirror update are:
                  cd ~/MagicMirror/modules/MMM-AssistantMk2
                  npm install --save-dev electron-rebuild
                  ./node_modules/.bin/electron-rebuild
                  and if you use MMM-Hotword too
                  cd ~/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                  npm install nan
                    bryan_1 @Guest
                    @Sean after MM latest update found youtube video is not played automatically. It is only shown. I ran npm start dev and get this error: Failed to execute ‘postMessage’ on ‘DOMWindow’: The target origin provided (‘https://www.youtube.com’) does not match the recipient window’s origin (‘http://0.0.0.0:8080’). Do you have any idea? Thanks in advance.
                      there is a limitation on the version of electron used… they have prevented autoplay of media (video , and audio)
                      if there is not a user interaction with the window content in advance… (and with a mirror, we don’t click etc)
                      anyhow… there is a work around in the shorterm
                      edit MagicMirror/js/electron.js
                      after line
                      function createWindow() {
                      add
                          app.commandLine.appendSwitch('autoplay-policy', 'no-user-gesture-required');  //< -------- added
                      save and restart MM
                        bryan_1 @sdetweil
                        @sdetweil I’ll try it tonight. Thank you.
                          bryan_1 @sdetweil
                          @sdetweil it works, thank you.
                            DopeEthiop
                            Hey guys, I’m having a problem with my MMM-AssistantMk2 and possibly my MMM-Hotword. I have a Raspberry Pi3 and I’m using a usb mic for recording.
                            I have both of the modules up and running but when asking Jarvis a question it takes about 7 seconds before I get any response. Then when I do get a response, the transcription is quick and hurried, while the text on the bottom of the screen disappears quickly. I was wondering if there was a way to optimize this through the config file or if this was something different?
                              A Former User @DopeEthiop
                              @DopeEthiop
                              Your issue always and only happens when you say “jarvis”? or all the same with other hotwords?
                              Sometimes the time lag could happen, but your case seems something wrong. Leave your issue to git repository issue board to look inside more deeply. here is not so good place to track issue.
                                dxfan227
                                Hello
                                I have both mmm assistantmk2 and hot word up and running however when I saw jarvis the first time it works…but then when I try again…no hot word picked up. any ideas?
                                  bibi
                                  Hello all, was just wondering if and how difficult it would be possible to add a kinda face animation in Mk2? I have seen Hello-Lucy and i found the idea cool but the face is kind of creepy :grinning_face_with_smiling_eyes:
                                    Mykle1 Project Sponsor Module Developer @bibi
                                    @bibi
                                    Take a look at this module. It displays animated faces of sorts.
                                    https://forum.magicmirror.builders/topic/9963/mmm-ai.
                                    Or, if you have an animated gif that suits you, you can use just about any image module to display it.
                                      Davido @dxfan227
                                      @dxfan227
                                      have you found a solution?
                                      if not, please attach your config
                                        dxfan227 @Davido
                                        @Davido
                                        Thanks, i did find a solution. For some reason the HOTWORD RESUME notification was not working. I had to “hard code” it into the .js file itself for the module. It is now working.
                                          dxfan227
                                          Is there a way to unlink this from my personal google account info?
                                          Ie when I ask to show me photos of dogs…it actually goes through MY google photos account and shows photos of my dog.
                                          • Cr4z33C Offline
                                            Cr4z33
                                            @Sean can you tell us please anything about what’s coming with versione 3? :smiling_face_with_halo:
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 21
                                            • 22
                                            • 15 / 22
