    MMM-AssistantMk2
    421 Posts 61 Posters 788.9k Views 57 Watching
      there is a limitation on the version of electron used… they have prevented autoplay of media (video , and audio)
      if there is not a user interaction with the window content in advance… (and with a mirror, we don’t click etc)
      anyhow… there is a work around in the shorterm
      edit MagicMirror/js/electron.js
      after line
      function createWindow() {
      add
          app.commandLine.appendSwitch('autoplay-policy', 'no-user-gesture-required');  //< -------- added
      save and restart MM
        bryan_1 @sdetweil
        @sdetweil I’ll try it tonight. Thank you.
          bryan_1 @sdetweil
          @sdetweil it works, thank you.
            DopeEthiop
            Hey guys, I’m having a problem with my MMM-AssistantMk2 and possibly my MMM-Hotword. I have a Raspberry Pi3 and I’m using a usb mic for recording.
            I have both of the modules up and running but when asking Jarvis a question it takes about 7 seconds before I get any response. Then when I do get a response, the transcription is quick and hurried, while the text on the bottom of the screen disappears quickly. I was wondering if there was a way to optimize this through the config file or if this was something different?
              A Former User @DopeEthiop
              @DopeEthiop
              Your issue always and only happens when you say “jarvis”? or all the same with other hotwords?
              Sometimes the time lag could happen, but your case seems something wrong. Leave your issue to git repository issue board to look inside more deeply. here is not so good place to track issue.
                dxfan227
                Hello
                I have both mmm assistantmk2 and hot word up and running however when I saw jarvis the first time it works…but then when I try again…no hot word picked up. any ideas?
                  bibi
                  Hello all, was just wondering if and how difficult it would be possible to add a kinda face animation in Mk2? I have seen Hello-Lucy and i found the idea cool but the face is kind of creepy :grinning_face_with_smiling_eyes:
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @bibi
                    @bibi
                    Take a look at this module. It displays animated faces of sorts.
                    https://forum.magicmirror.builders/topic/9963/mmm-ai.
                    Or, if you have an animated gif that suits you, you can use just about any image module to display it.
                      Davido @dxfan227
                      @dxfan227
                      have you found a solution?
                      if not, please attach your config
                        dxfan227 @Davido
                        @Davido
                        Thanks, i did find a solution. For some reason the HOTWORD RESUME notification was not working. I had to “hard code” it into the .js file itself for the module. It is now working.
                          dxfan227
                          Is there a way to unlink this from my personal google account info?
                          Ie when I ask to show me photos of dogs…it actually goes through MY google photos account and shows photos of my dog.
                          • Cr4z33C
                            Cr4z33
                            @Sean can you tell us please anything about what’s coming with versione 3? :smiling_face_with_halo:
                              A Former User @Cr4z33
                              @Cr4z33
                              Well, now it is on development and not ready to release so details could be changed.
                              But it might have these features;
                              • No need to wait after hotword. You could say “mirror, blahblah” instead “mirror (pause and wait activation) blahblah.”
                              • Some annoying dependency would be removed. HTML5 default audio output would be used, so you don’t be bothered by sound output configuration. If your web browser can play some audio, it would be enough
                              • Installer will be provided.
                              • Recorded wav file by user or other module could be used for your query. (So User can query via 3 ways - text, real-time vocal query, pre-recorded vocal query)
                              • Annoying center region issue would be gone.
                              • ScreenOutput would be more controllable (duration time, size, activation inner links, suggested commands, …)
                                • The core informations of screenOutput would be extracted for later using. (e.g: external link to open a broswer for getting additional information. it could be transferable to other module for later using.)
                              • Creating and managing custom action would be easier.
                                • So I’m considering to remove transcriptionHook trick to use action instead.
                                • I served transcriptionHook for making simple voice command, but that is not a natural way to use Google Assistant. In many cases, Ppl tried to make commands which are not related with google assistant directly. Rather those kinds of commands could be achieved by just simple voice detection without AI. So I now add that feature to MMM-Hotword and being condering to drop out from MMM-AssistantMk2
                              • YouTube features will be removed. (And Spotify also)
                                • Instead, YouTube, Spotify, Web Browsing, Map Direcions, Image search would be separated as independent module. those modules will use the info which is extracted from result of query. Of course, each module could be used standalone without AMK2. I’ll make it one-by-one. (Or whoever has interests could)
                              Cr4z33C 1 Reply Last reply Reply Quote 1
                              • Cr4z33C
                                Cr4z33 @Guest
                                @Sean wow that’s a BIG change in the module! 😲
                                Can’t wait to start trying it out mate to use all the good stuff you are adding in it.
                                Thanks for letting us know and have a nice Sunday. 😁
                                • saljokeS
                                  saljoke
                                  Wonderful. I want to try these changes!!!
                                    smarthome
                                    Hello
                                    How can I stop Assistant’s response and make request again like Google Home Speaker can ?
                                      smarthome @smarthome
                                      This is my config, still don’t work yet
                                          module: "MMM-AssistantMk2",
                                            notifications: {
                                              ASSISTANT_UNDERSTOOD: "HOTWORD_RESUME",
                                        module: "MMM-Hotword",
                                          models: [
                                              hotwords    : "stop",
                                              file        : "stop.pmdl",
                                              sensitivity : "0.5",
                                          command: {
                                            "stop":{
                                            notificationExec: {
                                              notification: "ASSISTANT_CLEAR",
                                              payload: (detected, afterRecord) => {
                                                return {profile:"default"}
                                            afterRecordLimit:0,
                                            restart:false,
                                        A Former User @smarthome
                                        @smarthome Sorry, at this moment, there is no way to interrupt response. Just wait ends.
                                          smarthome @Guest
                                          @Sean said in MMM-AssistantMk2:
                                          Tks for your quick answer! Can we make a command exec to mpg21 to stop blayback google response?
                                          S ? 2 Replies Last reply Reply Quote 0
                                            And other question is, if I ask a command that Google can not find the suitable answer, there’s no response while google home speaker give a promise answer? Is there any configure to do that?
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 21
                                            • 22
                                            • 15 / 22
