    Total Newbie 24" MagicMirror (Munich, Germany)
    42 Posts 13 Posters 52.0k Views 13 Watching
    • thedoorsfanaticT Offline
      thedoorsfanatic @zdenek
      @zdenek
      Again, pretty simple, with this: https://amzn.to/2C7513z
      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
      zdenekZ 1 Reply Last reply Reply Quote 0
      • zdenekZ Offline
        zdenek @thedoorsfanatic
        @thedoorsfanatic great, thanks
          thedoorsfanatic
          You are welcome !
          • ejay-ibmE Offline
            ejay-ibm Project Sponsor Module Developer
            @zdenek Very nice looking and result.
            As often in mirror showcase, the back is not shown ( yes that’s often the ugly part as well I know :) ) but I think it is interesting to see how all hardware are implemented in the back .
            Would you mind to share some pictures of the back ?
            thedoorsfanaticT 1 Reply Last reply Reply Quote 1
              thedoorsfanatic @ejay-ibm
              @ejay-ibm
              Since there is no frame there is also no actual back besides the backside of the monitor.
              The Raspi is sitting on a shelf below the mirror
                thedoorsfanatic
                Quick update:
                https://youtu.be/xpJ4ubovD_o
                Now with a Philips Hue Lightstrip in the back of the mirror
                  Aries1984 Module Developer
                  Hi there…looks great! What module did you use for the countdown?
                    thedoorsfanatic @Aries1984
                    @Aries1984
                    Thanks a lot!
                    I used MMM-CountDown:
                    https://github.com/boazarad/MMM-CountDown
                      thedoorsfanatic
                      Now also with Local Transport module:
                      https://youtu.be/xoh6VZHyznY
                      Nun wird mir morgens auf dem Magic Mirror meine tägliche Pendelstrecke über die Google Maps API angezeigt.
                        thedoorsfanatic
                        New update with PIR sensor and new modules: Wunderlist to-dos, SoccerLiveScore & fuel prices in a range of a certain distance to my home:
                        https://youtu.be/5Cs3pCZamuM
                          dxfan227
                          Looks good, can I ask what kind of glassed you used. For me I want someting a little more Mirror like…your’s looks good but appeakrs not so reflective? A little more like clear acrylic.
                          Which PIR module did you use? and With PIR hardware?
                            thedoorsfanatic @dxfan227
                            @dxfan227
                            Thanks a lot!
                            I used Mirropane™ Chrome Spy glas, 4 mm thick, next time I might get 6 mm.
                            PIR hardware: https://amzn.to/2YNSxYr
                            Module: https://github.com/paviro/MMM-PIR-Sensor
                              thedoorsfanatic
                              I integrated two new modules into my MagicMirror:
                              • MMM-GoogleFit
                              • MMM-GoogleMapsTraffic
                              Watch a short video:
                              https://youtu.be/Z1bWmxJHmAQ
                              German:
                              Meinem MagicMirror habe ich zwei neue Module hinzugefügt: Tägliche Schrittanzahl meiner Garmin Fitness Watch und Körpergewicht, synchronisiert über Google Fit. Dazu eine Google Map meiner Umgebung inklusive aktueller Stauanzeige.
                                thedoorsfanatic
                                https://youtu.be/VEH_AFpjQgM
                                Experimenting with Background Slideshow module on my test monitor before inserting new functions into my Smart Mirror …
                                Auf meinem Test-Monitor experimentiere ich mit dem Background Slideshow Modul herum, bevor ich meinem Smart Mirror neue Funktionen hinzufüge …
                                  thedoorsfanatic
                                  https://youtu.be/frFSshaYkjw
                                  My Smart Mirror will now show the birthdays from my Google Contacts. In addition, the IP of two smartphones is polled every 30 seconds to check when a person was connected to the home network.
                                  German translation:
                                  Auf meinem Smart Mirror werden nun auch die Geburtstage aus meinen Google Kontakten angezeigt. Zusätzlich wird alle 30 Sekunden die IP zweier Smartphones abgefragt, um zu checken, wann eine Person mit dem heimischen Netzwerk verbunden war.
                                  • strawberry 3.141S Offline
                                    strawberry 3.141 Project Sponsor Module Developer @thedoorsfanatic
                                    @thedoorsfanatic Looks nice and clean. Good job on the build.
                                    Greetings from Munich
                                    • H Offline
                                      hayman @thedoorsfanatic
                                      @thedoorsfanatic said in Total Newbie 24" MagicMirror (Munich, Germany):
                                      .currentweather .wi-day-sunny {
                                      content: url(“/css/icons/day.svg”);
                                      nicely done will you please send your custom.css files ,thanks
                                      thedoorsfanaticT 1 Reply Last reply Reply Quote 0
                                        thedoorsfanatic @hayman
                                        @hayman
                                        What exactly do you wanna know?
                                        • H Offline
                                          @thedoorsfanatic which size do you use and the folders,thanks
                                            thedoorsfanatic
                                            Back in the Lab to test new functions for my Magic Mirror. Today I started working on a German word clock…
                                            https://youtu.be/qa2UFx_EEK0
                                            FoziF 1 Reply Last reply Reply Quote 1
                                            • 2 / 3
