    Total Newbie 24" MagicMirror (Munich, Germany)
    42 Posts 13 Posters 51.1k Views 13 Watching
    • thedoorsfanaticT Offline
      thedoorsfanatic @ejay-ibm
      @ejay-ibm
      Since there is no frame there is also no actual back besides the backside of the monitor.
      The Raspi is sitting on a shelf below the mirror
      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
        thedoorsfanatic
        Quick update:
        https://youtu.be/xpJ4ubovD_o
        Now with a Philips Hue Lightstrip in the back of the mirror
          Aries1984 Module Developer
          Hi there…looks great! What module did you use for the countdown?
          thedoorsfanaticT 1 Reply Last reply Reply Quote 1
            thedoorsfanatic @Aries1984
            @Aries1984
            Thanks a lot!
            I used MMM-CountDown:
            https://github.com/boazarad/MMM-CountDown
              thedoorsfanatic
              Now also with Local Transport module:
              https://youtu.be/xoh6VZHyznY
              Nun wird mir morgens auf dem Magic Mirror meine tägliche Pendelstrecke über die Google Maps API angezeigt.
                thedoorsfanatic
                New update with PIR sensor and new modules: Wunderlist to-dos, SoccerLiveScore & fuel prices in a range of a certain distance to my home:
                https://youtu.be/5Cs3pCZamuM
                  dxfan227
                  Looks good, can I ask what kind of glassed you used. For me I want someting a little more Mirror like…your’s looks good but appeakrs not so reflective? A little more like clear acrylic.
                  Which PIR module did you use? and With PIR hardware?
                    thedoorsfanatic @dxfan227
                    @dxfan227
                    Thanks a lot!
                    I used Mirropane™ Chrome Spy glas, 4 mm thick, next time I might get 6 mm.
                    PIR hardware: https://amzn.to/2YNSxYr
                    Module: https://github.com/paviro/MMM-PIR-Sensor
                      thedoorsfanatic
                      I integrated two new modules into my MagicMirror:
                      • MMM-GoogleFit
                      • MMM-GoogleMapsTraffic
                      Watch a short video:
                      https://youtu.be/Z1bWmxJHmAQ
                      German:
                      Meinem MagicMirror habe ich zwei neue Module hinzugefügt: Tägliche Schrittanzahl meiner Garmin Fitness Watch und Körpergewicht, synchronisiert über Google Fit. Dazu eine Google Map meiner Umgebung inklusive aktueller Stauanzeige.
                        thedoorsfanatic
                        https://youtu.be/VEH_AFpjQgM
                        Experimenting with Background Slideshow module on my test monitor before inserting new functions into my Smart Mirror …
                        Auf meinem Test-Monitor experimentiere ich mit dem Background Slideshow Modul herum, bevor ich meinem Smart Mirror neue Funktionen hinzufüge …
                          thedoorsfanatic
                          https://youtu.be/frFSshaYkjw
                          My Smart Mirror will now show the birthdays from my Google Contacts. In addition, the IP of two smartphones is polled every 30 seconds to check when a person was connected to the home network.
                          German translation:
                          Auf meinem Smart Mirror werden nun auch die Geburtstage aus meinen Google Kontakten angezeigt. Zusätzlich wird alle 30 Sekunden die IP zweier Smartphones abgefragt, um zu checken, wann eine Person mit dem heimischen Netzwerk verbunden war.
                          • strawberry 3.141S Offline
                            strawberry 3.141 Project Sponsor Module Developer @thedoorsfanatic
                            @thedoorsfanatic Looks nice and clean. Good job on the build.
                            Greetings from Munich
                            • H Offline
                              hayman @thedoorsfanatic
                              @thedoorsfanatic said in Total Newbie 24" MagicMirror (Munich, Germany):
                              .currentweather .wi-day-sunny {
                              content: url(“/css/icons/day.svg”);
                              nicely done will you please send your custom.css files ,thanks
                              thedoorsfanaticT 1 Reply Last reply Reply Quote 0
                                thedoorsfanatic @hayman
                                @hayman
                                What exactly do you wanna know?
                                • H Offline
                                  @thedoorsfanatic which size do you use and the folders,thanks
                                    thedoorsfanatic
                                    Back in the Lab to test new functions for my Magic Mirror. Today I started working on a German word clock…
                                    https://youtu.be/qa2UFx_EEK0
                                    FoziF 1 Reply Last reply Reply Quote 1
                                    • FoziF Offline
                                      Fozi Project Sponsor @thedoorsfanatic
                                      @thedoorsfanatic that look great!
                                      BTW, I live close to Munich, too😁
                                        thedoorsfanatic @Fozi
                                        @Fozi
                                        Thanks, I appreciate it but your MM looks much nicer, I am jealous
                                        • FoziF Offline
                                          @thedoorsfanatic Come on, don’t be so humble!
                                            thedoorsfanatic
                                            Improving the layout and testing the new German Word Clock function …
                                            https://youtu.be/pRcDmjuu4vU
                                            • 2 / 3
