    Total Newbie 24" MagicMirror (Munich, Germany)
    42 Posts 13 Posters 50.0k Views 13 Watching
    • thedoorsfanaticT Offline
      thedoorsfanatic
      Now also with Local Transport module:
      https://youtu.be/xoh6VZHyznY
      Nun wird mir morgens auf dem Magic Mirror meine tägliche Pendelstrecke über die Google Maps API angezeigt.
      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
        thedoorsfanatic
        New update with PIR sensor and new modules: Wunderlist to-dos, SoccerLiveScore & fuel prices in a range of a certain distance to my home:
        https://youtu.be/5Cs3pCZamuM
          dxfan227
          Looks good, can I ask what kind of glassed you used. For me I want someting a little more Mirror like…your’s looks good but appeakrs not so reflective? A little more like clear acrylic.
          Which PIR module did you use? and With PIR hardware?
          thedoorsfanaticT 1 Reply Last reply Reply Quote 1
            thedoorsfanatic @dxfan227
            @dxfan227
            Thanks a lot!
            I used Mirropane™ Chrome Spy glas, 4 mm thick, next time I might get 6 mm.
            PIR hardware: https://amzn.to/2YNSxYr
            Module: https://github.com/paviro/MMM-PIR-Sensor
              thedoorsfanatic
              I integrated two new modules into my MagicMirror:
              • MMM-GoogleFit
              • MMM-GoogleMapsTraffic
              Watch a short video:
              https://youtu.be/Z1bWmxJHmAQ
              German:
              Meinem MagicMirror habe ich zwei neue Module hinzugefügt: Tägliche Schrittanzahl meiner Garmin Fitness Watch und Körpergewicht, synchronisiert über Google Fit. Dazu eine Google Map meiner Umgebung inklusive aktueller Stauanzeige.
                thedoorsfanatic
                https://youtu.be/VEH_AFpjQgM
                Experimenting with Background Slideshow module on my test monitor before inserting new functions into my Smart Mirror …
                Auf meinem Test-Monitor experimentiere ich mit dem Background Slideshow Modul herum, bevor ich meinem Smart Mirror neue Funktionen hinzufüge …
                  thedoorsfanatic
                  https://youtu.be/frFSshaYkjw
                  My Smart Mirror will now show the birthdays from my Google Contacts. In addition, the IP of two smartphones is polled every 30 seconds to check when a person was connected to the home network.
                  German translation:
                  Auf meinem Smart Mirror werden nun auch die Geburtstage aus meinen Google Kontakten angezeigt. Zusätzlich wird alle 30 Sekunden die IP zweier Smartphones abgefragt, um zu checken, wann eine Person mit dem heimischen Netzwerk verbunden war.
                  • strawberry 3.141S Offline
                    strawberry 3.141 Project Sponsor Module Developer @thedoorsfanatic
                    @thedoorsfanatic Looks nice and clean. Good job on the build.
                    Greetings from Munich
                    • H Offline
                      hayman @thedoorsfanatic
                      @thedoorsfanatic said in Total Newbie 24" MagicMirror (Munich, Germany):
                      .currentweather .wi-day-sunny {
                      content: url(“/css/icons/day.svg”);
                      nicely done will you please send your custom.css files ,thanks
                      thedoorsfanaticT 1 Reply Last reply Reply Quote 0
                        thedoorsfanatic @hayman
                        @hayman
                        What exactly do you wanna know?
                        • H Offline
                          @thedoorsfanatic which size do you use and the folders,thanks
                            thedoorsfanatic
                            Back in the Lab to test new functions for my Magic Mirror. Today I started working on a German word clock…
                            https://youtu.be/qa2UFx_EEK0
                            FoziF 1 Reply Last reply Reply Quote 1
                            • FoziF Offline
                              Fozi Project Sponsor @thedoorsfanatic
                              @thedoorsfanatic that look great!
                              BTW, I live close to Munich, too😁
                                thedoorsfanatic @Fozi
                                @Fozi
                                Thanks, I appreciate it but your MM looks much nicer, I am jealous
                                • FoziF Offline
                                  @thedoorsfanatic Come on, don’t be so humble!
                                    thedoorsfanatic
                                    Improving the layout and testing the new German Word Clock function …
                                    https://youtu.be/pRcDmjuu4vU
                                    • kusselinK Offline
                                      kusselin
                                      H, du hast ne PM
                                      Die Bundeligatabelle…hast du das mit diesem Modul hier
                                      MMM-soccer
                                      realisiert?
                                      Gruss
                                      thedoorsfanaticT LordyL 2 Replies Last reply Reply Quote 1
                                        thedoorsfanatic @kusselin
                                        @kusselin
                                        Hi Markus,
                                        die Fussballergebnisse hab ich mit diesem Modul realisiert:
                                        https://github.com/LukeSkywalker92/MMM-SoccerLiveScore
                                        • kusselinK Offline
                                          kusselin
                                          Hi, dachte ich mir schon…hast du meine PN bekommen. Wäre das machbar?
                                          Gruss
                                          • LordyL Offline
                                            Lordy @kusselin
                                            @kusselin Ich will mich nicht einmischen, aber schau Dir das Modul mal an. Davon bin ich überzeugt. https://github.com/master117/MagicMirror-FootballLeagues.git
                                            • 2 / 3
