    LED display shines through
    20 Posts 8 Posters 8.7k Views 7 Watching
    • H Offline
      hannes23
      I have a LG PHILIPS LP156WH2 (TL)(QB) LED Display behind this 2-way mirror from briga (btw realy good pricing and fast delivery!).
      Problem is, that the display shines through, even the Black areas are clearly visible even on low brightness and contrast. which in my opinion compleatly breaks the immersion. There is no more magic , it is just a screen behind a mirror.
      Does anyone have an idea how to avoid this and get only light areas to be seen?
      • justjim1220J Offline
        justjim1220 Module Developer @hannes23
        @hannes23
        Make sure the mirror is right up against the monitor screen, otherwise, you may be getting a reflection from the monitor on the back of the mirror causing shadows.
        "Life's Too Short To Dance With Ugly People"
        Jim Hallock - 1995
        • H Offline
          hannes23
          Thank you for your reply.
          The mirror is laying directly on the display (I am in a pre-assembly state). I think the led monitor can not display true black due to it’s backlight.
          I am thinking about something like a black foil between monitor and mirror, which makes the whole screen darker and then set the contrast to maximum?
          Maybe someone had similar problems and got a solution. Or a suggestion for a better 15’’ display?
          • F Offline
            francislallen
            Ensure the mirror is straight facing the screen, else, you might get a reflection from the screen on the back of the mirror causing shadows. Check more.
              maiky09
              Did someone find any soltion. PLEASE HELP US…
              • bheplerB Offline
                bhepler Module Developer
                Unfortunately, I think your only options are to either 1) replace the glass with a type that doesn’t transmit as much light through it (lower % rating) or 2) replace the monitor with a better quality one.
                  maiky09 @bhepler
                  @bhepler Thanks for the reply. That’s right, I’ll have to change the monitor. Can you give me some specifications to keep in mind when buying the monitor?
                    A Former User @maiky09
                    @maiky09
                    LP156WH2 insists 200nits as brightness, but usual LED panels also have 200~250nits. You need to choice higher contrast than LP156WH2(1:400).
                    Of course, There could be nicer panels - By example, Apple - 500nits, 1:1350 Lenovo X1 Extreme(1G) UHD - 500 nits, 1:1414. You can compare those values as reference which panel you will buy.
                    WARNING RPI can only handle up to FHD(1920*1080). So above panels mentioned are useless for RPI
                    Anyway the absolute answer will be OLED panel, it could give a real Black. Unfortunately that is still too expensive for MM.
                      maiky09 @Guest
                      @Sean Thank you very much for your reply. Wou this makes me more difficult and more expensive.
                      SergeS 1 Reply Last reply Reply Quote 0
                      • SergeS Offline
                        Serge
                        • SergeS Offline
                          Serge @maiky09
                          @maiky09 I have found that displays made with PLS technology emit better “dark” color as compared to displays made based on the IPS (and TFT) technology. Think about it.
                            A Former User @Serge
                            @Serge @maiky09
                            • PLS and IPS are almost same… SAMSUNG call their IPS as PLS rather than LG call theirs IPS. Due to patent, SAMSUNG cannot use the word IPS. both two are slightly different but almost same.
                            • If you want to get more high contrast ratio, consider VA panel. There be various - MVA, PVA/S-PVA, A-MVA/A-MVA+ but almost same too. (AH-VA is some kind of IPS. Don’t be confused.)
                              • The cons of VA panel - late response speed. afterimage would happen. So it rarely be adopted as screen of notebook.(and duralibility issue)
                                Anyway, usually we don’t use MM as movie player, so it might not be the issue.
                              • The pros of VA panel - Cheap, low light leak, darker black, higher contrast (than IPS)
                              • contrast ratio of VA is usually 1:3000 ~ 1:5000 while IPS usually be 1:1000.
                            • There is another option TN panel. High latency is good point but somehow useless for MM. color is not correct by angle.
                            But remember; the higher(expensive) of type A is better than the lower(cheap) of type B always.
                            SergeS M 2 Replies Last reply Reply Quote 0
                            • SergeS Offline
                              Serge @Guest
                              @Sean said in LED display shines through:
                              VA
                              sorry for misunderstanding.
                              I kept in mind and thought about VA but typed PLS.
                              Of course the diff in IPS and VA is visible especially in dark color, due to the higher contrast in the last one.
                              You are right.
                              Late response speed is not an issues for MM projects I think.
                                maiky09 @Guest
                                @Sean Thank you very much for that info. I need a monitor between 17 to 19 inches. I’ll see if I can find something.
                                  maiky09 @Guest
                                  @Sean Can you please tell me if this monitor is going to work for me? Please look at the specs. Thank you.
                                  https://www.pcliquidations.com/p76265-dell-p2017h-20-led
                                  • SergeS Offline
                                    Serge @maiky09
                                    @maiky09 it is not VA. Check all monitors suitable for you in terms of size/price and check at other website which type of matrix these LCD have. As was said above, the best option is VA (Vertical Alignment)
                                      dazza120
                                      Look in the show your mirror, must say I’ve not had that problem with mine, SamsungTV with a RPI https://forum.magicmirror.builders/category/12/show-your-mirror
                                        maiky09
                                        I decided to buy the one in the following link:
                                        https://www.amazon.com/dp/B07743412C/ref=cm_sw_r_cp_apa_i_STy5Cb4YQ0TKH
                                        I know it’s not VA, but I saw a tutorial recommending it, and the work went well. I hope it works for me.
                                          @maiky09
                                          Finally, it depends on your environment where MM is used. So IPS (easy to get) could be enough Or even VA couldn’t. With low transparency of spymirror, 1:5000 contrast might not be satisfied at all on strong daylight condition.
                                          The only point I want to tell is to consider FHD (1920*1080). It is the max resolution which RPI can handle (but if you consider other SBC like ATB, RockPi, Odroid, Nvidia Jetson, … etc. 4K could be available). You may probably need more real-estate to show other cool info.
                                            maiky09 @Guest
                                            @Sean Again, thank you very much for everything. Excellent information.
