    MMM-GoogleMapsTraffic freezes Magic Mirror
    21 Posts 7 Posters 9.2k Views 10 Watching
      dazza120 @MacMirror
      @macmirror yep I too have the problem of the mirror crashing on me with this module I have no idea how to fix it either.
        MadScientist
        I suspected this module for a while already but I never bothered to get into it. Whenever somebody reported random crashes after some hours they used the MMM-GoogleMapsTraffic module. In my case it is enough to run a cronjob once a day to reload the mirror.
        • E Offline
          Ernst-Jan
          I have te same probleem with the error MMM-GoogleMapsTraffic.js:77 Uncaught TypeError: Cannot read property ‘length’ of undefined.
          Do some one now what that means
            drfukc
            I have the same issue. When I boot up the Magic Mirror in debug mode npm start dev & but the Chrome console tab tells me this nasty thing:
            "You have included the Google Maps JavaScript API multiple times on this page."
            "This may cause unexpected errors."
            However, everything looks perfectly nice on my MagicMirror.
            All modules are successfully loaded, including “MMM-GoogleMapsTraffic”.
            But on the next day, the latest my screen is entirely black.
            It’s exactly the same thing as reported in this thread.
              sdetweil @drfukc
              @drfukc it appears the api had trouble, and the module did not handle the error
                drfukc
                yes, that’s the case, the module is running fine until it turns the monitor black (after several hours).
                There are more people in different threads having the same issue.
                The module author does not seem to respond.
                My workaround is a regular cron job restarting the MagicMirror.
                  sdetweil @drfukc
                  @drfukc I am away til later today. I will look at it. One of my modules gets photos from google
                    dazza120
                    Yep same I use cron job but would rather not have too, also this might be where all my ram goes as well, great if someone can look at this module
                      anybody want to try my updates
                      1. load script once, once dom created
                      2. improve process , handle lost config error
                      https://github.com/sdetweil/MMM-GoogleMapsTraffic
                      rename your existing folder out of the way
                      then, from MM/modules folder, git clone my repo, and restart MM
                      no changes to module config
                        dazza120 @sdetweil
                        @sdetweil I’m getting this when I try to do my that
                        pi@raspberrypi:~/MagicMirror/modules $ git pull https://github.com/sdetweil/MMM-GoogleMapsTraffic
                        warning: no common commits
                        remote: Enumerating objects: 3, done.
                        remote: Counting objects: 100% (3/3), done.
                        remote: Compressing objects: 100% (3/3), done.
                        remote: Total 123 (delta 0), reused 1 (delta 0), pack-reused 120
                        Receiving objects: 100% (123/123), 231.52 KiB | 0 bytes/s, done.
                        Resolving deltas: 100% (53/53), done.
                        From https://github.com/sdetweil/MMM-GoogleMapsTraffic
                         * branch            HEAD       -> FETCH_HEAD
                        fatal: refusing to merge unrelated histories
