    MMM-GoogleMapsTraffic freezes Magic Mirror
    21 Posts 7 Posters 11.0k Views 10 Watching
      drfukc
      yes, that’s the case, the module is running fine until it turns the monitor black (after several hours).
      There are more people in different threads having the same issue.
      The module author does not seem to respond.
      My workaround is a regular cron job restarting the MagicMirror.
        sdetweil @drfukc
        @drfukc I am away til later today. I will look at it. One of my modules gets photos from google
          dazza120
          Yep same I use cron job but would rather not have too, also this might be where all my ram goes as well, great if someone can look at this module
            anybody want to try my updates
            1. load script once, once dom created
            2. improve process , handle lost config error
            https://github.com/sdetweil/MMM-GoogleMapsTraffic
            rename your existing folder out of the way
            then, from MM/modules folder, git clone my repo, and restart MM
            no changes to module config
              dazza120 @sdetweil
              @sdetweil I’m getting this when I try to do my that
              pi@raspberrypi:~/MagicMirror/modules $ git pull https://github.com/sdetweil/MMM-GoogleMapsTraffic
              warning: no common commits
              remote: Enumerating objects: 3, done.
              remote: Counting objects: 100% (3/3), done.
              remote: Compressing objects: 100% (3/3), done.
              remote: Total 123 (delta 0), reused 1 (delta 0), pack-reused 120
              Receiving objects: 100% (123/123), 231.52 KiB | 0 bytes/s, done.
              Resolving deltas: 100% (53/53), done.
              From https://github.com/sdetweil/MMM-GoogleMapsTraffic
               * branch            HEAD       -> FETCH_HEAD
              fatal: refusing to merge unrelated histories
                sdetweil @dazza120
                @dazza120 said in MMM-GoogleMapsTraffic freezes Magic Mirror:
                no… cannot do that… cannot merge mine with the original
                what i said in my prior most
                u must git clone my repo … so you had to rename the old folder out of the way
                from MagicMirror/modules
                mv MMM-GoogleMapsTraffic MMM-GoogleMapsTraffic.original
                then
                git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git
                  dazza120 @sdetweil
                  @sdetweil done mate testing it now
                    dazza120
                    It’s taken a day or so before it went black, but something is burning the ram it hovers on 4% to 5% free memory
                      sdetweil @dazza120
                      @dazza120 hm… i am using the default config with my geolocation
                      and its runs for days and days…
                        dazza120 @sdetweil
                        @sdetweil what is the update times on the maps? Are you using a Pi?
                          sdetweil @dazza120
                          @dazza120 default update cycle is 900,000 milliseconds… so, 15 minutes
                          I am using an odroid XU4, faster than pi…
                          D J 3 Replies Last reply Reply Quote 1
                            dazza120 @sdetweil
                            @sdetweil I take it, it has more ram than the Pi too? Which could be why you’ve not experienced it
                              juantata @sdetweil
                                juantata @sdetweil
                                @sdetweil Hi. It gives me this error.
                                  sdetweil @juantata
                                  @juantata width is missing a comma
