    MMM-GoogleMapsTraffic freezes Magic Mirror
    21 Posts 7 Posters 11.6k Views 10 Watching
      anybody want to try my updates
      1. load script once, once dom created
      2. improve process , handle lost config error
      https://github.com/sdetweil/MMM-GoogleMapsTraffic
      rename your existing folder out of the way
      then, from MM/modules folder, git clone my repo, and restart MM
      no changes to module config
        dazza120 @sdetweil
        @sdetweil I’m getting this when I try to do my that
        pi@raspberrypi:~/MagicMirror/modules $ git pull https://github.com/sdetweil/MMM-GoogleMapsTraffic
        warning: no common commits
        remote: Enumerating objects: 3, done.
        remote: Counting objects: 100% (3/3), done.
        remote: Compressing objects: 100% (3/3), done.
        remote: Total 123 (delta 0), reused 1 (delta 0), pack-reused 120
        Receiving objects: 100% (123/123), 231.52 KiB | 0 bytes/s, done.
        Resolving deltas: 100% (53/53), done.
        From https://github.com/sdetweil/MMM-GoogleMapsTraffic
         * branch            HEAD       -> FETCH_HEAD
        fatal: refusing to merge unrelated histories
          sdetweil @dazza120
          @dazza120 said in MMM-GoogleMapsTraffic freezes Magic Mirror:
          no… cannot do that… cannot merge mine with the original
          what i said in my prior most
          u must git clone my repo … so you had to rename the old folder out of the way
          from MagicMirror/modules
          mv MMM-GoogleMapsTraffic MMM-GoogleMapsTraffic.original
          then
          git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git
            dazza120 @sdetweil
            @sdetweil done mate testing it now
              dazza120
              It’s taken a day or so before it went black, but something is burning the ram it hovers on 4% to 5% free memory
                sdetweil @dazza120
                @dazza120 hm… i am using the default config with my geolocation
                and its runs for days and days…
                  dazza120 @sdetweil
                  @sdetweil what is the update times on the maps? Are you using a Pi?
                    sdetweil @dazza120
                    @dazza120 default update cycle is 900,000 milliseconds… so, 15 minutes
                    I am using an odroid XU4, faster than pi…
                    D J 3 Replies Last reply Reply Quote 1
                      dazza120 @sdetweil
                      @sdetweil I take it, it has more ram than the Pi too? Which could be why you’ve not experienced it
                        juantata @sdetweil
                          juantata @sdetweil
                          @sdetweil Hi. It gives me this error.
                            sdetweil @juantata
                            @juantata width is missing a comma
