    MMM-GoogleMapsTraffic freezes Magic Mirror
    21 Posts 7 Posters 11.0k Views 10 Watching
      MacMirror
      For a long time a had the issue that MagicMirror freezes after a couple of hours. Finally I found out that after disabling the module GoogleMapsTrafic the error won’t occur.
      In the console the module produces 2 errors:
      js?key=xxxxxxxxxx:121 You have included the Google Maps JavaScript API multiple times on this page. This may cause unexpected errors.
      sh @ js?key= xxxxxxxxxx:121
      Ah @ js?key= xxxxxxxxxx:119
      google.maps.Load @ js?key= xxxxxxxxxx:18
      (anonymous) @ js?key= xxxxxxxxxx:208
      MMM-GoogleMapsTraffic.js:77 Uncaught TypeError: Cannot read property 'length' of undefined
          at HTMLScriptElement.script.onload (MMM-GoogleMapsTraffic.js:77)
      script.onload @ MMM-GoogleMapsTraffic.js:77
      My config is quite simple and I couldn’t find a way to avoid these errors.
              	module: 'MMM-GoogleMapsTraffic',
      	      	position: 'center',
                      	key: 'xxxxxxxxxx',
                      	lat: 52.5202362,
                      	lng: 13.3663832,
                      	height: '800px',
                      	width: '780px',
      			zoom: 12,
      			updateInterval: 300000, //5 Minuten
      			styledMapType: 'standard',
                      	disableDefaultUI: true,
      Does anybody experiences this problem?
      Every help is highly appreciated.
      D 1 Reply Last reply Reply Quote 2
        dazza120 @MacMirror
        @macmirror yep I too have the problem of the mirror crashing on me with this module I have no idea how to fix it either.
          MadScientist
          I suspected this module for a while already but I never bothered to get into it. Whenever somebody reported random crashes after some hours they used the MMM-GoogleMapsTraffic module. In my case it is enough to run a cronjob once a day to reload the mirror.
          • E Offline
            Ernst-Jan
            I have te same probleem with the error MMM-GoogleMapsTraffic.js:77 Uncaught TypeError: Cannot read property ‘length’ of undefined.
            Do some one now what that means
              drfukc
              I have the same issue. When I boot up the Magic Mirror in debug mode npm start dev & but the Chrome console tab tells me this nasty thing:
              "You have included the Google Maps JavaScript API multiple times on this page."
              "This may cause unexpected errors."
              However, everything looks perfectly nice on my MagicMirror.
              All modules are successfully loaded, including “MMM-GoogleMapsTraffic”.
              But on the next day, the latest my screen is entirely black.
              It’s exactly the same thing as reported in this thread.
                sdetweil @drfukc
                @drfukc it appears the api had trouble, and the module did not handle the error
                  drfukc
                  yes, that’s the case, the module is running fine until it turns the monitor black (after several hours).
                  There are more people in different threads having the same issue.
                  The module author does not seem to respond.
                  My workaround is a regular cron job restarting the MagicMirror.
                    sdetweil @drfukc
                    @drfukc I am away til later today. I will look at it. One of my modules gets photos from google
                      dazza120
                      Yep same I use cron job but would rather not have too, also this might be where all my ram goes as well, great if someone can look at this module
                        anybody want to try my updates
                        1. load script once, once dom created
                        2. improve process , handle lost config error
                        https://github.com/sdetweil/MMM-GoogleMapsTraffic
                        rename your existing folder out of the way
                        then, from MM/modules folder, git clone my repo, and restart MM
                        no changes to module config
                          dazza120 @sdetweil
                          @sdetweil I’m getting this when I try to do my that
                          pi@raspberrypi:~/MagicMirror/modules $ git pull https://github.com/sdetweil/MMM-GoogleMapsTraffic
                          warning: no common commits
                          remote: Enumerating objects: 3, done.
                          remote: Counting objects: 100% (3/3), done.
                          remote: Compressing objects: 100% (3/3), done.
                          remote: Total 123 (delta 0), reused 1 (delta 0), pack-reused 120
                          Receiving objects: 100% (123/123), 231.52 KiB | 0 bytes/s, done.
                          Resolving deltas: 100% (53/53), done.
                          From https://github.com/sdetweil/MMM-GoogleMapsTraffic
                           * branch            HEAD       -> FETCH_HEAD
                          fatal: refusing to merge unrelated histories
                            sdetweil @dazza120
                            @dazza120 said in MMM-GoogleMapsTraffic freezes Magic Mirror:
                            no… cannot do that… cannot merge mine with the original
                            what i said in my prior most
                            u must git clone my repo … so you had to rename the old folder out of the way
                            from MagicMirror/modules
                            mv MMM-GoogleMapsTraffic MMM-GoogleMapsTraffic.original
                            then
                            git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git
                              dazza120 @sdetweil
                              @sdetweil done mate testing it now
                                dazza120
                                It’s taken a day or so before it went black, but something is burning the ram it hovers on 4% to 5% free memory
                                  sdetweil @dazza120
                                  @dazza120 hm… i am using the default config with my geolocation
                                  and its runs for days and days…
                                    dazza120 @sdetweil
                                    @sdetweil what is the update times on the maps? Are you using a Pi?
                                      sdetweil @dazza120
                                      @dazza120 default update cycle is 900,000 milliseconds… so, 15 minutes
                                      I am using an odroid XU4, faster than pi…
                                      D J 3 Replies Last reply Reply Quote 1
                                        dazza120 @sdetweil
                                        @sdetweil I take it, it has more ram than the Pi too? Which could be why you’ve not experienced it
                                          juantata @sdetweil
                                            juantata @sdetweil
                                            @sdetweil Hi. It gives me this error.
