    MMM-GoogleMapsTraffic freezes Magic Mirror
    21 Posts 7 Posters 9.2k Views 10 Watching
      drfukc
      I have the same issue. When I boot up the Magic Mirror in debug mode npm start dev & but the Chrome console tab tells me this nasty thing:
      "You have included the Google Maps JavaScript API multiple times on this page."
      "This may cause unexpected errors."
      However, everything looks perfectly nice on my MagicMirror.
      All modules are successfully loaded, including “MMM-GoogleMapsTraffic”.
      But on the next day, the latest my screen is entirely black.
      It’s exactly the same thing as reported in this thread.
        sdetweil @drfukc
        @drfukc it appears the api had trouble, and the module did not handle the error
          drfukc
          yes, that’s the case, the module is running fine until it turns the monitor black (after several hours).
          There are more people in different threads having the same issue.
          The module author does not seem to respond.
          My workaround is a regular cron job restarting the MagicMirror.
            sdetweil @drfukc
            @drfukc I am away til later today. I will look at it. One of my modules gets photos from google
              dazza120
              Yep same I use cron job but would rather not have too, also this might be where all my ram goes as well, great if someone can look at this module
                anybody want to try my updates
                1. load script once, once dom created
                2. improve process , handle lost config error
                https://github.com/sdetweil/MMM-GoogleMapsTraffic
                rename your existing folder out of the way
                then, from MM/modules folder, git clone my repo, and restart MM
                no changes to module config
                  dazza120 @sdetweil
                  @sdetweil I’m getting this when I try to do my that
                  pi@raspberrypi:~/MagicMirror/modules $ git pull https://github.com/sdetweil/MMM-GoogleMapsTraffic
                  warning: no common commits
                  remote: Enumerating objects: 3, done.
                  remote: Counting objects: 100% (3/3), done.
                  remote: Compressing objects: 100% (3/3), done.
                  remote: Total 123 (delta 0), reused 1 (delta 0), pack-reused 120
                  Receiving objects: 100% (123/123), 231.52 KiB | 0 bytes/s, done.
                  Resolving deltas: 100% (53/53), done.
                  From https://github.com/sdetweil/MMM-GoogleMapsTraffic
                   * branch            HEAD       -> FETCH_HEAD
                  fatal: refusing to merge unrelated histories
                    sdetweil @dazza120
                    @dazza120 said in MMM-GoogleMapsTraffic freezes Magic Mirror:
                    no… cannot do that… cannot merge mine with the original
                    what i said in my prior most
                    u must git clone my repo … so you had to rename the old folder out of the way
                    from MagicMirror/modules
                    mv MMM-GoogleMapsTraffic MMM-GoogleMapsTraffic.original
                    then
                    git clone https://github.com/sdetweil/MMM-GoogleMapsTraffic.git
                      dazza120 @sdetweil
                      @sdetweil done mate testing it now
                        dazza120
                        It’s taken a day or so before it went black, but something is burning the ram it hovers on 4% to 5% free memory
