    MMM-EasyBack no autostart Video
    35 Posts 4 Posters 19.3k Views 4 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor
      I would like to have the funny monkeys from the MMM-EasyBack YouTube Video but the video does not start automatically and I don’t know how to start manually.
      Thanks for help🙏
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe this is due to a new restriction on the browser
        do this
        edit MagicMirror/js/electron.js
        and add the line shown below
        let mainWindow;
        function createWindow() {
            app.commandLine.appendSwitch('autoplay-policy', 'no-user-gesture-required');  //< -------- added
        save and restart MagicMirror
          Thanks i will try this later today
          Thanks 👍🏽👍🏽
            Hi, I have added the line than MM does not start…
              @Stoffbeuteluwe show me the few lines.
              I cut pasted from mine.
              Watch. out for the quotes, sometimes paste creates the wrong ones
                I can confirm that this fix DOES work. I installed the newest MM 2.7.1 and the “autostart video” was indeed not working. Many thanks to you, @sdetweil, for saving the day. :thumbsup:
                Here is a screen shot of how the edit should look in case anyone would like a visual.
                  [card:mykle1/MMM-EasyBack]
                  Update
                  • The easiest way to use video and pictures as a background on your mirror.
                  • Use a YouTube video as a live background with just the YouTube ID of the video.
                  • Works by default with Hello-Lucy voice. https://github.com/mykle1/Hello-Lucy.
                  • .jpg files, .png files, .gif files, Full Screen animated gifs (not recommended for Pi users).
                  • .mp4 and .mov files (others not tested).
                    Ok i will try again 😀
                      Perfect thank you…:folded_hands:
                        Darkmx-6
                        So I’m not sure what’s going on with mine because it won’t autostart. I did all the changes suggested and below is a copy straight out of the MagicMirror/js/electron.js file.
                        I’ve restarted it many times.
                        Before I edited it it had everything there except
                        was
                        "autoplay-policy", "no-user-gesture-required"
                        let mainWindow;
                                var electronOptionsDefaults = {
                                        width: 800,
                                        height: 600,
                                        x: 0,
                                        y: 0,
                                        darkTheme: true,
                                        webPreferences: {
                                                nodeIntegration: false,
                                                zoomFactor: config.zoom
                                        backgroundColor: "#000000"
                          sdetweil @Darkmx-6
                          @Darkmx-6 can you open the developers window, using ctrl-shift-i on the keyboard, select the tab labeled console at the top of that window, and scroll up to see any info, or errors…
                          u can also filter for just messages from a single module by putting part of the module name in the filter entryfield
                            Darkmx-6
                            @sdetweil said in MMM-EasyBack no autostart Video:
                            Sure, I can do that, but is there a way to do that through the console? To physically access the pi I have to climb a ladder. I’m going to do that now but it would be awesome if I don’t have to next time.
                              sdetweil @Darkmx-6
                              @Darkmx-6 not that I have found
                                Darkmx-6 @sdetweil
                                Humm… ctrl shift i doesn’t seem to work. may be it is just slow, I’m rebooting now and am going to try again. I’m using a raspberry pi zero.
                                  Darkmx-6
                                  yeah, it does nothing… is there a way to access it with the mouse?
                                  My Keyboard is connected and working because I can quit magic mirror with the keyboard.
                                    sdetweil @Darkmx-6
                                    @Darkmx-6 all three keys together, ctrl-shift and the letter i (as in Initial)
                                      Darkmx-6
                                      yep, like if I’m hitting ctrl + alt + delete correct?
                                      instead it’s ctrl shift i
                                        sdetweil @Darkmx-6
                                        @Darkmx-6 correct
                                          Darkmx-6
                                          Yeah I can’t get it to come up.
                                          I’m not sure what else I can do.
                                            sdetweil @Darkmx-6
                                            @Darkmx-6 if u can change the startup, npm start dev opens the developers window
