    MMM-EasyBack no autostart Video
    35 Posts 4 Posters 20.0k Views 4 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor
      Ok i will try again 😀
      • StoffbeuteluweS
        Perfect thank you…:folded_hands:
          Darkmx-6
          So I’m not sure what’s going on with mine because it won’t autostart. I did all the changes suggested and below is a copy straight out of the MagicMirror/js/electron.js file.
          I’ve restarted it many times.
          Before I edited it it had everything there except
          'autoplay-policy', 'no-user-gesture-required'
          was
          "autoplay-policy", "no-user-gesture-required"
          let mainWindow;
          function createWindow() {
              app.commandLine.appendSwitch('autoplay-policy', 'no-user-gesture-required');  //< -------- added
                  var electronOptionsDefaults = {
                          width: 800,
                          height: 600,
                          x: 0,
                          y: 0,
                          darkTheme: true,
                          webPreferences: {
                                  nodeIntegration: false,
                                  zoomFactor: config.zoom
                          backgroundColor: "#000000"
            sdetweil @Darkmx-6
            @Darkmx-6 can you open the developers window, using ctrl-shift-i on the keyboard, select the tab labeled console at the top of that window, and scroll up to see any info, or errors…
            u can also filter for just messages from a single module by putting part of the module name in the filter entryfield
              Darkmx-6
              @sdetweil said in MMM-EasyBack no autostart Video:
              Sure, I can do that, but is there a way to do that through the console? To physically access the pi I have to climb a ladder. I’m going to do that now but it would be awesome if I don’t have to next time.
                sdetweil @Darkmx-6
                @Darkmx-6 not that I have found
                  Darkmx-6 @sdetweil
                  Humm… ctrl shift i doesn’t seem to work. may be it is just slow, I’m rebooting now and am going to try again. I’m using a raspberry pi zero.
                    Darkmx-6
                    yeah, it does nothing… is there a way to access it with the mouse?
                    My Keyboard is connected and working because I can quit magic mirror with the keyboard.
                      sdetweil @Darkmx-6
                      @Darkmx-6 all three keys together, ctrl-shift and the letter i (as in Initial)
                        Darkmx-6
                        yep, like if I’m hitting ctrl + alt + delete correct?
                        instead it’s ctrl shift i
                          sdetweil @Darkmx-6
                          @Darkmx-6 correct
                            Darkmx-6
                            Yeah I can’t get it to come up.
                            I’m not sure what else I can do.
                              sdetweil @Darkmx-6
                              @Darkmx-6 if u can change the startup, npm start dev opens the developers window
                                Darkmx-6 @sdetweil
                                I am trying a clean install now
                                  Darkmx-6 @sdetweil
                                  is this the start file you are talking about?
                                  pi@raspberrypi:~ $ ls
                                  chromium_start.sh  mmstart.sh                  package-lock.json
                                  MagicMirror        node-v10.16.0-linux-armv6l
                                  pi@raspberrypi:~ $
                                  mmstart.sh?
                                  pi@raspberrypi:~ $ sudo nano mmstart.sh
                                    GNU nano 3.2                       mmstart.sh
                                  #!/bin/bash
                                  node serveronly &
                                  sleep 30
                                  xinit /home/pi/chromium_start.sh
                                  npm start dev
                                  Is that where it goes?
                                  Man doing this project makes me feel so dumb I need to learn more, any suggestions?
                                    Darkmx-6
                                    Oh an just to update with the clean install I had the same issue.
                                      Darkmx-6
                                      I am also now using a Raspberry Pi 3 B+
                                        Darkmx-6
                                        Well I ended up going to a static picture because I can’t think of what else to do.
                                          sdetweil @Darkmx-6
                                          @Darkmx-6 i don’t know where mmstart.sh came from… it is not part of the base MagicMirror solution.
                                          the MagicMirror start script is ~/MagicMirror/installers/mm.sh
                                          it does not run serveronly… it assumes you are running the mirror user experience ON the same machine.
                                          i don’t know if EasyBack works on the remote client of serveronly… THAT browser would have to enable autoplay… our fix was for the electron browser running ON the same machine
                                          edit:
                                          ok, i see what you are doing… using chromium for the browser for some reason…
                                          so u have to disable the autoplay blocker there , from
                                          https://developers.google.com/web/updates/2017/09/autoplay-policy-changes
                                          You can decide to disable entirely the autoplay policy by setting the
                                          Chrome flag "Autoplay Policy" to "No user gesture is required" at chrome://flags/#autoplay-policy.
                                          This allows you to test your website as if user were strongly engaged with your site and playback autoplay would be always allowed.
                                            Darkmx-6
                                            Ah I see! It works THANK YOU!
                                            Must be because of the pre-made image I installed MagicMirror with.
                                            Here is the link:
                                            http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/
                                            Here is the fix:
                                            I edited the file chromium_start.sh found here:
                                            chromium_start.sh  MagicMirror  mmstart.sh  node-v10.16.0-linux-armv6l  package-lock.json
                                            and added
                                            --autoplay-policy=no-user-gesture-required
                                            Example:
                                              GNU nano 3.2                          chromium_start.sh
                                            #!/bin/sh
                                            unclutter &
                                            xset -dpms # disable DPMS (Energy Star) features.
                                            xset s off # disable screen saver
                                            xset s noblank # don’t blank the video device
                                            matchbox-window-manager &
                                            #midori -e Fullscreen -a http://localhost:8080
                                            chromium-browser --autoplay-policy=no-user-gesture-required --incognito --kiosk http://localhost:8080/
                                            S Mykle1M 2 Replies Last reply Reply Quote 1
