    MMM-EasyBack no autostart Video
    35 Posts 4 Posters 19.5k Views 4 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor
      Hi, I have added the line than MM does not start…
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe show me the few lines.
        I cut pasted from mine.
        Watch. out for the quotes, sometimes paste creates the wrong ones
          I can confirm that this fix DOES work. I installed the newest MM 2.7.1 and the “autostart video” was indeed not working. Many thanks to you, @sdetweil, for saving the day. :thumbsup:
          Here is a screen shot of how the edit should look in case anyone would like a visual.
            [card:mykle1/MMM-EasyBack]
            Update
            • The easiest way to use video and pictures as a background on your mirror.
            • Use a YouTube video as a live background with just the YouTube ID of the video.
            • Works by default with Hello-Lucy voice. https://github.com/mykle1/Hello-Lucy.
            • .jpg files, .png files, .gif files, Full Screen animated gifs (not recommended for Pi users).
            • .mp4 and .mov files (others not tested).
              Ok i will try again 😀
                Perfect thank you…:folded_hands:
                  Darkmx-6
                  So I’m not sure what’s going on with mine because it won’t autostart. I did all the changes suggested and below is a copy straight out of the MagicMirror/js/electron.js file.
                  I’ve restarted it many times.
                  Before I edited it it had everything there except
                  'autoplay-policy', 'no-user-gesture-required'
                  was
                  "autoplay-policy", "no-user-gesture-required"
                  let mainWindow;
                  function createWindow() {
                      app.commandLine.appendSwitch('autoplay-policy', 'no-user-gesture-required');  //< -------- added
                          var electronOptionsDefaults = {
                                  width: 800,
                                  height: 600,
                                  x: 0,
                                  y: 0,
                                  darkTheme: true,
                                  webPreferences: {
                                          nodeIntegration: false,
                                          zoomFactor: config.zoom
                                  backgroundColor: "#000000"
                    sdetweil @Darkmx-6
                    @Darkmx-6 can you open the developers window, using ctrl-shift-i on the keyboard, select the tab labeled console at the top of that window, and scroll up to see any info, or errors…
                    u can also filter for just messages from a single module by putting part of the module name in the filter entryfield
                      Darkmx-6
                      @sdetweil said in MMM-EasyBack no autostart Video:
                      Sure, I can do that, but is there a way to do that through the console? To physically access the pi I have to climb a ladder. I’m going to do that now but it would be awesome if I don’t have to next time.
                        sdetweil @Darkmx-6
                        @Darkmx-6 not that I have found
                          Darkmx-6 @sdetweil
                          Humm… ctrl shift i doesn’t seem to work. may be it is just slow, I’m rebooting now and am going to try again. I’m using a raspberry pi zero.
                            Darkmx-6
                            yeah, it does nothing… is there a way to access it with the mouse?
                            My Keyboard is connected and working because I can quit magic mirror with the keyboard.
                              sdetweil @Darkmx-6
                              @Darkmx-6 all three keys together, ctrl-shift and the letter i (as in Initial)
                                Darkmx-6
                                yep, like if I’m hitting ctrl + alt + delete correct?
                                instead it’s ctrl shift i
                                  sdetweil @Darkmx-6
                                  @Darkmx-6 correct
                                    Darkmx-6
                                    Yeah I can’t get it to come up.
                                    I’m not sure what else I can do.
                                      sdetweil @Darkmx-6
                                      @Darkmx-6 if u can change the startup, npm start dev opens the developers window
                                        Darkmx-6 @sdetweil
                                        I am trying a clean install now
                                          Darkmx-6 @sdetweil
                                          is this the start file you are talking about?
                                          pi@raspberrypi:~ $ ls
                                          chromium_start.sh  mmstart.sh                  package-lock.json
                                          MagicMirror        node-v10.16.0-linux-armv6l
                                          pi@raspberrypi:~ $
                                          mmstart.sh?
                                          pi@raspberrypi:~ $ sudo nano mmstart.sh
                                            GNU nano 3.2                       mmstart.sh
                                          #!/bin/bash
                                          node serveronly &
                                          sleep 30
                                          xinit /home/pi/chromium_start.sh
                                          npm start dev
                                          Is that where it goes?
                                          Man doing this project makes me feel so dumb I need to learn more, any suggestions?
                                            Darkmx-6
                                            Oh an just to update with the clean install I had the same issue.
