    [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates
    76 Posts 13 Posters 77.3k Views 13 Watching
    • Cr4z33C Offline
      Cr4z33 @bolish
      @bolish sorry, but it is quite hard to get the difference for me lol. :smiling_face_with_open_mouth_cold_sweat:
      Do you mind doing please a pastebin of your edited node_helper.js so that I can try it out?
        bolish
        Just replace related lines by the following ones (it’s approx. around line 610) into your node.js :
                    if (["MONITORTOGGLE", "MONITORSTATUS", "MONITORON"].indexOf(action) !== -1) {
                        screenStatus = exec(monitorStatusCommand, opts, (error, stdout, stderr) => {
                            if (stdout.indexOf("power status: standby") !== -1 || stdout.indexOf("false") !== -1) { // MODIF DONE HERE
                                // Screen is OFF, turn it ON
                                status = "off";
                                if (action === "MONITORTOGGLE" || action === "MONITORON") {
                                    exec(monitorOnCommand, opts, (error, stdout, stderr) => {
                                        this.checkForExecError(error, stdout, stderr, res, { monitor: "on" });
                                    this.sendSocketNotification("USER_PRESENCE", true);
                                    return;
                            } else if (stdout.indexOf("power status: on") !== -1 || stdout.indexOf("true") !== -1) { // MODIF DONE HERE
                                // Screen is ON, turn it OFF
                                status = "on";
                                if (action === "MONITORTOGGLE") {
                                    this.monitorControl("MONITOROFF", opts, res);
                                    return;
        Cr4z33C 2 Replies Last reply Reply Quote 0
        • Cr4z33C Offline
          Cr4z33 @bolish
          @bolish OK thanks now the TV can be turned off succesfully, but still can’t be turned on ( although I keep getting the Done! confirmation message ) . :thinking_face:
          • Cr4z33C Offline
            Cr4z33 @bolish
            @bolish OK something weird happened.
            After let’s say 1 minute the TV turned ON by itself (can’t say really…) and there’s now no signal on the (proper) HDMI port.
            I have the feeling the module is still sending monitor commands and NOT cec-utils package ones! :thinking_face:
              bolish
              @Cr4z33 indeed, strange, I will check my code this evening (I did it by “memory” since this morning…).
              • Cr4z33C Offline
                Cr4z33 @Cr4z33
                @bolish in addition to what I wrote in my last post I forgot that I actually have entered the custom commands in the module config section so it is twice weird as it should execute those commands.
                  mohace @Cr4z33
                  @Cr4z33 said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                  @mohace huh?
                  I don’t have those menu’s entries at all.
                  Are you using a custom version of the module or? :confused_face:
                  Not at all. You can see same pic in shbatm second post, after the first one you replyed.
                  @shbatm said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
                  Additional Features Added:
                  • Dynamic Module Control menu – uses the new API to create a Module Control menu on the remote page to control other modules via notifications.
                  • Custom Menu – ability to specify your own custom menu items from a file (for advanced users)
                  • Use PM2 API to control restarts/stops of MM. Can also support starting/stopping other PM2 scripts by passing processName: “scriptToUse” in the query payload.
                  Example Dynamic Menu for MMM-Carousel w/ Navigation
                  It seems that you need activate some features in modules to show them in this menu. But I don’t know what needs Newsfeed, for to have active his entry.
                  • Cr4z33C Offline
                    Cr4z33 @mohace
                    @mohace Oh yes you are correct I forgot that we can have custom entries indeed.
                    Well in my case Newsfeed is showing up by default without having to enable manually something. :man_shrugging_light_skin_tone:
                    • L Offline
                      Lowis
                      I don’t have these entries
                      reinstalled twice the module without luck.
                      when i first installed this module the entries was there .
                      my config.js
                            module: 'MMM-Remote-Control',
                            position: 'bottom_left',
                              customCommand: {},
                              customMenu: 'custom_menu.json',
                              showModuleApiMenu: true,
                              apiKey: ''
                      • swvalentiS Offline
                        swvalenti Project Sponsor
                        Any idea why my remote control looks like this? It’s lacking the right buttons etc…0_1557623899958_MM.PNG
                        • Cr4z33C Offline
                          Cr4z33
                          I need to add some custom commands to control MMM-RTSPStream streams like if they were tv channel buttons, but I am not skilled enough to understand the interested readme section. :smiling_face_with_open_mouth_cold_sweat:
                          @shbatm could you please help me adding one stream button (as example for all the others to add)?
                          All I need is to run a combo of ‘RTSP-STOP all’ first (I am using OMXplayer therefore I prefer to kill any running stream first) and ‘RTSP-PLAY streamX’ immediately after.
                            When I press Restart MagicMirror it doesn’t restart…if I hit Refresh Browser the browser refreshes. Any idea why Restart MagicMirror command doesn’t work? Running latest updates on all platforms.
                              retroflex Project Sponsor Module Developer @swvalenti
                              @swvalenti Yeah, same here. Would really like to find an answer for this…
                              • Cr4z33C Offline
                                Cr4z33 @Cr4z33
                                @shbatm you there mate please? :smiling_face_with_halo:
                                • Cr4z33C Offline
                                  Cr4z33 @Cr4z33
                                  It looks like @shbatm is not following this forum since many months.
                                  Therefore @bolish or someone else could you please post your custom menu entries code so that I can better figure out how to enter that MMM-RTSPStream code?
                                  The related README section didn’t make so much sense to me. :man_shrugging_medium_skin_tone:
                                    BD0G
                                    Using Raspberry Pi Zero W with latest version of Buster. MM2 working . used command in first post to install MMM-RemoteControl. Used Master Branch and not Dev. Module directory created sucessfully. Edited config.js with appropriate entries. I dont have anything displaying on screen besides the clock and Holidays .
                                    Its supposed to display the default webpage in the center of the screen. I dont see that . Just black in that area.
                                    Here is the config.js
                                    code_tvar config = {
                                    	port: 8080,
                                    	language: "en",
                                    	timeFormat: 12,
                                    	units: "imperial",
                                    			     // false, default for all  NON-armv6l devices
                                            		// position: 'bottom_left',
                                                		apiKey: '56cab4b5d5e24cfea8c436ac591d722c'
                                    			module: "alert",
                                    			module: "updatenotification",
                                    			position: "top_bar"
                                    			module: "clock",
                                    			position: "top_left"
                                    			header: "US Holidays",
                                    						symbol: "calendar-check",
                                    						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                                    ext
                                      sdetweil @BD0G
                                      @BD0G gotta have a position setting
                                        BD0G @sdetweil
                                        @sdetweil Damn you are helpful!
                                        I forgot to uncomment the position setting. Duh. Man little things just slip by. :)
                                          BD0G
                                          That works. Now I am struggling with understanding the IP Whitelist area . I want to open up access to all IP Addresses internally between 192.168.1.2 and 192.168.1.254 as I am unsure which of those IP addresses will be dynamically assigned to the device I use to access the MMM-Remote-Control app.
                                            sdetweil @BD0G
                                            @BD0G so, i just clear the whitelist, and allow anyone on my network to connect… (its only me,inside my house)
                                            ipWhitelist: [],
                                            you will also have to open up the address block
                                            address: [] or [0.0.0.0]
                                            otherwise it means ONLY the same machine can talk to the mirror…
                                            • 4 / 4
