    [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates
    76 Posts 13 Posters 76.1k Views 13 Watching
    • Cr4z33C Offline
      Cr4z33 @Cr4z33
      @bolish in addition to what I wrote in my last post I forgot that I actually have entered the custom commands in the module config section so it is twice weird as it should execute those commands.
        mohace @Cr4z33
        @Cr4z33 said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
        @mohace huh?
        I don’t have those menu’s entries at all.
        Are you using a custom version of the module or? :confused_face:
        Not at all. You can see same pic in shbatm second post, after the first one you replyed.
        @shbatm said in [MMM-Remote-Control](v2-dev) Extensible REST API, Dynamic Menus, and Socket Communications, plus other updates:
        Additional Features Added:
        • Dynamic Module Control menu – uses the new API to create a Module Control menu on the remote page to control other modules via notifications.
        • Custom Menu – ability to specify your own custom menu items from a file (for advanced users)
        • Use PM2 API to control restarts/stops of MM. Can also support starting/stopping other PM2 scripts by passing processName: “scriptToUse” in the query payload.
        Example Dynamic Menu for MMM-Carousel w/ Navigation
        It seems that you need activate some features in modules to show them in this menu. But I don’t know what needs Newsfeed, for to have active his entry.
        • Cr4z33C Offline
          Cr4z33 @mohace
          @mohace Oh yes you are correct I forgot that we can have custom entries indeed.
          Well in my case Newsfeed is showing up by default without having to enable manually something. :man_shrugging_light_skin_tone:
          • L Offline
            Lowis
            I don’t have these entries
            reinstalled twice the module without luck.
            when i first installed this module the entries was there .
            my config.js
                  module: 'MMM-Remote-Control',
                  position: 'bottom_left',
                    customCommand: {},
                    customMenu: 'custom_menu.json',
                    showModuleApiMenu: true,
                    apiKey: ''
            • swvalentiS Offline
              swvalenti Project Sponsor
              Any idea why my remote control looks like this? It’s lacking the right buttons etc…0_1557623899958_MM.PNG
              • Cr4z33C Offline
                Cr4z33
                I need to add some custom commands to control MMM-RTSPStream streams like if they were tv channel buttons, but I am not skilled enough to understand the interested readme section. :smiling_face_with_open_mouth_cold_sweat:
                @shbatm could you please help me adding one stream button (as example for all the others to add)?
                All I need is to run a combo of ‘RTSP-STOP all’ first (I am using OMXplayer therefore I prefer to kill any running stream first) and ‘RTSP-PLAY streamX’ immediately after.
                Cr4z33C 2 Replies Last reply Reply Quote 0
                  When I press Restart MagicMirror it doesn’t restart…if I hit Refresh Browser the browser refreshes. Any idea why Restart MagicMirror command doesn’t work? Running latest updates on all platforms.
                    retroflex Project Sponsor Module Developer @swvalenti
                    @swvalenti Yeah, same here. Would really like to find an answer for this…
                    • Cr4z33C Offline
                      Cr4z33 @Cr4z33
                      @shbatm you there mate please? :smiling_face_with_halo:
                      • Cr4z33C Offline
                        Cr4z33 @Cr4z33
                        It looks like @shbatm is not following this forum since many months.
                        Therefore @bolish or someone else could you please post your custom menu entries code so that I can better figure out how to enter that MMM-RTSPStream code?
                        The related README section didn’t make so much sense to me. :man_shrugging_medium_skin_tone:
                          BD0G
                          Using Raspberry Pi Zero W with latest version of Buster. MM2 working . used command in first post to install MMM-RemoteControl. Used Master Branch and not Dev. Module directory created sucessfully. Edited config.js with appropriate entries. I dont have anything displaying on screen besides the clock and Holidays .
                          Its supposed to display the default webpage in the center of the screen. I dont see that . Just black in that area.
                          Here is the config.js
                          code_tvar config = {
                          	port: 8080,
                          	language: "en",
                          	timeFormat: 12,
                          	units: "imperial",
                          			     // false, default for all  NON-armv6l devices
                                  		// position: 'bottom_left',
                                      		apiKey: '56cab4b5d5e24cfea8c436ac591d722c'
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			position: "top_left"
                          			header: "US Holidays",
                          						symbol: "calendar-check",
                          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                          ext
                            sdetweil @BD0G
                            @BD0G gotta have a position setting
                              BD0G @sdetweil
                              @sdetweil Damn you are helpful!
                              I forgot to uncomment the position setting. Duh. Man little things just slip by. :)
                                BD0G
                                That works. Now I am struggling with understanding the IP Whitelist area . I want to open up access to all IP Addresses internally between 192.168.1.2 and 192.168.1.254 as I am unsure which of those IP addresses will be dynamically assigned to the device I use to access the MMM-Remote-Control app.
                                  sdetweil @BD0G
                                  @BD0G so, i just clear the whitelist, and allow anyone on my network to connect… (its only me,inside my house)
                                  ipWhitelist: [],
                                  you will also have to open up the address block
                                  address: [] or [0.0.0.0]
                                  otherwise it means ONLY the same machine can talk to the mirror…
                                    mohace
                                    Hi. There is a way to call, i.e, module controls/carousel/next slide from url?
                                    • N Offline
                                      Nneuland @shbatm
                                      • 4 / 4
