    MMM-DarkSkyForecast - Yet ANOTHER weather module
    334 Posts 67 Posters 891.2k Views 74 Watching
    • H Offline
      humdinger44
      Hey guys,
      I too am trying to solve the “Loading…” problem. I’ve tried a number of things but the most telling clue I have is that dark sky doesn’t register any api use for my key. I’ve tried resetting the key, no difference. No errors show up in the dev tool. Does anyone see any problems with my config?
         	module: "MMM-DarkSkyForecast",
        	header: "Weather",
      	classes: "default everyone",
        	disabled: false,
        		config:
          			apikey: "**************",
          			latitude: "**.******",
          			longitude: "-**.******",
          			iconset: "2m",
          			forecastLayout: "table"
        motdog @humdinger44
        @humdinger44 longitude should have - you have _ that could be it
        • H Offline
          humdinger44 @motdog
          @motdog Thanks, I double checked that but it is the negative sign “-”
            the ‘loading’ problem is typical of a module that displays a default message (‘Loading…’)
            which is replaced when the data arrives. So, the data did not arrive…
            can u open the developers window and select the console tab and put DarkSky in the filter box. to remove any other messages…
            there should be some message about the api usage, key, … something
              I changed my key so it was invalid, and see an error in the terminal window
              [MMM-DarkSkyForecast] 15-May-19 09:11 ** ERROR ** null
              • H Offline
                humdinger44 @sdetweil
                @sdetweil https://imgur.com/d2Xeqgs.jpg I dont see anything like that
                https://i.imgur.com/d2Xeqgs.jpg shows the errors tab. i dont believe any of them apply to darksky
                  sdetweil @humdinger44
                  @humdinger44 note, this is in the terminal window where u issue npm start…
                  Or it should appear in the pm2 logs
                  • H Offline
                    this?
                    https://i.imgur.com/SZZOQHm.png?1
                    note that my internet connection up and running
                      @humdinger44 that says u are trying to run two copies on the same port. No can do do u have 2 entries for pm2 startup?
                      • H Offline
                        @sdetweil it’s only like that because of how I started the dev tool while the mirror was already running
                          @humdinger44 can’t do that. Have to stop other 1st. Only one copy running at a time
                          • H Offline
                            @sdetweil Sorry, I’m wildly incompetent at this.
                            My mirror launches in electrum automatically. When I kill it, it just relaunches itself seconds later. I don’t know how to launch that inspection tool without starting a second copy.
                              @humdinger44 do
                              pm2 show
                              Find the name of the app
                              Then do
                              pm2 stop ????
                              Where ??? Is the app name
                              Then do the
                              npm start dev
                              from a terminal window
                              • H Offline
                                @sdetweil Thanks for walking me through this. Unfortunately ive not been able to identify the process https://i.imgur.com/hgXS13T.png?1
                                i tried doing it from different directory locations and with the ls command because show wasnt working.
                                • N Offline
                                  nobita @j.e.f.f
                                  @j-e-f-f
                                  Thanks for your module,it 's very nice and useful
                                  I have problem ,this module not support my language
                                  because ,I am Thai peaple
                                  I would to know how to add support Thai language
                                  Thank for your help
                                    @humdinger44 try pm2 list from the MagicMirror folder
                                    • N Offline
                                      nobita @nobita
                                      @j-e-f-f
                                      I try to adjust fontsize in custom.css but not work
                                      so I would like to know how to Enlarge fontsize and change color
                                      at position A,B,C,D,E (as photo)
                                      Thanks for hint
                                      • rudibaraniR Offline
                                        rudibarani Project Sponsor
                                        Dear @j-e-f-f ,
                                        thank you for this great module. I enjoy looking at it every morning :grinning_face:
                                        I would like to use real world data from a temperature sensor at our house instead of the “current temperature” data from the weather service.
                                        Would it be possible to optionally add an URL to the config that returns the temperature as plain value (e.g. 15.76) and replace the corresponding value from the weather service?
                                        Thanks for considering this,
                                        Phillip
                                          j.e.f.f Project Sponsor Module Developer @rudibarani
                                          @rudibarani it’s a great idea but not exactly as simple as enabling a second data source URL. As my module is designed to use the Dark Sky API, I would need a separate routine to handle the different data format, and it would be a one-off for just your sensor model. Of course others will want their sensors supported and so on… unfortunately I don’t have the time to support such variances in functionality, which all do what my module already does — provide you with real-time weather information.
                                          One of the major benefits of the Dark Sky API is how accurate it is, given you can put in your exact long/lat coordinates. The temperature you’ll get from the API should be very close to what your sensor is providing, maybe off by at most one or two degrees.
                                          That said, my module is very much open-source. You are free to fork it and try to add this functionality on your own. If your programming experience is limited, modifying someone else’s code is a good way to learn. My code is very well documented so you should have a good idea as to what each part does. Also JavaScript is very forgiving and makes for a great beginner’s language.
                                          I know this isn’t the answer you wanted to hear, but I hope you’ll be encouraged give modifying my module a shot. It’s very satisfying when you make something like this work for your exact needs. It’s how I got started, and I guess it’s just snowballed from there! :D
                                          rudibaraniR 1 Reply Last reply Reply Quote 0
                                            rudibarani Project Sponsor @j.e.f.f
                                            Dear @j-e-f-f,
                                            thanks for your feedback. I don’t have much coding skills (yet) - but I will try :slightly_smiling_face:
                                            Best,
                                            Phillip
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 16
                                            • 17
                                            • 11 / 17
