    2 MagicMirror windows
    17 Posts 4 Posters 7.5k Views 3 Watching
    • U Offline
      umeeq @Mykle1
      @Mykle1
      You are right. However, it seems like MagicMirror might be the one I should delete? When I run pm2 start mm.sh, the “mm” window launches.
      Thanks for your help.
        Mykle1 Project Sponsor Module Developer @umeeq
        @umeeq said in 2 MagicMirror windows:
        Yes sir :-)
        U 1 Reply Last reply Reply Quote 1
        • U Offline
          umeeq @Mykle1
          @Mykle1
          This worked! Thank you so much.
            @umeeq
            You’re welcome. Peace!
            • U Offline
              umeeq @Mykle1
              @Mykle1 You helped me with this a year ago and I ran into the same issue. I deleted MagicMirror, and now when I run pm2 start mm.sh the mirror doesn’t launch. I also noticed the mm.sh file was missing from /home/pi.
                sdetweil @umeeq
                @umeeq mm.sh is located in /home/pi/MagicMirror/installers
                U 1 Reply Last reply Reply Quote 0
                • U Offline
                  umeeq @sdetweil
                  @sdetweil Thanks for your response Sam.
                  I initially also saw a version in /home/pi, possibly the duplicate.
                  I’m still not sure how to boot the correct version of the mm though. Also not sure how I keep setting up two MMs.
                  Thanks in advance.
                    sdetweil @umeeq
                    @umeeq pm2 delete one of the apps or copy mm.sh into the MM folder
                    • U Offline
                      umeeq @sdetweil
                      @sdetweil As in here?
                        sdetweil @umeeq
                        @umeeq yes… MM (or mm) = MagicMirror (tired of typing it out all the time)
                        • U Offline
                          umeeq @sdetweil
                          @sdetweil No worries, I just wasn’t sure where you meant to copy it into.
                          I copied it into /home/pi/MagicMirror… ran pm2 start mm.sh and still nothing.
                          I can execute the file from the folder location, but cant run pm2 stop mm to stop the app. I ran pm2 show mm and got the result below.
                            sdetweil @umeeq
                            pm2 start mm.sh
                            from what folder?
                            • U Offline
                              umeeq @sdetweil
                              @sdetweil Copied from /home/pi/MagicMirror/installers into /home/pi/MagicMirror. Mind you I didn’t delete the original in the installers folder.
                              Bare with me with the hand-holding.
                                bhepler Module Developer @umeeq
                                @umeeq - Looking at your info, the pm2 process is expecting to find the mm.sh file in the folder /home/pi
                                It’s this line: script path /home/pi/mm.sh
                                So move the script to that location.
                                mv /home/pi/MagicMirror/mm.sh /home/pi
                                chmod +x /home/pi/mm.sh
                                U 1 Reply Last reply Reply Quote 3
                                • U Offline
                                  umeeq @bhepler
                                  @bhepler This worked, thank you!
