    2 MagicMirror windows
    17 Posts 4 Posters 7.7k Views 3 Watching
    • U
      umeeq @Mykle1
      @Mykle1
      This worked! Thank you so much.
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @umeeq
        @umeeq
        You’re welcome. Peace!
        U 1 Reply Last reply Reply Quote 1
        • U
          umeeq @Mykle1
          @Mykle1 You helped me with this a year ago and I ran into the same issue. I deleted MagicMirror, and now when I run pm2 start mm.sh the mirror doesn’t launch. I also noticed the mm.sh file was missing from /home/pi.
            sdetweil @umeeq
            @umeeq mm.sh is located in /home/pi/MagicMirror/installers
            U 1 Reply Last reply Reply Quote 0
            • U
              umeeq @sdetweil
              @sdetweil Thanks for your response Sam.
              I initially also saw a version in /home/pi, possibly the duplicate.
              I’m still not sure how to boot the correct version of the mm though. Also not sure how I keep setting up two MMs.
              Thanks in advance.
                sdetweil @umeeq
                @umeeq pm2 delete one of the apps or copy mm.sh into the MM folder
                • U
                  umeeq @sdetweil
                  @sdetweil As in here?
                    sdetweil @umeeq
                    @umeeq yes… MM (or mm) = MagicMirror (tired of typing it out all the time)
                    • U
                      umeeq @sdetweil
                      @sdetweil No worries, I just wasn’t sure where you meant to copy it into.
                      I copied it into /home/pi/MagicMirror… ran pm2 start mm.sh and still nothing.
                      I can execute the file from the folder location, but cant run pm2 stop mm to stop the app. I ran pm2 show mm and got the result below.
                        sdetweil @umeeq
                        @umeeq said in 2 MagicMirror windows:
                        pm2 start mm.sh
                        from what folder?
                        • U
                          umeeq @sdetweil
                          @sdetweil Copied from /home/pi/MagicMirror/installers into /home/pi/MagicMirror. Mind you I didn’t delete the original in the installers folder.
                          Bare with me with the hand-holding.
                            bhepler Module Developer @umeeq
                            @umeeq - Looking at your info, the pm2 process is expecting to find the mm.sh file in the folder /home/pi
                            It’s this line: script path /home/pi/mm.sh
                            So move the script to that location.
                            mv /home/pi/MagicMirror/mm.sh /home/pi
                            chmod +x /home/pi/mm.sh
                            U 1 Reply Last reply Reply Quote 3
                            • U
                              umeeq @bhepler
                              @bhepler This worked, thank you!
