    2 MagicMirror windows
    17 Posts 4 Posters 6.8k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @umeeq
      @umeeq
      I assume PM2 is reporting something like this
      In which case you would:
      pm2 stop mm
      pm2 delete mm
      pm2 save
      rm ~/mm.sh
      Then check your instances again. :-)
      U 1 Reply Last reply Reply Quote 1
      • U Offline
        umeeq @Mykle1
        @Mykle1
        You are right. However, it seems like MagicMirror might be the one I should delete? When I run pm2 start mm.sh, the “mm” window launches.
        Thanks for your help.
          @umeeq said in 2 MagicMirror windows:
          Yes sir :-)
          • U Offline
            umeeq @Mykle1
            @Mykle1
            This worked! Thank you so much.
              @umeeq
              You’re welcome. Peace!
              • U Offline
                umeeq @Mykle1
                @Mykle1 You helped me with this a year ago and I ran into the same issue. I deleted MagicMirror, and now when I run pm2 start mm.sh the mirror doesn’t launch. I also noticed the mm.sh file was missing from /home/pi.
                  sdetweil @umeeq
                  @umeeq mm.sh is located in /home/pi/MagicMirror/installers
                  U 1 Reply Last reply Reply Quote 0
                  • U Offline
                    umeeq @sdetweil
                    @sdetweil Thanks for your response Sam.
                    I initially also saw a version in /home/pi, possibly the duplicate.
                    I’m still not sure how to boot the correct version of the mm though. Also not sure how I keep setting up two MMs.
                    Thanks in advance.
                      sdetweil @umeeq
                      @umeeq pm2 delete one of the apps or copy mm.sh into the MM folder
                      • U Offline
                        umeeq @sdetweil
                        @sdetweil As in here?
