    2 MagicMirror windows
    17 Posts 4 Posters 7.5k Views 3 Watching
    • U Offline
      umeeq
      Hi Everyone,
      I’m very new to MM and need some assistance. I just tried entering the code to enable auto boot and now everytime the mirror boots I have 2 MM windows running. I have gone into the config.js file and edited to determine the correct window but now need to get rid of the second window I created by “enabling” auto boot.
      Will backtracking to remove the code work?
      Thanks in advance.
        Mykle1 Project Sponsor Module Developer @umeeq
        @umeeq
        I assume PM2 is reporting something like this
        In which case you would:
        pm2 stop mm
        pm2 delete mm
        pm2 save
        rm ~/mm.sh
        Then check your instances again. :-)
        U 1 Reply Last reply Reply Quote 1
        • U Offline
          umeeq @Mykle1
          @Mykle1
          You are right. However, it seems like MagicMirror might be the one I should delete? When I run pm2 start mm.sh, the “mm” window launches.
          Thanks for your help.
            @umeeq said in 2 MagicMirror windows:
            Yes sir :-)
            • U Offline
              umeeq @Mykle1
              @Mykle1
              This worked! Thank you so much.
                @umeeq
                You’re welcome. Peace!
                • U Offline
                  umeeq @Mykle1
                  @Mykle1 You helped me with this a year ago and I ran into the same issue. I deleted MagicMirror, and now when I run pm2 start mm.sh the mirror doesn’t launch. I also noticed the mm.sh file was missing from /home/pi.
                    sdetweil @umeeq
                    @umeeq mm.sh is located in /home/pi/MagicMirror/installers
                    U 1 Reply Last reply Reply Quote 0
                    • U Offline
                      umeeq @sdetweil
                      @sdetweil Thanks for your response Sam.
                      I initially also saw a version in /home/pi, possibly the duplicate.
                      I’m still not sure how to boot the correct version of the mm though. Also not sure how I keep setting up two MMs.
                      Thanks in advance.
                        sdetweil @umeeq
                        @umeeq pm2 delete one of the apps or copy mm.sh into the MM folder
                        • U Offline
                          umeeq @sdetweil
                          @sdetweil As in here?
                            sdetweil @umeeq
                            @umeeq yes… MM (or mm) = MagicMirror (tired of typing it out all the time)
                            • U Offline
                              umeeq @sdetweil
                              @sdetweil No worries, I just wasn’t sure where you meant to copy it into.
                              I copied it into /home/pi/MagicMirror… ran pm2 start mm.sh and still nothing.
                              I can execute the file from the folder location, but cant run pm2 stop mm to stop the app. I ran pm2 show mm and got the result below.
                                sdetweil @umeeq
                                pm2 start mm.sh
                                from what folder?
                                • U Offline
                                  umeeq @sdetweil
                                  @sdetweil Copied from /home/pi/MagicMirror/installers into /home/pi/MagicMirror. Mind you I didn’t delete the original in the installers folder.
                                  Bare with me with the hand-holding.
                                    bhepler Module Developer @umeeq
                                    @umeeq - Looking at your info, the pm2 process is expecting to find the mm.sh file in the folder /home/pi
                                    It’s this line: script path /home/pi/mm.sh
                                    So move the script to that location.
                                    mv /home/pi/MagicMirror/mm.sh /home/pi
                                    chmod +x /home/pi/mm.sh
                                    U 1 Reply Last reply Reply Quote 3
                                    • U Offline
                                      umeeq @bhepler
                                      @bhepler This worked, thank you!
