    2 MagicMirror windows
    17 Posts 4 Posters 7.7k Views 3 Watching
      sdetweil @umeeq
      @umeeq mm.sh is located in /home/pi/MagicMirror/installers
      U 1 Reply Last reply Reply Quote 0
      • U
        umeeq @sdetweil
        @sdetweil Thanks for your response Sam.
        I initially also saw a version in /home/pi, possibly the duplicate.
        I’m still not sure how to boot the correct version of the mm though. Also not sure how I keep setting up two MMs.
        Thanks in advance.
          sdetweil @umeeq
          @umeeq pm2 delete one of the apps or copy mm.sh into the MM folder
          • U
            umeeq @sdetweil
            @sdetweil As in here?
              sdetweil @umeeq
              @umeeq yes… MM (or mm) = MagicMirror (tired of typing it out all the time)
              • U
                umeeq @sdetweil
                @sdetweil No worries, I just wasn’t sure where you meant to copy it into.
                I copied it into /home/pi/MagicMirror… ran pm2 start mm.sh and still nothing.
                I can execute the file from the folder location, but cant run pm2 stop mm to stop the app. I ran pm2 show mm and got the result below.
                  sdetweil @umeeq
                  @umeeq said in 2 MagicMirror windows:
                  pm2 start mm.sh
                  from what folder?
                  • U
                    umeeq @sdetweil
                    @sdetweil Copied from /home/pi/MagicMirror/installers into /home/pi/MagicMirror. Mind you I didn’t delete the original in the installers folder.
                    Bare with me with the hand-holding.
                      bhepler Module Developer @umeeq
                      @umeeq - Looking at your info, the pm2 process is expecting to find the mm.sh file in the folder /home/pi
                      It’s this line: script path /home/pi/mm.sh
                      So move the script to that location.
                      mv /home/pi/MagicMirror/mm.sh /home/pi
                      chmod +x /home/pi/mm.sh
                      U 1 Reply Last reply Reply Quote 3
                      • U
                        umeeq @bhepler
                        @bhepler This worked, thank you!
