    Add module reference to alerts
    Scheduled Pinned Locked Moved Feature Requests
    alert
    7 Posts 3 Posters 5.6k Views 2 Watching
    • strawberry 3.141S Offline
      Hey guys,
      I recently worked on
      [card:fewieden/MMM-AlarmClock]
      and stumbled on a problem. I want to support normal devices and touch screen devices. Non touch screen is working fine already,
      but there’s a problem for the touch screen mode. I added a button but when I fire an alert from the default alert module, there will be an overlay, so my button will not be clickable. To get around this, I thought about adding a reference to an alert, so I can query the alert of my module and give it a click event.
      My thought was to change this https://github.com/MichMich/MagicMirror/blob/master/modules/default/alert/alert.js#L91 to
      message += "<span data-sender='" + sender.name + "' class='thin' style='font-size:22px;line-height: 30px;'>" + params.message + "</span>";
      What are your thoughts on this?
      • MichMichM Offline
        MichMich
        Paging @paviro since he is te writer of the alert module.
        • MichMichM Offline
          MichMich
          Can’t you just change the z-index of the button in your module’s CSS file?
            strawberry 3.141 Project Sponsor Module Developer @MichMich
            @MichMich z-Index didn’t work for me, but with the following code I could achieve what I was trying to do.
            MM.getModules().enumerate((module) => {
                if(module.name === 'alert'){
                    module.alerts["MMM-AlarmClock"].ntf.addEventListener("click", ()=>{this.resetAlarmClock();});
            • MichMichM Offline
              MichMich
              So no more change to the core is required?
                @MichMich In my oppinion it’s not a good idea to mess around with other modules variables. If someone has a better approach just let me now, but it would work without changes to the core at the moment.
                  paviro
                  Well feel free to change things in the alert module since it should be rewritten at some point anyway… :D
                  – The Doctor
