    Tilting the display by a couple of degrees to make it straight
    8 Posts 5 Posters 2.4k Views 3 Watching
      alborzs
      I have managed to install the display behind my mirror a bit tilted. It is off by a couple of degrees only, but it still shows.
      Is there anyway to tilt the whole interface a couple of degrees?
      I have already searched quite a bit of the display of the raspberry pie can be tilted but it I have not found a solution, so I am really hoping that the MM interface can be tilted! The display is already glued so that is difficult to change now.
      • brobergB Offline
        broberg Project Sponsor @alborzs
        @alborzs it probably is possible, but it will look terrible, if not blurry it will create artifacts.
        • joela85J Offline
          joela85
          I think your best bet is do remount your display to be square. As @broberg said, if you can do it, it won’t look very good due to the nature of the line up of the pixels. Small text will probably be un-readable.
          • evroomE Offline
            evroom
            @alborzs
            I rotated my screen from landscape to portrait using custom.css.
            Cannot find the topic in this forum, but this is the body in my custom.css file:
            body {
              margin: 0;
              position: absolute;
              transform: rotate(-90deg);
              transform-origin: top left;
              width: 100vh;
              height: 100vw;
              object-fit: cover;
              top: 100vh;
                    visibility: visible;
            Perhaps you give it a try with different degrees in the rotate() parameter.
            MagicMirror version: 2.33.0
            Test environment:
            MagicMirror version: v2.33.0
            • bheplerB Offline
              bhepler Module Developer
              This reminds me of a joke.
              Q: How many software engineers does it take to change a light bulb?
              A: None. It’s a hardware problem.
              Q: How many hardware engineers does it take to change a light bulb?
              A: None. Just tell the software engineers to code around it.
                alborzs
                @bhepler :)
                @evroom Thanks, I will give that a try. It is just such a beautiful installation I don’t wanna mess with it now. All the cable management, everything is perfect. I curse myself for mounting the display every time I am in front of the mirror
                • brobergB Offline
                  You know what, @evroom s solution might just work.
                  Tried it and it isn’t half bad, it gets blurry, but not overly so. (disclaimer, tried this on a 24" 1440p display)
                  body {
                  transform: rotate(0.2deg);
                    alborzs
                    @broberg @evroom , thanks guys. That is exactly what I needed.
                    -1 degree of rotation and it is perfect now.
